ESC light on? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > ESC light on?
The Original 3/8" Ruffstuff Diff Cover!The Cure for your Tie Rod Roll!Bolt In Jeep JK Tie Rod Kit!
Unread 12-20-2014, 07:25 PM   #1
94beachxj
1994 XJ Cherokee
ESC light on?
The ESC light came on while I was driving to work this week.
Now I did install a Daystar budget boost last week end.
I was going to get a alignment asap...but I wanted to show it off at work 1st of course.
Well after 40 plus miles I heard that ding and saw the ESC light appear. 3 days later and 49 miles more no change.
Today I got the alignment done,and to my surprised the code was a speed sensor failure. Now I'm very confused........ Well i tested the alignment and returned to the shop to pay the bill. They told me at the Napa service center its a warranty deal and your covered. Cool right? So i left NAPA and proceeded to the stop light 1 mile away...........No ESC light and the cruise control works! I am persuaded to think the off tracking due to a misaligned suspension, sent a code from the speed sensors?
The 2013 Wrangler has never threw a code in the 1 yr of driving it.
I hope this help any other jeeper that has this issue.
94beachxj is offline   Reply With Quote Quick reply to this message
Unread 12-21-2014, 03:32 AM   #2
zjilla
U have to drive over 30mph fpr 10 miles to reset the esp after your steeringwheel was centered. The abs esp and bas lights are all simitaniously linked together
Sent from my GT-N7000 using JeepForum
2007 Unlimited Sahara
98 ZJ Limited RHD (British spec)
USAF Military Working Dog Handler
www.annirlane.blogspot.com
October 2013 JK of the month
My Slowly but surely JK build thread:
http://www.jeepforum.com/forum/f96/s...hread-1562595/
zjilla is offline   Reply With Quote Quick reply to this message
Unread 12-21-2014, 09:10 AM   #3
jwmbishop
Accidental Obfuscator
jwmbishop's Avatar
2011 JK Wrangler
Codes are "out of parameter" - not good or bad. So your thinking is along the correct lines. The code was for "out of parameter speed sensor voltage". Which could have been caused by false engagement of TC/ Stability.
If you dont own a code scanner - you are at the mercy of others...
If all's working now - just drive it like ya stole it and see if it throws another code.
J Wm Bishop EA, ASADE
Waiting for the JAMBOREE at Rubicon is worse than waiting for Christmas...
jwmbishop is offline   Reply With Quote Quick reply to this message
Unread 01-27-2015, 06:36 PM   #4
94beachxj
1994 XJ Cherokee
After Lift. With my Fav Viking players jersey!
Unread 01-28-2015, 02:54 PM   #5
SoK66
2009 JK Wrangler
This is a not uncommon issue with budget lifted JKs. In general all that's needed is a steering wheel centering. If that does not cure it there's the likelihood the axles have been pulled too far off center. You can center them in a couple of ways, best being raised track bar mounts and/or adjustable track bars
Driver has no money. Owns two Jeeps.
SoK66 is offline   Reply With Quote Quick reply to this message
