ESC kicks in after 4" lift - Page 2 - JeepForum.com
post #16 of 39 Old 01-15-2013, 03:48 PM
starscream
1981 CJ5
Originally Posted by jstrubberg View Post
Magnusson-Moss requires that the warrant or prove that a modification caused the malfunction, they can't just say it did.
It also expressly forbids requirements for branded-only parts.
If a dealership refuses you warranty service on the basis of a mod and you accept it, that's your fault. You have legal protection against that kind of thing.
http://en.wikipedia.org/wiki/Magnuso...s_Warranty_Act
Magnusson-Moss doesn't make it cheap to fight a dealership and lawyers in court either. I know what you're saying, but you have to also realize there are dealerships out there that have and will deny claims and then you are only left to fight them with lawyers which cost time and money. All I said is since he was paying to have the dealership do the work anyway, any protections he was promised should be in writing. There's nothing wrong with that.
starscream is offline
post #17 of 39 Old 01-15-2013, 04:11 PM
MountainMan864
Shouldve traded in for a 2012 lol.
MountainMan864 is offline
post #18 of 39 Old 01-15-2013, 04:25 PM
SoK66
2009 JK Wrangler
Originally Posted by mdsteves View Post
So my ESC kicks in around corners like exit ramps after my 4" lift was installed. It happened with stock tires and it happens with the 35" nittos i just got installed.
So i called the dealership and they said it is normal with any newer jeep with a 3-4" lift. Is this a fact or are BSin me?
Bad info from the dealer. Indicates eitehr teh wheel isn't centered, and /or the axles aren't centered side to side under the frame. Center the axles first, starting with the rear. Measure from mirror image spots on the frame to the tire sidewalls. Don't measure tire letters, etc. Make sure wheels are turned dead ahead and tire pressures are identical. Adjust the track bar until the readings are within 1/8" side to side. Do the rear first, adjust as needed, then do the front. Then check and center the steering wheel as needed. (Adjust to center using the drag link.) Should do the trick.
SoK66 is offline
post #19 of 39 Old 01-19-2013, 07:20 AM Thread Starter
mdsteves
Do i need to put the rear on jacks to re-center the rear?
I have to order the rear adj trackbar and want to put it on when it comes. The damn axle is about 1"+ to the left.
mdsteves is offline
post #20 of 39 Old 01-19-2013, 07:49 AM
JTPhoto
JTPhoto's Avatar
Did they instal a rear trackbar relocation bracket? If not, that may be all you need.
^^Jeff^^
2008 Black and Khaki Sahara Unlimited Trax-Lok rear diff. 3.5" Rock Krawler fr springs, rear TeraFlex 2.5 BB, D44HD/J8 w/ OX locker and RCVs, 37x12.50x17 Pitbull Rockers on ProComp 2635 Predator Alloys, AEV Prem Bumper, Smitty X2O 12K ETC..
JTPhoto is offline
post #21 of 39 Old 01-19-2013, 08:30 AM Thread Starter
mdsteves
Yea they did... Off by 1/2". my measurements were off.
mdsteves is offline
post #22 of 39 Old 01-19-2013, 08:35 AM
starscream
1981 CJ5
No you center it on the ground, otherwise it would be off to the left again under load. It'll make a small difference too if you switch between a hard top or soft top because of the added weight. There should be a write up somewhere that explains what to do. Basically with it disconnected you bounce up and down on the rear bumper a few times to center it. Sounds hokey but it works.
Edit: I see you do have a bracket
post #23 of 39 Old 01-19-2013, 08:19 PM
SoK66
2009 JK Wrangler
That's your problem, even if as you say in a later thread that it's off by 1/2", not 1". Even 1/2" is too much.
Not sure what lift you have, but if it came with an axle side raised track bar mount bracket with multiple holes, use the hole in the bracket that gets the axle closest to centered. An adjustable track bar is best, but you can usually get a stock bar to center fairly close.
Get the rear centered, then do the front.
SoK66 is offline
post #24 of 39 Old 01-19-2013, 08:43 PM Thread Starter
mdsteves
The dealership went with a Rough Country lift. The bracket is installed but does not have multiple holes. I ordered an adj rear trackbar and will be here this week.
Looks like I will have to lift the rear off the ground to get springs off to get the bolt out of the trackbar bracket...fun times.
The front is centered when I measured it.
Do I need to loosen the control arm's nuts to re-center?
mdsteves is offline
post #25 of 39 Old 01-19-2013, 09:48 PM
Heath
2014 JK Wrangler
Steering wheel isn't perfectly centered, its just close enough that it doesn't cause a problem often.
Buy a Procal and set the wheel yourself on the street. That will get it the most perfect. Get on a deserted street and loosen the drag link clamp bolts. Drive a few hundred feet slowly and let the wheel go where it wants to as you come to a stop. Adjust the wheel according to the Procal instructions. No more issues
2013 JKU Rubicon
Heath is offline
post #26 of 39 Old 01-19-2013, 10:21 PM Thread Starter
mdsteves
Have one of those coming with my trackbar
mdsteves is offline
post #27 of 39 Old 01-20-2013, 11:27 AM
SoK66
2009 JK Wrangler
You can have the wheel perfectly centered, but if the axles aren't centered to teh frame the ESP will over ride in certain situations. Gotta do the axles first, steering wheel second.
SoK66 is offline
post #28 of 39 Old 01-20-2013, 11:44 AM
Heath
2014 JK Wrangler
That's right
2013 JKU Rubicon
Heath is offline
post #29 of 39 Old 01-20-2013, 12:12 PM Thread Starter
mdsteves
Thanks everyone for pointing me in the right direction. hopefully get this fixed soon.
mdsteves is offline
post #30 of 39 Old 01-20-2013, 06:01 PM
SoK66
2009 JK Wrangler
No. Just center the axles. Be sure the rig is settled on it's tires before you adjust anything.
SoK66 is offline
