ESC kicks in after 4" lift - JeepForum.com
post #1 of 39 Old 01-15-2013, 10:39 AM Thread Starter
mdsteves
So my ESC kicks in around corners like exit ramps after my 4" lift was installed. It happened with stock tires and it happens with the 35" nittos i just got installed.
So i called the dealership and they said it is normal with any newer jeep with a 3-4" lift. Is this a fact or are BSin me?
mdsteves is offline
post #2 of 39 Old 01-15-2013, 10:49 AM
BigMikeOfTO
2011 JK Wrangler
I'm on a 4" lift with 35s....NEVER had that issue
Sent from my iPhone using my thumbs
BigMikeOfTO is offline
post #3 of 39 Old 01-15-2013, 11:33 AM
jstrubberg
2009 JK Wrangler
BS.
Either your steering wheel isn't exactly centered, or the axles have shifted slightly out of line due to the lift. The ESC thinks you are in a skid and kicks in.
jstrubberg is offline
post #4 of 39 Old 01-15-2013, 11:34 AM
jstrubberg
2009 JK Wrangler
Did you take care of the driveline after that lift? 4" can cause you driveshaft troubles...
post #5 of 39 Old 01-15-2013, 11:44 AM
222Doc
222Doc's Avatar
Did you/they center the wheel. Reset it to the new tire's as well.
4" inch is alot a lift. hope its done well. The esc should not turn, normaly.
222Doc is offline
post #6 of 39 Old 01-15-2013, 11:45 AM Thread Starter
mdsteves
Dealership told me to see if i can turn it off.
And i will be ordering a TW driveshaft for the front this weekend and the rear in 2 weeks.
mdsteves is offline
post #7 of 39 Old 01-15-2013, 12:04 PM
222Doc
222Doc's Avatar
No it will cause, not may. Its going to go out. A 4 inch lift is measured rear. so the front is at least 5+. Even 4 inch rears"s run long too new. This thing must have all the adjustible things too, when you install the rear D/l, it will need to tip the rear pinion up to aline with the cardan drive shaft. I would also set the rear back about 1+" or as much as you can.
222Doc is offline
post #8 of 39 Old 01-15-2013, 12:22 PM Thread Starter
mdsteves
I think i understand what you are saying.
I had the dealership install it so i could keep my limited lifetime power train warranty.
mdsteves is offline
post #9 of 39 Old 01-15-2013, 12:31 PM
RockyClymer
RedRock4Wheeler
RockyClymer's Avatar
Your ESC is kicking in because your steering wheel was not centered after lift. DS will need to be eventually changed but is NOT related to your ESC issue.
08 JK 23S - Colorado Jeep Club No. 204
Too much to list - see my profile for details on build
16 JK Rubi with all the trimmings
NRA Life member
"It takes a special kind of stupid to believe criminals will follow gun laws."
I do not consider myself a smartass. I point out the obvious, search for the truth, and speak fluent sarcasm. I am, by experience, an accomplished curmudgeon.
RockyClymer is offline
post #10 of 39 Old 01-15-2013, 12:42 PM
buns79
As mentioned above you need to center your steering wheel, it's easy to do and you can also shut off the esc just do a search on here its kinda pain in the a** but it can be done!
13 jku 6sp, 4:88s, elockers, 3.5" RK, Ps fenders and front bumber, ace rear, 37" km2s Olllllll0
buns79 is offline
post #11 of 39 Old 01-15-2013, 01:32 PM
starscream
1981 CJ5
I hope you got that in writing.
starscream is offline
post #12 of 39 Old 01-15-2013, 02:42 PM
jstrubberg
2009 JK Wrangler
Lift doesn't have anything to do with powertrain. The only components affected by a lift are the driveshafts, and the limited lifetime warranty is for internally lubricated parts only.
As far as warranty goes, anyway. If the dealership told you it did, thy lied to you to make a sale.
post #13 of 39 Old 01-15-2013, 03:01 PM
starscream
1981 CJ5
Which are connected to the transfer case, which is connected to the transmission, which is connected to the engine... now throw the 35" tires he got on top of that. Lots of outs for an unscrupulous dealership to attempt to deny a warranty claim.
post #14 of 39 Old 01-15-2013, 03:13 PM Thread Starter
mdsteves
That is why i want to keep it. I looked at mopar lift site and they a 4" lift is for 33-35" tires so they cant get me there. Although i already bought a truss,gussets, and sleeves in prep for 37s
mdsteves is offline
post #15 of 39 Old 01-15-2013, 03:38 PM
jstrubberg
2009 JK Wrangler
Magnusson-Moss requires that the warrant or prove that a modification caused the malfunction, they can't just say it did.
It also expressly forbids requirements for branded-only parts.
If a dealership refuses you warranty service on the basis of a mod and you accept it, that's your fault. You have legal protection against that kind of thing.
http://en.wikipedia.org/wiki/Magnuso...s_Warranty_Act
