Which Entry Guards & Rear Grab Handles - JeepForum.com
post #1 of 12 Old 11-01-2007, 04:04 PM Thread Starter
JYogi
OK
Placing an order.
Which Entry guards are the best bet?
I see the Mopar rubber ones and I also see some made by Rugged Ridge.
Any other suggestions?
I want something where I wont drill into the Jeep or anything
Also, I am getting 3 in Mastercraft front handles but what about rear grab handles? Rugged Ridge?
Kentucky Colonel, Tennessee Squire & 1911 Junkie!
08 Wrangler Unlimited Rubicon Steel Blue. Ordered 9/17 D 10/03 Driveway 10/31...
JYogi is offline
post #2 of 12 Old 11-01-2007, 04:26 PM
ge2
Gold Member
ge2's Avatar
I ended up with 3" handles for all 4 doors. The rear door handles are in the upper back corner of the door, so they probably aren't quite as ideal as if they were about 6-8 inches more forward, but they seem to work just fine for folks climbing up in there.
ge2 is offline
post #3 of 12 Old 11-01-2007, 04:56 PM
luigi0523
The MOPAR entry guards! Better quality!
luigi0523 is offline
post #4 of 12 Old 11-01-2007, 11:01 PM
tkob1060
2016 WK
just got the black mopar entry guards they are great and stick right on, also got the rear Rugged Ridge handles and they are perfect and just mount to the factory holes in the plastic around the rollbar, unbolt and slip the bolt thru the gromet hole and put them back in, takes like 10min to install both entry guards and handles
tkob1060 is offline
post #5 of 12 Old 11-02-2007, 03:05 PM
tigers34
I went with the Mopar entry guards. Still looking at grab handles. I like the Rugged Ridge handles for the back since they mount to the factory holes. I wish there was a better alternative for the front to avoid velcro.
2008 Unlimited X
Steel Blue
tigers34 is offline
post #6 of 12 Old 11-05-2007, 03:17 PM
weiva
Second the Rugged Ridge grab handles. I previously had EKSport handles in back which I moved to the front. Rear passengers instantly commented they prefer the heft and location of the Rugged Ridge ones. Price was the same as everyone else's. Note, the instructions say you can skip the 'extra' washers. Using them didn't affect installation one bit.
weiva is offline
post #7 of 12 Old 11-05-2007, 03:28 PM
DILYSI Dave
The same handles that are attached with screws in the back can also be mounted on the A-pillar up front to avoid any of the velcro attaching ones, if that's your thing.
DILYSI Dave is offline
post #8 of 12 Old 11-05-2007, 04:02 PM
tigers34
Are you talking about going from the A-pillar to the sun visor? I saw this in a thread, but could not figure out how it attaches to the sun visor.
I'm not very mechanically inclined.
2008 Unlimited X
Steel Blue
tigers34 is offline
post #9 of 12 Old 11-05-2007, 04:25 PM
rirrgang
Mopar entry guards are fine but they DO NOT protect the top lip of the door sill. They attach by double sticky tape so installation is easy and no holes to drill.
For handles I bought "Smittybuilt" from eBay for 14.95. They seem to be just like the other 6 or 7 brands out there and the price was right. They mount with Velcro arond the padding on the roll bar. For the rear I bought another branded set that bolted right in to the existing holes in the roll bar cover. Funny though is that the handles are exactly like the front smittybilt ones, even thought they are different brands. I paid under 10.00 buck for them. There must be only one or two real manufactures in China making these little gems.
Speaking of entry stuff. I just completed installing the rear tailgate gas strut last week. A near factory looking install but still going to add strap near the bottom of the tailgate to stop the door from opening beyond 90 degrees to the body. The shaft of the strut comes in to contact with the weather strip of the tail gate when allowed to open all the way and I don't want that to happen. The stop strap will make this a real clean install. I'll post some pics when it gets done. For those who'd like to do the same, here are the part numbers from McMaster Carr.
9416K182 Gas spring with threaded ends
9416K86 Nylon 10mm Ball Sockets
9512K12 Ball mounting 304 sst bracket, you'll need 2.
I also bought a door strap for an 06 wrangler and the strap pin and strap back to put stop strap on the tail gate.
-Rick
07 Sahara Unlimited
rirrgang is offline
post #10 of 12 Old 11-05-2007, 05:51 PM
tigers34
Did your rear handles come off of e-bay?
2008 Unlimited X
Steel Blue
tigers34 is offline
post #11 of 12 Old 11-05-2007, 07:28 PM
rirrgang
The handles did come from eBay.
-Rick
07 Sahara Unlimited
rirrgang is offline
post #12 of 12 Old 11-05-2007, 10:38 PM
tkob1060
2016 WK
hey the rugged ridge rear handles actually come with directions how to mount them to the front A pillar too, I guess they read the forums lol
tkob1060 is offline
Want to find hard, mountable grab handles for front and rear unclewayne65 JK Wrangler Technical Forum 21 10-13-2009 08:56 AM
Best Grab Handles?? JYogi JK Wrangler Technical Forum 23 08-27-2008 05:16 PM
grab handles tigers34 JK Wrangler Technical Forum 18 01-04-2008 09:55 PM
Grab Handles nepatsfn JK Wrangler Technical Forum 4 09-22-2007 06:23 AM
Grab Handles nikki TJ Wrangler Technical Forum 7 07-06-2004 08:54 PM
