Engine Trouble - JeepForum.com
post #1 of 8 Old 02-06-2012, 03:48 PM Thread Starter
BadPirate
Engine Trouble
P0507 - Idle Speed Performance Higher Than Expected
I received the above code on my 2008 JKU, 40,000 miles. The engine light remains on and the red lightning bolt light along with traction control will come on at random times. When the other two lights come on the idle speed will jump to 1,100 and I will have no power at all.
Any ideas as to the cause? I really don't want to run to the dealership. Thanks.
BadPirate is offline
post #2 of 8 Old 02-06-2012, 06:22 PM
RockyClymer
RedRock4Wheeler
RockyClymer's Avatar
I would suggest you re-boot your system first...disconnect battery for 5 to 10 min, the reconnect and see if this clears the code...try the simple stuff first.
08 JK 23S - Colorado Jeep Club No. 204
Too much to list - see my profile for details on build
16 JK Rubi with all the trimmings
NRA Life member
"It takes a special kind of stupid to believe criminals will follow gun laws."
I do not consider myself a smartass. I point out the obvious, search for the truth, and speak fluent sarcasm. I am, by experience, an accomplished curmudgeon.
RockyClymer is offline
post #3 of 8 Old 02-06-2012, 06:33 PM
jstrubberg
2009 JK Wrangler
How old is your battery? The JK ECM gets really weird if your battery voltage drops.
jstrubberg is offline
post #4 of 8 Old 02-06-2012, 06:51 PM Thread Starter
BadPirate
I actually just got a new battery. They swapped it out with a system saver so that may have dropped the voltage while installing the new battery.
post #5 of 8 Old 02-06-2012, 07:14 PM
ronjenx
ronjenx's Avatar
Here is some info about the code you have:
P0507-IDLE SPEED PERFORMANCE HIGHER THAN EXCEPTED
Theory of Operation
The objective of the Idle Speed Rationality is to monitor the ability to achieve and maintain a steady idle condition. The monitor will judge the functionality of the idle speed control system by monitoring RPM during idle. If RPM does not come within a calibrated deadband of target idle speed, a timer is started. If the timer reaches its maximum threshold without any sign of the RPM trending towards control, a soft failure is generated.
When Monitored:
With the engine idling in drive, the brake applied, engine run time above a minimum calibrated value, and no VSS, MAF/MAP, ECT, TPS, ETC, CKP Sensor, fuel system, or injector DTCs present.
Set Condition:
Engine speed is 200 RPM or more above target idle speed for 30 seconds. Two Trip Fault. Three good trips to turn off the MIL.
Possible Causes
AIR INDUCTION SYSTEM LEAKS
Inspect the Air Induction System for the following problems:
Leaks: Air Intake tube connection, Air Cleaner housing, etc.
PCV SYSTEM LEAKS
Inspect the PCV system for the following problems:
Leaks - cracked or damaged hoses or tubes, poor hose or tube connections, PCV valve stuck open, etc.
ENGINE VACUUM LEAKS
Start the engine.
Inspect the vehicle for external vacuum leaks.
Inspect the engine for internal leaks.
THROTTLE BODY
Inspect the throttle body for carbon build up, other restrictions, and a bent throttle plate using a straight edge.
While the vehicle is running, lightly tap on ETC Motor with your hand and listen for idle to raise.
If the idle increases:
Verify that there is good pin to terminal contact at the Throttle Body and the Powertrain Control Module connectors. If OK, replace the Throttle Body Assembly. Disconnect the Battery when replacing the Throttle Body Assembly. After installation is complete, use a scan tool and select the ETC RELEARN function.
POWERTRAIN CONTROL MODULE (PCM)
Using the wiring diagram/schematic as a guide, inspect the wiring and connectors between the Throttle Body and the Powertrain Control
Module (PCM).
Look for any chafed, pierced, pinched, or partially broken wires.
Look for broken, bent, pushed out or corroded terminals. Verify that there is good pin to terminal contact in the Throttle Body and
Refer to any Technical Service Bulletins that may apply.
ronjenx is offline
post #6 of 8 Old 02-06-2012, 08:45 PM
jstrubberg
2009 JK Wrangler
As in the problem started right after the battery replacement? If so, that's where I would start. Battery, cables, crimped wires, etc.
post #7 of 8 Old 02-07-2012, 03:20 AM Thread Starter
BadPirate
I disconnected the battery and let is sit for 30 minutes to reset. I will see what it does today.
post #8 of 8 Old 02-01-2013, 02:02 AM
CMEvans79
No update? I'm guessing everything is OK after the disconnect? My 07 is doing the same thing so I'm now very interested... sorry for grave digging, but These threads are here for a reason.
They say your jeep will eventually earn itself a name... Mine has now done that... ladys and gents, meet "Strife" because lately, that's all its given me.
CMEvans79 is offline
Engine trouble Islander92 YJ Wrangler Technical Forum 11 04-16-2011 02:40 PM
Engine Trouble... joker2041 TJ Wrangler Technical Forum 3 10-19-2006 07:55 PM
Engine trouble aju4 TJ Wrangler Technical Forum 3 07-19-2005 08:05 PM
Engine Trouble JSBlu974X4 TJ Wrangler Technical Forum 8 01-24-2005 06:00 PM
4.2 L engine trouble muddymark YJ Wrangler Technical Forum 4 09-27-2001 09:41 PM
