Engine tick 3.8L - JeepForum.com
post #1 of 26 Old 05-28-2013, 09:51 PM Thread Starter
BadBarret
Engine tick 3.8L
Looks like I need some help again I have an 07 Wrangler 6sp(47k miles), and there seems to be a ticking from the engine. It only happens after it warms up and you can hear it good between 1k-2k rpm (may happen at higher rpms but it's harder to hear) It could just be something loose vibrating but I'm not really sure. Was just curious if any others have had this issue and if so what the solution was. Thanks for any help!!
BadBarret is offline
post #2 of 26 Old 05-28-2013, 11:01 PM
RockyClymer
RedRock4Wheeler
RockyClymer's Avatar
Is the tick related to the rpm of the engine or not?
08 JK 23S - Colorado Jeep Club No. 204
Too much to list - see my profile for details on build
16 JK Rubi with all the trimmings
NRA Life member
"It takes a special kind of stupid to believe criminals will follow gun laws."
I do not consider myself a smartass. I point out the obvious, search for the truth, and speak fluent sarcasm. I am, by experience, an accomplished curmudgeon.
RockyClymer is offline
post #3 of 26 Old 05-28-2013, 11:42 PM Thread Starter
BadBarret
No tick at idle, starts at 1k and and seems to stop between 2-3k
post #4 of 26 Old 05-29-2013, 04:52 AM
JTPhoto
JTPhoto's Avatar
If you rev it while sitting still, does it tick?
^^Jeff^^
2008 Black and Khaki Sahara Unlimited Trax-Lok rear diff. 3.5" Rock Krawler fr springs, rear TeraFlex 2.5 BB, D44HD/J8 w/ OX locker and RCVs, 37x12.50x17 Pitbull Rockers on ProComp 2635 Predator Alloys, AEV Prem Bumper, Smitty X2O 12K ETC..
JTPhoto is offline
post #5 of 26 Old 05-29-2013, 05:44 AM Thread Starter
BadBarret
Yes it does
post #6 of 26 Old 05-29-2013, 08:10 AM
RockyClymer
RedRock4Wheeler
Again, does the ticking frequency increase with increasing rpms?
NRA Life member
post #7 of 26 Old 05-29-2013, 08:24 AM
JTPhoto
JTPhoto's Avatar
Wonder if this may be injector noise.
Does it sound like it is coming from the top end? Left, Right, both sides?
With an automotive stethoscope you may be able to pin point the noise.
^^Jeff^^
JTPhoto is offline
post #8 of 26 Old 05-29-2013, 09:37 AM
222Doc
222Doc's Avatar
or just use a section of hose ie. few feet of garden hose lenght of heater hose. cheep it works.
222Doc is online now
post #9 of 26 Old 05-29-2013, 12:33 PM
SteveBad
SteveBad's Avatar
2011 JK Wrangler
1) Does it go away when you step on the clutch?
2) Unrelated to the above question, What weight oil are you running?
5-20 is the recommended, but it permits a lot of valvetrain noises.
I switched to 5-30 and things got a lot quieter.
" Leave the gun .... take the cannolis. "
SteveBad is offline
post #10 of 26 Old 05-29-2013, 01:02 PM Thread Starter
BadBarret
Sorry, yes the frequency increases with the rpms.
Switched to 5w-30 last time I did my oil, however does not seem to have helped.
post #11 of 26 Old 05-29-2013, 05:20 PM
RockyClymer
RedRock4Wheeler
My guess is a hydraulic lifter is not filling...
NRA Life member
post #12 of 26 Old 05-29-2013, 05:58 PM
Jiblet
Only happens between certain RPMs, could be a loose heat shield. Although that's more often described as a buzz or rattle.
Can you post a sound or video file (or link to youtube)?
Jiblet is offline
post #13 of 26 Old 05-29-2013, 06:13 PM Thread Starter
BadBarret
You know, now that you mention it it could be a rattle. Is there anyway to post sound clips from the jeepforum app?
post #14 of 26 Old 05-29-2013, 06:17 PM Thread Starter
BadBarret
But wouldn't a rattle happen all the time whether the engine is hot or cold?? Ugh so frustrating, I keep second guessing myself...
post #15 of 26 Old 05-29-2013, 06:36 PM
JTPhoto
JTPhoto's Avatar
A heat shield rattle can be sound dependent (sympathetic vibration) from certain tones of the exhaust.. Very hard to identify sometimes.
^^Jeff^^
JTPhoto is offline
