Engine Problems due to Lift???? - JeepForum.com
post #1 of 12 Old 07-20-2010, 05:26 PM Thread Starter
JBLKMOM
Hi, I have a 2007 JK 4-door. I have a four inch lift on it and my engine threw a rod out and now I am being told by the dealer that I need a new engine. I have less than 41,000 miles on it. The dealer says that it is due to my lift as this causes additional strain on the engine. I NEVER had a single caution light on my dash board. Does this sound correct? I find it hard to believe that I should have to replace an engine at 40,000 miles due to my lift. Any thoughts would be greatly appreciated.
Thanks!
JBLKMOM is offline
post #2 of 12 Old 07-20-2010, 05:33 PM
krutj
2009 JK Wrangler
Holy Cow....this is gonna stir up a hornets nest!
We are hearing this crap quite often....
The experts will chime in soon....good luck and no it isn't correct.
find a new dealer.
-- Joel --
krutj is offline
post #3 of 12 Old 07-20-2010, 05:50 PM
1222
RIP John
1222's Avatar
Since you have a 4” lift then you probably have either 35 or 37” tires. You never filled out your profile so it’s difficult to give an honest opinion. Do you have an auto or manual? What gear ratio are you running, 3.21’s. 3.73, 4.10’s, 5.13’s or 5.38’s? Are you one of those people who think they have to floor the pedal while going up long grades and or with a head wind? Did you ever change your oil and do you keep tabs on it between changes? What were you doing when it threw the rod?
You see that there are a lot of questions that need to be answered. Much more than I listed here.
(2011-2016)
1222 is offline
post #4 of 12 Old 07-20-2010, 05:50 PM
plac
what hes talking about is how much harder the engine has to work to pull larger tires. i assume you have bigger tires if you have a 4" lift. perfect feasible explanation, but pretty rare.
2015 Subaru WRX
plac is offline
post #5 of 12 Old 07-20-2010, 05:56 PM
tjkj2002
2002 KJ Liberty
Most likely the OP never changed the oil,did extended drains,did not regear the diffs for larger tires,or hit something offroad and punctured the oil pan just to name a few things,just pic one or 2 or 3.
There blaming the lift but if he does not have receipts showing oil changes with the correct oil he's SOL anyways.You do not need every receipt,but enough to show a trend,does not need to be shop invoices either as a receipt from wallmart with "6qts of 5w20" and what ever filter is clearly stamped on there.
tjkj2002 is offline
post #6 of 12 Old 07-20-2010, 06:30 PM Thread Starter
JBLKMOM
I do have 35" tires on it. I did regular oil changes but I was over by 2000 miles for my last oil change (so I was at 5000 instead of 3000) I have never taken off road but I do punch it up hills. It isn't 4wheel drive. Help!! I don't feel like I should have to pay $6100 for a new engine at 40,000 miles.
JBLKMOM is offline
post #7 of 12 Old 07-20-2010, 06:35 PM
MilitaryJK4455
2010 JK Wrangler
Why?.....
Maybe try finding one out of a junkyard
MilitaryJK4455 is offline
post #8 of 12 Old 07-20-2010, 06:43 PM
nwbronco
2014 JK Wrangler
If you've got the records for your maintenance, you are on solid ground. Either find another dealer or contact Chrysler Customer Service.
Good luck.
Bob K.
I have to ask though. What warranty do you have? The 3/36 is gone now.
nwbronco is offline
post #9 of 12 Old 07-20-2010, 06:59 PM
JLC08JK
What was I thinking?
JLC08JK's Avatar
In my opinion the JK engine system will not allow it to run above its limits!
Take the electronic throttle, When you're in a high gear and put the peddle to the floor the response is no different than if you eased the peddle to the proper position. The old systems with a cable would open the air intake to the point of engine knock and catastrophic failure.
The towing rating on a JK Unlimited is 3500 lb!
Nobody can honestly say that stock gears and 35" tires adds more stress to the engine than a 3k lb. trailer!
The oil change shouldn't be an issue because the manual states 5k or 6k miles between changes.
I think you need to do some more research and find a way to contest their decision!
Good luck
Jim
JLC08JK is offline
post #10 of 12 Old 07-20-2010, 07:49 PM
Blu-Jacket
2009 JK Wrangler
Why not call AEV and find out what they do with brand new 3.8's that have been removed for the hemi's. Maybe save a little money.
Blu-Jacket is offline
post #11 of 12 Old 07-20-2010, 07:52 PM
Warlord2
All I will say is if they dont want to fix it under warranty, then dont let them fix it when your paying! Used low mileage engines can be had at a decent prices now-a-days and any decent mechanic can swap a engine... I wouldnt be surprised if you can get the whole thing done for under $2k depending on how hard you want to look. There are lots of salvage yards online, hell I found a 5.7l hemi for $2k with 20k miles on it....
In my opinion they should replace it under warranty, what good is a lifetime warranty when there is nothing to use it on. Problem is it sounds like you will have to fight him for it...Try taking it to another dealership, prolly would be worth traveling out of town if you have to.
edit
I just noticed you have a 07, unless you picked up a warranty package somewhere you might be out of luck in that department.
07 JK 2D X model with 6 speeds. Full Traction 3" ultimate lift kit. 315x75x16 Toyo Open Country M/T on Rock crawler procomp rim. Ruby dana44's front sleeved inside/outside C truss and rear with 5.13's gears. Homemade rock guards, rear bumper w/tire carrier, oilpan/tranny skid, evap canister skid, light bar, switch pod. Riddler diff covers, Cobra 75 w/wilson antenna, Polk speakers, 10" sub, 2x Amps, Lightforce 240 drive light, backup lights, rock lights.
Warlord2 is offline
post #12 of 12 Old 07-20-2010, 07:53 PM
rennypogo
Drop a Hemi in it!
rennypogo is offline
Engine problems Scramblerguy TJ Wrangler Technical Forum 4 05-20-2010 12:51 PM
STILL engine problems! HELP! AngusTJ TJ Wrangler Technical Forum 6 11-24-2008 10:40 AM
post engine wash problems--engine light on.... PatriotCrawler TJ Wrangler Technical Forum 6 06-21-2007 12:10 AM
engine problems DAGROTTS YJ Wrangler Technical Forum 11 03-25-2006 11:46 PM
Engine Problems Marine_Psycho YJ Wrangler Technical Forum 2 11-29-2005 05:19 PM
