Emergency help please - JeepForum.com
post #1 of 12 Old 03-10-2013, 06:49 PM Thread Starter
ferninaz
ferninaz's Avatar
On the trail, buddies rubicon, rear locker will not come unlocked. Tried pulling the M3 fuse, disconnected battery, drive it in reverse. Anyone have any idea what we can do on the trail to get it fixed?
ferninaz is offline
post #2 of 12 Old 03-10-2013, 06:59 PM
JIMBOX
This worked one time on my front Rubi locker-
Jackup one side so you can jossle the tire (you know twist)-at the same time have the driver cycle the elocker switch and pull out of 4lo--
If that doesn't work, anotherwords, if the tire you have in the air will still stay "locked", then put it in 2hi and driveit home --that'll get you off the trail-
Stay at or below 20 mph and even though it's not the front---take it easy on turns--there's a chance that because of the speed it'll try to "kickout" of elock-
Good luck
JIMBO
Yellow Jeep No. 683
--YA GOTTA HAVE CLASS--
JIMBOX is offline
post #3 of 12 Old 03-10-2013, 09:24 PM Thread Starter
ferninaz
ferninaz's Avatar
Thanks, road side assistance towed him once we great off the trail
ferninaz is offline
post #4 of 12 Old 03-10-2013, 09:45 PM
ronjenx
ronjenx's Avatar
If it happens again, pull the fill plug, and with a common screwdriver pry the locker plate (disc) to the right.
ronjenx is offline
post #5 of 12 Old 03-11-2013, 08:00 AM
JIMBOX
Glad you got out-
JIMBO
Yellow Jeep No. 683
JIMBOX is offline
post #6 of 12 Old 03-11-2013, 09:13 AM Thread Starter
ferninaz
ferninaz's Avatar
Now the big question, we will find out today if Jeep will warranty it.
ferninaz is offline
post #7 of 12 Old 03-11-2013, 09:34 AM
JIMBOX
Heh Heh, thats always upintheair-
It'll depend on the dealer and any mods your buddy made to the Rubi--
Tell him good luck
JIMBO
Yellow Jeep No. 683
JIMBOX is offline
post #8 of 12 Old 03-11-2013, 10:52 AM
Yendor
I'm not trying to be a smartalek. Trying to educate myself. What does a rear locker do that an Anti Spin (as Jeep calls it) /Positrac rear end doesn't?
Yendor is offline
post #9 of 12 Old 03-11-2013, 10:58 AM
ronjenx
ronjenx's Avatar
Anti-spin will power both wheels but has a limit. One wheel will eventually spin.
A locker will lock both wheels together and not allow one wheel to spin at all.
ronjenx is offline
post #10 of 12 Old 03-11-2013, 11:01 AM
jwmbishop
Accidental Obfuscator
jwmbishop's Avatar
2011 JK Wrangler
posi-trac is GMs brand of limited slip. Limited slip merely limits the slip speed between the two axles - one can still turn faster (thus apply more torque) than the other. Lockers do just as they describe - force both axles to turn equal speeds - thus apply equal torque...
J Wm Bishop EA, ASADE
The wagon should, of course, be as light as possible, but strength should not be sacrificed to lightness, for on any but the regularly traveled roads, the wagon will get many a
jwmbishop is offline
post #11 of 12 Old 03-11-2013, 03:28 PM Thread Starter
ferninaz
ferninaz's Avatar
If anyone is curious, the carrier bearing failed and caused it to stay in the locked position. No idea how but thats what the dealership is saying. The good thing is that TucsonChryslerJeep is doing the work under warranty.
ferninaz is offline
post #12 of 12 Old 03-11-2013, 04:29 PM
Morb
I should hope so...if a locking diff isn't intended to be used on a trail I don't know why it'd come stock on a Rubicon
Morb is offline
