Emergency brake shoe install - JeepForum.com
post #1 of 10 Old 04-21-2011, 12:39 AM Thread Starter
yfzandy
The other day I bought some new rotors and e brake shoes. When I went to install them I made sure the brake lever was down all the way and I took the star adjuster all the way in. My problem is when I installed the rotor the shoes were really tight going on. One side went on snug, but once I got all the way in it was fine. The other side on the other hand went on tight all the way and once I got it on it was so tight I could not turn the rotor at all. My question is what did I do wrong. I have read a few threads and people are saying that there is no adjustment on the cable at all. Like I said before I had the star adjuster all the way in and the brake lever down all the way? Can anyone help me out on this one. Thanks
yfzandy is offline
post #2 of 10 Old 04-21-2011, 04:50 AM
tavic
2010 JK Wrangler
My past experiences with drum brakes, I've always set them with some drag to "burn" them in a bit which would give you nice tight e-brake. This could be the same idea being used from the manufacturer, especially since you have everything adjusted to its max.
tavic is offline
post #3 of 10 Old 04-21-2011, 10:09 AM Thread Starter
yfzandy
I just don't understand why one side is fine and the other is tight when they are both run off of the same length of cable and same lever. I paid $150.00 Cdn. for them, so I don't really want to wear them out that quick. Thanks for the reply, but is there anyone else that has any thoughts on this.
yfzandy is offline
post #4 of 10 Old 04-21-2011, 10:19 AM
plk457
There is adjustment at both rotors for both e brake tensions...if that makes sense. The star adjuster that you mentioned did you do teh same thing for both sides? If not that should be your problem.
plk457 is offline
post #5 of 10 Old 04-21-2011, 11:09 AM Thread Starter
yfzandy
I ended up reusing the adjusters and I did make sure both were turned all the way in. I had to clean them up, but they are both in good shape.
yfzandy is offline
post #6 of 10 Old 04-22-2011, 08:09 AM
Unknown303
Does anyone have pictures of the adjusters for the ebrake? Mine ultra loose, and I need to dial them in a lot I imagine.
Unknown303 is offline
post #7 of 10 Old 04-22-2011, 09:15 AM
ronjenx
ronjenx's Avatar
Go here to see how the lever works.
http://www.jeepforum.com/forum/f96/o...study-1061720/
The lever gets a new grip on the cable every time you use it.
Here is a pic of the adjusters.
Here is a pic of the access to the adjuster without removing the drum. A little more difficult to do, but can be done.
ronjenx is offline
post #8 of 10 Old 04-22-2011, 01:18 PM
Unknown303
Thanks! I think my handle is still in good working order, I just have to crank it way to far to get the brake to engage... Might have to replace the pads now that I think of it.
post #9 of 10 Old 04-25-2011, 07:00 PM Thread Starter
yfzandy
Is there anyone out there that has replaced their own rotors and e brake shoes? I installed mine and there is one side that is still getting hot after I installed it and the adjuster is all the way in. I have read that there is no adjustment on the cable, so what have I done wrong.
yfzandy is offline
post #10 of 10 Old 04-25-2011, 07:06 PM
spedly
2011 JK Wrangler
Do you by chance have a lift on the jeep and the e-brake cables still attached to the body? I did shoes on a local guy's because when he lifted the cables got pulled tight and were dragging the shoes all the time.
Poser Jeep.
spedly is offline
E brake shoe adjustment question. Ezalycasaid TJ Wrangler Technical Forum 5 02-19-2011 01:53 AM
Re-install Emergency brake handle? Easy Question (probably) bikepharmer YJ Wrangler Technical Forum 13 10-13-2010 10:34 PM
8.8 Parking Brake Shoe - Problem linusb YJ Wrangler Technical Forum 7 10-10-2010 12:30 PM
No Emergency brake! monica02190 YJ Wrangler Technical Forum 11 03-22-2010 08:42 AM
Brake Pads & Shoe recommendations? BNovak TJ Wrangler Technical Forum 2 07-27-2004 05:05 AM
