Electronic Sway Bar Disconnect?? - JeepForum.com
post #1 of 5 Old 02-19-2014, 10:40 PM Thread Starter
MyJKU14
2014 JK Wrangler
I found a module for the electronic sway bar disconnect but it does not include the wiring harness. Does this look like the part that I need??
http://www.quadratec.com/products/52...FY1FMgod-xcAPQ
Also, do I need to have the dealership do anything to hook it all up?
'14 JKU
'05 LJ Rubicon (husband's)
Colorado Jeep Club #281
Past Jeeps: '02 WJ Overland, '02 WJ Limited, '08 KK Sport
MyJKU14 is offline
post #2 of 5 Old 02-20-2014, 09:14 AM
RockyClymer
RedRock4Wheeler
RockyClymer's Avatar
That is one way of doing it, you would also need the OEM switch installed and would need the ECM reflashed to recognize the installation...another way, but not factory look, would be to wire the disconnect separately from ECM with fuse and switch unit...not sure I have seen a specific thread or know of anyone actually doing that though.
08 JK 23S - Colorado Jeep Club No. 204
Too much to list - see my profile for details on build
16 JK Rubi with all the trimmings
NRA Life member
"It takes a special kind of stupid to believe criminals will follow gun laws."
I do not consider myself a smartass. I point out the obvious, search for the truth, and speak fluent sarcasm. I am, by experience, an accomplished curmudgeon.
RockyClymer is offline
post #3 of 5 Old 02-20-2014, 10:26 AM
Brut4ce
2010 JK Wrangler
This.....
Just wire a fuse able link with a lighted toggle and do t worry about all the stuff...there should be a primary wire and a switch wire....if you can find a schematic or if you know someone with a Rubicon test the wires when disengaged and engaged ....
"There's plenty of time to rest when your dead or knocked out!"
BUILT FOR THE ROCKS BUILD
Brut4ce is offline
post #4 of 5 Old 02-20-2014, 08:46 PM
Maertz
2009 JK Wrangler
i run mine from a switch, but i used the lockers relays as a bypass. i would assume the relays are in the jks without the lockers, but really not sure on that. i suppose you could easily add a relay for each if needed.
Wishing I Wasn't Part Of The 'JK' Crowd...
Maertz is offline
post #5 of 5 Old 02-21-2014, 06:53 PM
2jk1cjtj
I got two jks one with lockers and one without and they only put the relays in if you got the lockers.
2jk1cjtj is offline
