Electronic sway bar disconnect - JeepForum.com
post #1 of 30 Old 07-11-2010, 05:19 PM Thread Starter
graham123488
2010 JK Wrangler
This is my first jeep. I have a 2010 wrangler sport. What is the sway bar disconnect and what is it good for? I have been mud riding all my life and ive never had anything that you would disconnect the sway bar on. Im just use to scouts, fords, nissan trucks.
graham123488 is offline
post #2 of 30 Old 07-11-2010, 05:23 PM
RockyClymer
RedRock4Wheeler
RockyClymer's Avatar
If you have the Sport - it does not come with an electric sway bar disconnect unless it was put on as an option. When you disconnect the sway bar (actually an anti-sway bar) it allows the front axle to articulate to a great degree and maintain wheel contact with the surface.
08 JK 23S - Colorado Jeep Club No. 204
Too much to list - see my profile for details on build
16 JK Rubi with all the trimmings
NRA Life member
"It takes a special kind of stupid to believe criminals will follow gun laws."
I do not consider myself a smartass. I point out the obvious, search for the truth, and speak fluent sarcasm. I am, by experience, an accomplished curmudgeon.
RockyClymer is offline
post #3 of 30 Old 07-11-2010, 05:26 PM Thread Starter
graham123488
2010 JK Wrangler
so unless im doing alot of rock climbing its not something i will really need is it
post #4 of 30 Old 07-11-2010, 06:03 PM
MilitaryJK4455
2010 JK Wrangler
You can manually disconnect your swaybar links anyway... Takes five seconds, and its actually better than the electric anyway, just not as convenient.
MilitaryJK4455 is offline
post #5 of 30 Old 07-11-2010, 06:04 PM
MilitaryJK4455
2010 JK Wrangler
Ya'll know they are puttin these things on the new dodge trucks now?
post #6 of 30 Old 07-11-2010, 06:06 PM
anymanusa
somebody post a picture of this thing. I figured it would come on my '05 rubi, but I guess they didn't have them at that time. I'll just get the JKS disconnect for $150.
anymanusa is offline
post #7 of 30 Old 07-11-2010, 07:07 PM
allibaster
Here's the Mopar PDF: http://moparestore.trademotion.com/m...s/K6860116.pdf
It's not even for rock climbing, unless you subscribe to Jeep marketing. Basically, it allows a Jeep Rubicon to disconnect your front sway bar with the push of a switch. It's kinda like electronic scissors, or something else equally lame or lazy. Manual disconnects are just a good, probably better, since they're not controlled by an ECU.
Manual disconnects: $125
Remote disconnects: $1,455 (http://jeepparts.mopar.com/jeep/wran...cessories.html)
allibaster is offline
post #8 of 30 Old 07-11-2010, 07:47 PM
MilitaryJK4455
2010 JK Wrangler
Manual disconnects are called "two wrenches" and you can get them for under 30 bones....
Quick disco's are about 125 though... And they are just something else for convenience.
post #9 of 30 Old 07-11-2010, 07:56 PM
ZeroGravity
Lol well said man.
Electronic sway bar disconnects. Now that is something right there.
91 YJ
98 XJ
2 door love
The U.S. Army vaguely envisioned something bigger than a motorcycle, smaller than a truck, and undaunted by the most difficult terrain.
ZeroGravity is offline
post #10 of 30 Old 07-11-2010, 08:23 PM
anymanusa
Remote disconnects: $1,455 (Jeep Wrangler Accessories - The Official Jeep Parts and Accessory eStore offered by Chrysler)
thanks. i figured it may look like that, but I wasn't sure if they may have had some solenoid operated pins either.
Yeah, I'm not going to be going electric anytime soon.
post #11 of 30 Old 07-12-2010, 08:55 AM
mandalayjim
I installed the JKS quicker disconnects three days ago. Because these have 4 grease fittings for the pivot points when connected I would advise that you have rubber gloves when disconnecting or reconnecting on the trail. It's going to get messy.
mandalayjim is offline
post #12 of 30 Old 07-12-2010, 09:29 AM
JIMBOX
They were designed over 50 years ago, but the cost and use wasn't realised till recently and they are an added convenience, but
There are cases where -BAM- all of a sudden the ability to free you front swaybar can be a life saver and either forgetting to manually release your swaybar, at the start, or not being able to---
The electronic can be a life saver, especially in search and rescue !!
They're kinda like e-hubs Vs manual hubs !!
JIMBO
Yellow Jeep No. 683
--YA GOTTA HAVE CLASS--
JIMBOX is offline
post #13 of 30 Old 07-12-2010, 09:50 AM
troy32323
2010 JK Wrangler
Just out of curiousity... What would happen if you left the antisway bar disconnected all the time?
Would it be undrivable on the road? or just not handle quite as well?
troy32323 is offline
post #14 of 30 Old 07-12-2010, 09:55 AM
Joshhamburger
depending on how you drive, it could add to the amount of body roll that you feel. A lot of guys will disconnect them completely, I took mine front bar completely off my ZJ and couldn't really tell a difference in ride quality.
Joshhamburger is offline
post #15 of 30 Old 07-12-2010, 10:00 AM Thread Starter
graham123488
2010 JK Wrangler
Since my 2010 jk don't have this what would be the best and cheapest way for me to beable to disconnect mine with buying the electric one?
Electronic-disconnecting front sway bar or Active Sway Bar System vgullotta JK Wrangler Technical Forum 16 08-30-2010 07:39 AM
Lifting with Electronic Sway Bar Disconnect. charvey9 JK Wrangler Technical Forum 2 08-29-2009 08:56 AM
Electronic Front Sway Bar Disconnect = Fun roc4117 JK Wrangler Technical Forum 8 02-18-2008 05:15 PM
Lift with electronic front sway bar disconnect? roc4117 JK Wrangler Technical Forum 2 09-06-2007 08:02 AM
Rubicon Electronic Sway Bar Disconnect JK_Jeep JK Wrangler Technical Forum 6 05-26-2007 09:50 AM
