Electronic Stability Control - JeepForum.com
post #1 of 12 Old 01-21-2014, 05:45 PM Thread Starter
bubbyjeep1
This is a nightmare...
I have a 2013 jku 5000 mi, 4" lift, 35's, and *3.23* gears
I went offroading for the first time on a friend's place where there were some hills, some small drops, nothing serious i thought. I never turned off the ESC (I don't know if i should have or not). At the very start, i went into a hole too fast, got stuck and four wheel drive got us out. I had to put it in four wheel drive a couple others times to get me out of a hole that i went into much slower. I got cocky and did a couple donuts (I am a dumb kid and I know). Sure enough the ESC (Electronic Stability Control) warning light started flashing and it hasn't gone off since. It is the only light on. In the manual it says something along the lines of "after driving several miles and the light remains on, take it to the dealership." Since then I've driven probably 50 mi.
I know I ought to take it by the dealer but my question is what should i be expecting? How serious? Is this the 3.23's coming back to haunt me? Is it possible there is no malfunction and the light will turn off any day now?
Any and all feedback is much appreciated.
bubbyjeep1 is offline
post #2 of 12 Old 01-21-2014, 06:06 PM
RockyClymer
RedRock4Wheeler
RockyClymer's Avatar
You are going to have to give this group a lot more info for a meaningful answer. Make of lift, parts included, etc. An why in hell are your trying to run 35s with 3.23 gears? Did you mean 3.73 or something else?
08 JK 23S - Colorado Jeep Club No. 204
Too much to list - see my profile for details on build
16 JK Rubi with all the trimmings
NRA Life member
"It takes a special kind of stupid to believe criminals will follow gun laws."
I do not consider myself a smartass. I point out the obvious, search for the truth, and speak fluent sarcasm. I am, by experience, an accomplished curmudgeon.
RockyClymer is offline
post #3 of 12 Old 01-21-2014, 06:28 PM
Prot
Prot's Avatar
2014 JK Wrangler
Press the button twice.
2014 JKU Copperhead Pearl
Too many mods to list. Too awesome to sell.
Prot is offline
post #4 of 12 Old 01-21-2014, 06:44 PM
tjkj2002
2002 KJ Liberty
Keep it in 4wd when offroad,4low is best.
tjkj2002 is offline
post #5 of 12 Old 01-21-2014, 08:02 PM Thread Starter
bubbyjeep1
I am tracking down each specific part now
post #6 of 12 Old 01-21-2014, 09:01 PM
222Doc
222Doc's Avatar
sounds like a wire might have been pulled from a hub sensor. might want to check those.
222Doc is offline
post #7 of 12 Old 01-21-2014, 09:04 PM
michiganmaveric
Got Beer?
michiganmaveric's Avatar
2011 JK Wrangler
You can try disconnecting the battery to see if it will clear. If disconnecting the battery does not clear the light take it to the dealer. I don't think it has anything to do with your gears. Mine 2011 light will come on sometimes and not go out until I stop and shut the eng off and restart, dealer says probably a wheel sensor malfunction. Try the battery and see what happens.
Previous Jeeps: 84 CJ7 (A True Jeep), 2000 XJ (163,000 Miles/Totaled (Pictures of wrecked Jeep in gallery)), 2004 WJ (parting out die to major electrical issues)
If you don't have time to do it right the first time, how do you have time to do it over.
Lifetime member #13
lifetime member/airforce26yrs
2011 Tango/Mango JKU
michiganmaveric is offline
post #8 of 12 Old 01-21-2014, 09:10 PM
AaronVZ
Check the wheel speed sensors. My guess is one got damaged.
AaronVZ is offline
post #9 of 12 Old 01-21-2014, 09:59 PM
Dirtay_Harry
Try holding down the ESC button for 5 sec til you hear a beep then turn it back on
Dirtay_Harry is offline
post #10 of 12 Old 01-21-2014, 10:04 PM
SubAtomicGenius
2011 JK Wrangler
Or you might have simply bent up something up front or knocked your steering out of alignment.
SubAtomicGenius is offline
post #11 of 12 Old 01-22-2014, 12:22 AM
ancientspear
Are all 4 tires at reasonably similar pressures? If they are out of wack it could trip the ESP. Easy thing to check and address if it is the case good luck!
Also wash everything down real good. Long shot, usually only helps with break indicator light issues after the trail but if you need to bring it in some place, you'll be glad you did.
ancientspear is offline
post #12 of 12 Old 01-22-2014, 10:09 AM
JoonHoss
2011 JK Wrangler
My first thought was alignment as well. Who did the suspension install? What parts did you change/upgrade? Was everything retorqued after initial install?
Hoss
"Gimme three gallons of low lead; two hot dogs and a strawberry soda..."JGW
JoonHoss is offline
