Electrical Dunce - Help needed with SPOD and Arb Compressor - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > Electrical Dunce - Help needed with SPOD and Arb Compressor
1987-1995 Jeep Wrangler Turn Signal Switch (Wells)1987-1989 Jeep Wrangler Brake Pad & Rotor Kit Semi-Met50" LED CREE Light Bar Pair With Wiring Kit
Unread 06-14-2015, 08:08 AM   #1
boydmc85
Yesterday I installed my SPOD and Arb 12 Volt Air Compressor (CKMA12). Physically they are installed but the electrical connections baffle me (or I'm over thinking it).
My purpose for this setup is ONLY for the onboard air. I will not be installing air lockers on this jeep.
In addition to the massive Arb wiring harness, I also have the Arb harness from SPOD. I do not believe that I need to wire the Arb to the battery as this unit only pulls 26 Amps and the spod should support up to 30 amp.
How do I wire this up to make it work?
Any help would be greatly appreciated.
boydmc85 is offline   Reply With Quote Quick reply to this message
Unread 06-14-2015, 09:58 AM   #2
Vetteguy
the sPod has the rely built in so all you need to do is wire the + & -( from the compressor) to the sPod with the proper fuse.
Vetteguy is offline   Reply With Quote Quick reply to this message
Unread 06-14-2015, 12:43 PM   #3
boydmc85
But how about the pressure switch? I can understand running the power straight from the compressor too the SPOD but do I need to do anything with the pressure switch?
Unread 06-14-2015, 08:41 PM   #4
Vetteguy
OK, I looked into it a little more. You need to run the + of the compressor to the + of the sPod. then run the - of the compressor into one side of the pressure switch then the other side of the pressure switch to the - of the sPod.
Unread 06-15-2015, 04:59 AM   #5
boydmc85
Awesome. Thank you for your help. I greatly appreciate it. I'll confirm how this works out in the next day or so when I get a chance to do it.
Unread 06-15-2015, 04:58 PM   #6
ExpoJeep
You can't run the circuit through the pressure switch as that switch is rated at only 20 amps. CKMA12 is also fused at 40 amps with a start up current draw (for a few milliseconds) that can approach 100 amps when restarting under load. The easiest way to do the job is to control the ARB harness with the Spod output. You only need the ARB underhood harness and not the dash harness. Hook up the big black and red leads to the battery from the ARB harness. Plug in the included relay into the yellow plug and connect the red and blue wires to the pressure switch on the compressor (doesn't matter which way). Next plug in the compressor motor to the plug with the big red and black leads in it. Lastly find the 4 loose wire on the ARB harness (black, red , green, yellow) and connect the red one to the output circuit off your S-pod. That will turn the compressor on and operate it as designed via the pressure switch and relay in the ARB harness. Running directly off the Spod is pushing it for current capacity and performance of the compressor is likely to suffer as a result along with possibly damaging your Spod.
ExpoJeep is offline   Reply With Quote Quick reply to this message
Unread 06-15-2015, 08:04 PM   #7
PhatBasturd
Got chiggers?
PhatBasturd's Avatar
1976 CJ7
^^This.
PhatBasturd is offline   Reply With Quote Quick reply to this message
Unread 06-16-2015, 08:34 AM   #8
jwmbishop
Accidental Obfuscator
jwmbishop's Avatar
2011 JK Wrangler
Tie back black, green and yellow (as unused)?
J Wm Bishop EA, ASADE
The world is made from rocks and mud. Maturity is knowing when to stop playing in the mud...
jwmbishop is offline   Reply With Quote Quick reply to this message
Unread 06-17-2015, 06:51 AM   #9
boydmc85
As much as I was trying to avoid using the huge ARB harness, more to just keep everything very clean looking, your comments make a tremendous amount of sense. The last thing that I want to do is burn up the SPOD and/or the compressor. Thank you for the detailed write-up along with others in this thread. I can finally make sense of all of the connectors.
Happy Wheeling!
Unread 06-18-2015, 12:49 PM   #10
ExpoJeep
If you get lost with any of the wiring on the ARB side just ring them and ask for the Tech Dept. The guys there will walk you through the process as needed.
Unread 06-22-2015, 05:41 AM   #11
boydmc85
Arb with SPOD install
I'm DONE. I used not only the "long" ARB provided harness but also the SPOD "Arb harness" that I purchased extra and everything came out great. I will say that I shortened the ARB harness where I could (mostly around the battery connection I took off a good 16 inches of unneeded harness). I still ended up with a coil of wire near the SPOD itself. Perhaps one day I'll cut that up and make new connectors for it.
Thank you everyone for your help. Now on to the next project. Happy Jeeping!!!
Unread 06-22-2015, 08:15 AM   #12
IVLIVS
Spod
Call the company at SPOD they will be glad to answer any ?s
IVLIVS is offline   Reply With Quote Quick reply to this message
