Electric windows stop working until key turned??? - JeepForum.com
post #1 of 8 Old 09-22-2012, 08:06 AM Thread Starter
jeeperscrXj
Hello,
The electric windows on my 2007 JK will suddenly stop working in one or the other direction - up or down. When I pull over, shut the vehicle off, then re-start it, they work fine again. In two instances to test this, I pulled over just to shut off and restart the vehicle; the vindows immediately worked fine. I am sure this is a computer issue as the door locks sometimes decide to lock at odd and inconsistent times. Can this be simply resolved at home?
Thank you for your help,
JK Justin with XJ too
jeeperscrXj is offline
post #2 of 8 Old 09-22-2012, 09:37 AM
rirrgang
You may want to disconnect your battery for 20 or 30 minutes and see if that helps. If not, you may need to have it flashed.
-Rick
07 Sahara Unlimited
rirrgang is offline
post #3 of 8 Old 09-22-2012, 09:55 AM
jwmbishop
Accidental Obfuscator
jwmbishop's Avatar
2011 JK Wrangler
ditto. Reset the computer first. 30 second disconnect is really all it takes - but this is always a good time to clean, inspect and do other PMs while its disconnected, so usually when I reset its for at least 20 minutes...
J Wm Bishop EA, ASADE
The wagon should, of course, be as light as possible, but strength should not be sacrificed to lightness, for on any but the regularly traveled roads, the wagon will get many a
jwmbishop is online now
post #4 of 8 Old 09-22-2012, 11:52 AM
Vin
Also have the batery tested.
Vin is offline
post #5 of 8 Old 09-22-2012, 05:22 PM
68cupe
My 2008 JKU does this every now and then, too. Battery is within a year old new and it still does it. It is the switch itself that is doing it. My original switch LEDs in them went out and mine started doing it. Replaced the switch and never had the issue until these LEDs went out now. I just deal with it best I can. Doesn't do it too often so no harm for me.
68cupe is offline
post #6 of 8 Old 09-22-2012, 06:47 PM
ronjenx
ronjenx's Avatar
Originally Posted by jeeperscrXj View Post
Hello,
The circuit breaker (CB 1) that protects the window circuits/motors will disconnect when overloaded, and will self-reset only after the Jeep is shut off.
I would look for a reason the circuit is overloading.
Do the motors sound like they are straining or bogging down?
ronjenx is online now
post #7 of 8 Old 09-22-2012, 07:05 PM
68cupe
Mine dont. I keep some lithium grease on them every once and a while to keep strain off of motors.
68cupe is offline
post #8 of 8 Old 10-06-2012, 08:44 AM Thread Starter
jeeperscrXj
Thanks everyone for your comments. These are good suggestions. I will do as suggested and give it a try. Justin
Plastic windows turned white White_Wrangler Wrangler General Discussion 4 08-23-2010 01:50 PM
No electric when key is turned... MikeTheVike TJ Wrangler Technical Forum 5 07-19-2010 11:19 AM
Windows Stop working? 08rubinewb JK Wrangler Technical Forum 10 07-03-2009 07:31 AM
ARB Locker working in cold weather. Compressor keep turned on, but not working hard Sparty TJ Wrangler Technical Forum 3 02-01-2009 06:31 PM
Electric fan wont stop! Anti-bling TJ Wrangler Technical Forum 18 11-19-2007 05:02 PM
