EGR system - JeepForum.com
post #1 of 6 Old 03-15-2010, 08:00 PM Thread Starter
Jos360
2010 JK Wrangler
EGR system
I have question about my JK Unlimited.
Is it a good thing to remove the EGR system from this car? I worked on a lot of diesels on which i've seen what EGR does. I have always removed the system on the diesels i owned. But maybe it's different for gas cars?
I always noticed a more smooth running engine and an improvement on gas mileage.
Since i see no EGR-delete kits for these 3.8 engines, i assume that EGR doesn't really do a bad job? Of course making your own EGR-delete is very easy on these things, but i would wonder if the computer freaks out if i do that or that it's just plain useless.
Please discuss
Jos360 is offline
post #2 of 6 Old 03-15-2010, 08:28 PM
ronjenx
ronjenx's Avatar
In order to make a kit for the JK, you would have to know what the ECM looks for to know the system is working.
I have not seen much in the way of EGR delete kits for gas engines. Maybe the need for it is not there because it's not as bad for gas engines as it is for diesels.
Regarding what you said about EGR being bad for diesels, I agree, but not as much since ULSD became available.
I got into the computer on my '01 VW TDI and turned the EGR down to the legal low limit. Between that and ULSD, the intake is staying very clean.
I wouldn't delete EGR because it is illegal to do so. It's probably not enforceable, but I still wouldn't do it.
Like I said, you would have to know what the JK ECM looks for when it turns EGR on, so you can fool the computer.
ronjenx is offline
post #3 of 6 Old 03-15-2010, 08:32 PM Thread Starter
Jos360
2010 JK Wrangler
So your opinion is that the ECM would freak when it sees that the EGR is not connected anymore? Or do i misunderstand you?
It being illegal is not really my worry. It's more an issue that i have no idea how bad EGR is for a gas engine.
Jos360 is offline
post #4 of 6 Old 03-15-2010, 08:48 PM
ronjenx
ronjenx's Avatar
Yes, that is my opinion. I strongly believe the JK computer looks for evidence the EGR is actually working, but I don't know it for a fact. It seems I read it looks for a slight roughness or a change in how it runs, but I can't find that reference.
EGR bad for a gas engine? Maybe a slight reduction in performance, but not the clogged intakes like the old diesel fuel would clog a diesel intake.
Edit to add:
Found it: The EGR monitor calculates the difference in engine roughness from the EGR off condition to the EGR condition. This engine combustion stability difference as measured by engine roughness is the measure of a functional EGR system.
You may get this code:P0401-EGR SYSTEM PERFORMANCE
ronjenx is offline
post #5 of 6 Old 03-15-2010, 08:57 PM Thread Starter
Jos360
2010 JK Wrangler
Maybe i'll disconnect the EGR connector tomorrow morning (after i'm at work ) to check if it gives me an error message.
I guess that a gas engine burns a little cleaner that the old diesels would, but if it would improve mileage by a 10th of a mile per gallon, it would be worth keeping the engine clean i guess...
Jos360 is offline
post #6 of 6 Old 03-15-2010, 08:59 PM
ronjenx
ronjenx's Avatar
See what I added to my previous post.
ronjenx is offline
vacuum system hoses all hooked up but system doesnt work snowcrawlr619 YJ Wrangler Technical Forum 8 12-28-2009 07:52 AM
hsa system randy lewis Wrangler General Discussion 1 08-12-2009 08:19 AM
Is the a/c system the same for a 4 cyl and a 6 cyl? mexdealer YJ Wrangler Technical Forum 4 07-22-2009 09:38 AM
A/C system, '97 TJ JStMarie TJ Wrangler Technical Forum 0 05-21-2009 01:21 PM
PA system AK1904 YJ Wrangler Technical Forum 1 12-29-2003 04:06 PM
