Easy Switched Power Source - JeepForum.com
 1Likes
post #1 of 35 Old 08-16-2011, 07:49 PM Thread Starter
ronjenx
ronjenx's Avatar
If your TIPM (fuse box) is set up like my 2008 is....
Here is a way to get switched power from the fuse box. It's easier than installing wires in the connector under the TIPM, although not quite as clean an install.
The fuse tap came from Advance Auto, Buss catalog # BP/HHH. It is rated for 10 amps, so that will be the max fuse you should put in it.
For use as outlined, only the top fuse position can be used, as the bottom fuse would send power to an empty wire socket in TIPM connector C6.
Headdancer likes this.
ronjenx is offline
post #2 of 35 Old 12-15-2011, 11:49 AM
MKE_Mike
2016 JK Wrangler
subscribe to be able to come back here... thanks for the great info....
MKE_Mike is offline
post #3 of 35 Old 12-15-2011, 01:10 PM
tslewisz
2010 JK Wrangler
^^^^^ what he said ^^^^^^^^^
tslewisz is offline
post #4 of 35 Old 12-15-2011, 05:13 PM
SilverStreaker
good info, thanks!
My Jeep - 2012 Wrangler Unlimited Sport S
My Wife's Jeep - 2007 Grand Cherokee - only mod - K&N Cold Air Intake system
SilverStreaker is offline
post #5 of 35 Old 12-29-2011, 04:27 PM
goldenglory18
This is stupid good. Thanks a bunch for sharing!
Gone and I dont miss it at all - 2011 JKU
goldenglory18 is offline
post #6 of 35 Old 12-29-2011, 04:42 PM
SubAtomicGenius
2011 JK Wrangler
Wonder if I can change the wiring for the stereo using this info - I'll play MP3's with the key in the ACC position, then when I go to start the Jeep, the damn stereo switches back to the radio while the USB port re-boots. What a PITA!
SubAtomicGenius is offline
post #7 of 35 Old 12-29-2011, 05:02 PM
Mol
Disclaimer: I'm Polish
Mol's Avatar
At least you can play MP3s through your USB
Thanks for sharing, Ron
Mol is offline
post #8 of 35 Old 12-29-2011, 11:51 PM
Sykd4MyWaggy
Woot woot, great pictures! Thanks
07' JKU Sahara Jeep Green Metallic
Stock for now
Coming Very soon
35" Cooper Discoverer stt's & 3.5 RK Mid Arm Lift
Sykd4MyWaggy is offline
post #9 of 35 Old 12-30-2011, 03:15 AM
mrsig
This is a great right up!! Thanks.
07 JKU To see mods & my Jeep in Action @
CEO of Black Sheep 4x4s
Member of CCJ, White Jeep Club Member #137.
mrsig is offline
post #10 of 35 Old 07-24-2012, 09:32 AM
SKIQUATTRO
questions...why is the Tap in different positions in pics 3 and 4? in #3, the tap wire is running towards the outside of the box, where in #4, its running towards the interior of the box
SKIQUATTRO is offline
post #11 of 35 Old 07-24-2012, 09:49 AM Thread Starter
ronjenx
ronjenx's Avatar
That's explained in the picture narratives. 3 is in a slot that is hot in RUN only. 4 is in a slot that is hot in accessory and run.
They have to face different ways to have clearance for the red wire.
ronjenx is offline
post #12 of 35 Old 07-24-2012, 09:52 AM
PhatBasturd
PhatBasturd's Avatar
1976 CJ7
He is just showing you 2 different places to tap:
#3 will be hot when the key is in the RUN position
#4 will be hot when the key is in ACC or RUN position.
EDIT: Doh! RONJENX beat me to it.
PhatBasturd is offline
post #13 of 35 Old 07-24-2012, 10:50 AM
SKIQUATTRO
got it....thanks
post #14 of 35 Old 07-24-2012, 11:47 AM
WhiteJK
2009 JK Wrangler
Stupid question. How many relay switches can I activate(share) with this one line. Sorry, I'm electronics impaired. Thanks.
WhiteJK is offline
post #15 of 35 Old 07-24-2012, 12:00 PM Thread Starter
ronjenx
ronjenx's Avatar
Find out the relay coil draw, and go from there. The setup shown is rated at 10 amps.
ronjenx is offline
Where is a 12v switched ignition source gittman140 TJ Wrangler Technical Forum 8 10-29-2013 04:10 AM
Looking for Switched Power Source to Mirror - Help folkxrock JK Wrangler Technical Forum 3 08-15-2011 08:05 PM
Need a Key switched constant 12V source. RedneckYJ YJ Wrangler Technical Forum 6 10-04-2009 03:39 PM
Switched 12v source Jchris TJ Wrangler Technical Forum 3 05-08-2008 02:27 PM
Switched Power Source ErikAtTheW TJ Wrangler Technical Forum 2 08-31-2005 08:01 AM
