DW and your Front End. - Page 5 - JeepForum.com
post #61 of 67 Old 09-25-2013, 07:31 PM Thread Starter
JTPhoto
JTPhoto's Avatar
Originally Posted by wb2510
I took the measurements on the axle and the measurements are the exact same on both sides. So the front axle is square. The report on my camber states that both sides are at -0.7 which is a 1/2 degree off. As I recall now the dealer wanted $800 to correct it. I didn't think a half of a degree was worth that amount unless they could guarantee it would stop DW which they couldn't of course. In fact they acted like they never heard of such a thing before!
Cool, now we know that the front is OK. If you are interested you could try the rear diff as well.
As for camber there are 3 ways to fix that and they are
1 bend the end of the axle tube. ( not advised)
2 cut off the "C" and reweld ( this can be used to correct caster as well).
3 offset ball joints. (Cheapest and most reasonable fix)
I agree with Your decision to not worry about 1/2 degree.
What were your Caster numbers?
^^Jeff^^
2008 Black and Khaki Sahara Unlimited Trax-Lok rear diff. 3.5" Rock Krawler fr springs, rear TeraFlex 2.5 BB, D44HD/J8 w/ OX locker and RCVs, 37x12.50x17 Pitbull Rockers on ProComp 2635 Predator Alloys, AEV Prem Bumper, Smitty X2O 12K ETC..
JTPhoto is online now
post #62 of 67 Old 09-25-2013, 07:56 PM
wb2510
Originally Posted by JTPhoto
Cool, now we know that the front is OK. If you are interested you could try the rear diff as well. As for camber there are 3 ways to fix that and they are 1 bend the end of the axle tube. ( not advised) 2 cut off the "C" and reweld ( this can be used to correct caster as well). 3 offset ball joints. (Cheapest and most reasonable fix) I agree with Your decision to not worry about 1/2 degree. What were your Caster numbers?
The Castor angles were not on the Dealer's report. I'll have to give them a call to see if they have a record of it.
2008 JK Wrangler Unlimited X
2005 KJ Liberty
1994 YJ
wb2510
Late Jeep Club #3
wb2510 is offline
post #63 of 67 Old 09-28-2013, 08:46 AM Thread Starter
JTPhoto
JTPhoto's Avatar
So let's now throw this into the mix... Thursday all 4 balljoints changed, uppers badly worn, lowers bad enough. They are now replaced with a full set Synergy balljoints. So here's the recap... 146,000 has NEVER had DW
Trackbar changed still had all 14mm bolts, sloppy and wallowed holes.
All 4 Balljoints now changed (worn out)
All original control arms and bolts still installed. All original tie rods and draglink.
So the mystery continues.
^^Jeff^^
post #64 of 67 Old 09-28-2013, 10:43 PM
Psycho-X-Jeep
2009 JK Wrangler
I think u need to go buy some lottery tickets!
Psycho-X-Jeep is offline
post #65 of 67 Old 09-29-2013, 07:22 AM Thread Starter
JTPhoto
JTPhoto's Avatar
LOL ... I couldn't win a dollar in a lottery if my life depended on it.
^^Jeff^^
post #66 of 67 Old 12-24-2013, 03:15 PM
wb2510
FYI - Just received a letter today from Ford Motor Co. regarding the similar problem they are having with what they are calling "shimmy" on some of their trucks. They recently released a "Special Field Action" on the issue. You can probably find it on their website if you look for SFA "09L02". Interesting, but like Chrysler they don't seem to get it. Tire pressure is not going to fix what is going on.
2005 KJ Liberty
1994 YJ
wb2510
Late Jeep Club #3
wb2510 is offline
post #67 of 67 Old 12-24-2013, 03:19 PM Thread Starter
JTPhoto
JTPhoto's Avatar
Not surprising at all.. Thanks for the update..
^^Jeff^^
