Dual tops question - JeepForum.com
post #1 of 11 Old 09-29-2006, 09:10 AM Thread Starter
jkunlimited07
Dual tops question
I'm interested in purchasing an 07 Wranger Unlimited with Dual Tops. I'm getting a little anxious and my dealer has the one I want without the dual tops (it only has the soft top). He said that he could order the hard top and have it installed for me.
If I were to do that, would it be the SAME EXACT setup as purchasing a vechicle with the dual tops straight from the factory? He said that it would be, but I wanted to be absolutely certain before making such a big purchase. I did call Jeep directly but they really couldn't answer the question. Thanks for your help.
jkunlimited07 is offline
post #2 of 11 Old 09-29-2006, 09:21 AM
NapalmEnema
Junior Member
I don't see how it wouldn't be, the hard top is fully removeable, so it should be something you can put on later or store in your garage as needed?
Good luck with your purchase!
NapalmEnema is offline
post #3 of 11 Old 09-29-2006, 09:38 AM
Rocky529
Rocky529's Avatar
It should be the same. The hard top just bolts on without any extra pieces. Atleast that is how it is on the YJ and TJ.
Silver Metallic finish with black dual tops - Dana 44 Rear
2.25" Suspension Lift with Old Man Emu Shocks
Performance Accessories 1" Body Lift
Daystar 1" Motor Mount Lift
Spidertrax 1.25" Wheel Spacers - 32"x11.5" MT/R Tires
Rocky529 is offline
post #4 of 11 Old 09-29-2006, 09:51 AM
Hoghead00
Not sure about the JK, but on the TJ's, the body is prewired for the hardtop for the rear defrost and the windshield washer for TJ's with dual tops or hardtops only. You would just want to be sure they include the wiring loom. I assume they would, but......
2004 Jeep Wrangler Rubicon
Hoghead00 is offline
post #5 of 11 Old 09-29-2006, 10:00 AM
IGZLBR
2002 XJ Cherokee
around here, in Canada, if I have a customer that wants a hard top after the fact, it usually cost 3 times more than if it were a factory installed option. Perhaps it different for US Mopar, but it is always, way, way cheaper to get the option/packages you want from the factory. This goes for most if not all parts installed after the fact by your dealer (at our local dealers here anyways).
Simon Scott
Langley Chrysler
Current Rides: 1993 Grand Wagoneer, 1992 Cherokee
Past: 1982 CJ-7, 1986 CJ-7, 1994 YJ
IGZLBR is offline
post #6 of 11 Old 09-29-2006, 10:17 AM
tacopeland
I did that with my '97 Wrangler. It came with a soft top and a year later i bought the hard top and full doors from the dealer. They installed the wiring an everything.
tacopeland is offline
post #7 of 11 Old 09-29-2006, 10:54 AM
mikejwil
mikejwil's Avatar
I would get something in writing saying that you can get the hard-top afterwards for the same price as the factory option.
CURRENT - ordered 10/26, home 1/14
2008 JK Unlimited,3.8L,6-spd,limited slip,dual tops,tow pkg,all power
SOLD
1999 XJ 4.0L,AX15,NP231,D30HP,C8.25
STOLEN
1993 XJ 4.0L,AW4 ,NP231,D30HP,C8.25:::C4X4 THB:GDI 3row:K&N:JKS QD: Dynomax#17340:MagnaflowCat#23221:Surco 45x60
mikejwil is offline
post #8 of 11 Old 09-29-2006, 01:24 PM Thread Starter
jkunlimited07
Thanks for everyone's replies! I'm off tomorrow morning to the dealer and I'll let you know how it turns out.
post #9 of 11 Old 09-29-2006, 03:13 PM
NaeKid
JF Administrator, eh?
NaeKid's Avatar
If I was you, I would also buy with the hardtop as the "only top" and then purchase a soft-top afterwards - either a dealer-top or one of the aftermarket units.
Winter is coming up soon - so there would be fewer days that you would have the soft-top down anyway.
When I picked up my '06 Unlimited it came with the dual-tops. I haven't taken the hardtop off yet because I don't have anywhere to store it
Hello, my name is Vance and I am a Jeepaholic.
Its better to be naked with your friends, than to be clothed with your enemies
Silver
, zombie ready as the daily-driver
NaeKid is offline
post #10 of 11 Old 10-03-2006, 09:02 AM
SafetyMike
Another question for the thread:
With the dual tops, can I leave the soft top folded up with the hard top on? I know it comes that way from the factory, however should I worry about the hard top wearing into the soft top over time from road vibration?
OR will the soft top cover protect it?
SafetyMike is offline
post #11 of 11 Old 10-03-2006, 10:01 AM
ghostship
1978 CJ7
Jeep recommends that you remove it, and it can rub causing wear marks over time. It also gets in the way of the rear cargo access. I'll probably leave my softtop in there over the winter, and then remove it next fall when the hardtop goes back on, like I did with my 03 Rubi.
ghostship is offline
question about dual tops yukonmuscle JK Wrangler Technical Forum 16 12-15-2008 11:53 AM
Dual tops question... Lammer JK Wrangler Technical Forum 6 06-09-2008 11:35 PM
Question about Dual Tops Gravitytester JK Wrangler Technical Forum 2 05-03-2008 11:35 AM
New Jeep - Dual Tops Question Strideur TJ Wrangler Technical Forum 5 07-17-2005 08:50 AM
Dual tops question Prospect62 TJ Wrangler Technical Forum 4 06-08-2004 09:37 AM
