DS Vibration - Pinion Angle? - JeepForum.com
post #1 of 9 Old 12-03-2010, 12:33 PM Thread Starter
113366
2010 JK Wrangler
2010 4D Rubicon, with a 2.5" Teraflex Lift (new springs, shocks, etc). Stock tires for now. New front and rear bumpers (winch also on front, and new swing-out tire carrier on rear).
I was originally getting a vibration / resonance around 35 to 45 MPH after the lift, but am now hearing a distinct grinding-type noise at these speeds (along with the original vibration). The noise and vibration appear to emanate from right under my feet, so I was thinking the front DS was needing re-balancing, or perhaps a new Tom Woods DS. However, from the posts on similar subjects, perhaps I need to consider new, adjustable upper control arms for the front, to tune in a new pinion angle, and keep the stock DS (kinda seems counter-intuitive in that the lift is only 2.5"....but stranger things have happened).
I'm thinking that I should remove the front DS anyway, until I can get this issue resolved (and to verify that the DS is, indeed, the problem).
Once the original tires are "used up", I'll eventually go with 33's. Am assuming that the new upper control arms would come in useful for this change as well.
Any input / advice will be gratefully appreciated.
113366 is offline
post #2 of 9 Old 12-03-2010, 01:53 PM
PanthersFan
Is the noise only under acceleration? Mine was. I narrowed it down by removing the rear drive-shaft and driving around. Sound went away with the rear shaft off, so I know it was the TC or the rear diff. Turned out it was the rear differential. Had the shop put a rebuild kit in it the rear diff and sound is gone.
BTW: I've got a 2.5" lift, too. I put adjustable uppers on the back to correct the rear shaft pinion angle to see if that fixed my problem. It didn't - it was my pinion bearings.
THE Conventions of a number of the States, having at the time of their adopting the Constitution, expressed a desire, in order to prevent misconstruction or abuse of its powers, that further declaratory and restrictive clauses should be added: And as extending the ground of public confidence in the Government, will best ensure the beneficent ends of its institution.
PanthersFan is offline
post #3 of 9 Old 12-03-2010, 02:06 PM
aristobrat
2010 JK Wrangler
Newbie question, but I didn't think the front DS spun unless you were in 4WD?
aristobrat is offline
post #4 of 9 Old 12-03-2010, 02:07 PM Thread Starter
113366
2010 JK Wrangler
Noise is evident all the time between 35 and 45 (ish).
I'm fairly certain I should remove the front DS, just to ensure the noise isn't coming from somewhere else.
113366 is offline
post #5 of 9 Old 12-03-2010, 02:10 PM Thread Starter
113366
2010 JK Wrangler
"Newbie question, but I didn't think the front DS spun unless you were in 4WD?"
I may be off-base, but I think it spins all the time, while the wheels are turning......
113366 is offline
post #6 of 9 Old 12-03-2010, 02:25 PM
MoparToYou
2014 JK Wrangler
It spins all the time, unless you have locking hubs that can be unlocked.
Take the front driveshaft off and drive the Jeep. If the vibration goes away it is from the front driveshaft.
You don't even need to take the whole driveshaft off. Just disconnect the axle end and tie it up with a bungie cord (don't use four wheel drive though).
2014 Grand Cherokee Laredo: 2" Eibach lift, 265/70R-17 BFG KO2's, 17x9 KMC Addicts
MoparToYou is offline
post #7 of 9 Old 12-03-2010, 02:30 PM
aristobrat
2010 JK Wrangler
Ah, ok -- so it's the TC end that's not engaged when in 2WD?
post #8 of 9 Old 12-03-2010, 02:34 PM Thread Starter
113366
2010 JK Wrangler
That's my understanding..
113366 is offline
post #9 of 9 Old 12-04-2010, 03:38 PM Thread Starter
113366
2010 JK Wrangler
Well...........
Front DS removed, and there's still a vibration / resonance / noise from the front end. My assumptions are that there's an "issue" with the front diff., that's exacerbated by the DS.
Will make an appointment with the purchasing dealer. Only three months new, with 3k miles.
113366 is offline
Front pinion angle vs. driveline angle Jeepin' Rock Cl TJ Wrangler Technical Forum 19 11-01-2016 04:02 PM
Caster Angle and 4WD Vibration nforcer YJ Wrangler Technical Forum 34 01-20-2010 08:59 PM
CV drive shaft angle vs. pinion angle mdm TJ Wrangler Technical Forum 7 12-01-2009 05:36 AM
Rake and pinion angle - DS vibration incredibull TJ Wrangler Technical Forum 10 10-04-2009 06:08 PM
Vibration at neutral throttle (Pinion angle OK) doublins TJ Wrangler Technical Forum 2 02-06-2008 08:12 AM
