Driver side higher than passenger side - JeepForum.com
post #1 of 26 Old 10-10-2009, 09:28 AM Thread Starter
traderdan
So, I finished my 2" lift kit a couple days ago and went out and measured my jeep today. My driver side is about 3/4 of an inch higher than my passenger side. Is this normal?
traderdan is offline
post #2 of 26 Old 10-10-2009, 11:42 AM
jnorton1
A lot of people report this not sure if to that extent but there is a bit of lean to it. Mine does slightly.
2007 JK
33's
Cragar Soft 8's
2.5 BB
Gibson Exhaust
Airraid Intake
jnorton1 is offline
post #3 of 26 Old 10-10-2009, 11:58 AM Thread Starter
traderdan
Do you think this could be due to the fact that my rear track bar was a little short after I put on the lift? I had to raise the body a little bit to match it up.
post #4 of 26 Old 10-10-2009, 12:01 PM
jnorton1
Shouldn't be, your rear axle might be off center now, though it usually isn't with just a 2" lift. I have read that some say the lean is from the gas tank or something. It seems the issue is hit or miss.
2007 JK
33's
Cragar Soft 8's
2.5 BB
Gibson Exhaust
Airraid Intake
jnorton1 is offline
post #5 of 26 Old 10-10-2009, 12:02 PM
jnorton1
Did you make sure all your springs were seated completely. Not sure if you did a BB or coil lift.
2007 JK
33's
Cragar Soft 8's
2.5 BB
Gibson Exhaust
Airraid Intake
jnorton1 is offline
post #6 of 26 Old 10-10-2009, 05:58 PM Thread Starter
traderdan
I did a coil lift. I checked and they all are. Well the two on the front are and the two on the back seem to be. The rubber liner at the top is where it is supposed to be.
post #7 of 26 Old 10-10-2009, 07:36 PM
bunkrdfool
Gas tanks on your right side of the jeep. The lean might be caused by having it full.
USAF Security Forces. Keeping your chair safe since 2009.
bunkrdfool is offline
post #8 of 26 Old 10-12-2009, 08:56 PM
owtdorz
2009 JK Wrangler
DITTO
3/4" is about right.
'09 Detonator Yellow 4dr Rubi, Bestop Element doors, Rugged Ridge XHD w/stinger, Warn 9.5ti, 3.5 Rock Krawler, Woods driveshafts, Hella 500 aux lights, 35x12.5x17 BFG KM2<< THEY SUCK
owtdorz is offline
post #9 of 26 Old 06-26-2010, 10:50 PM
Charles
2017 WK
This lean thing is unusual. I am a full inch lower full tank or not! I guess I'm going to have put a spacer on the right.
Charles is offline
post #10 of 26 Old 06-27-2010, 12:41 PM
plac
yes its normal. when you sit in the drivers seat it probably lowers another 1/2" so its even.
2015 Subaru WRX
plac is offline
post #11 of 26 Old 06-27-2010, 05:18 PM
Charles
2017 WK
But when a passenger gets in it goes back to uneven. It should sit level. I'm dying to know what causes the JK lean.
Charles is offline
post #12 of 26 Old 06-27-2010, 05:29 PM
ronjenx
ronjenx's Avatar
To be clear on OEM curb height, this is from the service manual:
"Curb height dimensions assume full fluids (including fuel) and zero passengers."
"Maximum difference cross-car is 0.47 in."
ronjenx is online now
post #13 of 26 Old 06-27-2010, 06:51 PM
Charles
2017 WK
I thought this was pretty interesting too: NOTE: The stabilizer/sway bar may be torque locked
due to left and right suspension height differences. This
condition is due to driving surface differences or vehicle
loading. In order for the stabilizer/sway bar to
disconnect/reconnect, the right and left halves of the bar
must be aligned. This alignment may require that the
vehicle be driven onto level ground or rocked from side
to side.
To return to on-road mode, press the stabilizer/sway bar
button again.
I did go out and disco and re-disco and I'm still 3.4 of an inch low on the passenger side.
Charles is offline
post #14 of 26 Old 06-27-2010, 06:56 PM
jeepinmichguy_
Soar Forever Six
jeepinmichguy_'s Avatar
most jeeps sit like that (depending on brand of lift), its so it levels out when the driver gets in. i even put new springs on my jeep a few weeks ago ad it still sat like that.
ΜΟΛΩΝ ΛΑΒΕ
Jeepinmichguy is a jerk.
jeepinmichguy_ is offline
post #15 of 26 Old 06-27-2010, 07:04 PM
Charles
2017 WK
That makes no sense. They wouldn't engineer it to sit level with one person it it. If a Jeep has two or four people in it, that weight would negate the leveling effect that they engineered in.
Charles is offline
Bar the goes from passenger to driver side between roll bars Shellb2414 YJ Wrangler Technical Forum 14 07-31-2009 12:15 PM
Passenger side lower than driver side + more. Imped TJ Wrangler Technical Forum 2 11-19-2008 02:37 PM
Driver or Passenger side rear view? SlimBeegs TJ Wrangler Technical Forum 9 06-24-2007 12:40 PM
Passenger side lower than driver side mezer TJ Wrangler Technical Forum 4 03-29-2006 02:08 PM
Passenger side 3/4" higher FlyersFan2009 TJ Wrangler Technical Forum 5 05-30-2005 09:17 PM
