Drive Shaft Angle Acceptable?? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > Drive Shaft Angle Acceptable??
KrawlOff-Road.com now Carries Iron Rock Off Road!!!!!Toxic Brakes - 3000 PSI Braided Stainless Steel Brake LineFS: 2007-2013 Jeep Wrangler "HALO" Angel Eye Kit
Unread 05-20-2015, 07:52 PM   #1
Apettenon
Jeep Wrangler 2013 2door JK with Teraflex 2.5" Coil lift + 3/4" Daystar spacers on each coil. I was beginning to worry about my drive shafts angles. Can any one tell me if I am ok running stock DS's by looking at the provided Rear and Front DS pictures. Any help would be appreciated !!
The first two pictures are of the Rear DS and the the remaining three pictures are of the Front DS.
Apettenon is offline   Reply With Quote Quick reply to this message
Unread 05-20-2015, 09:37 PM   #2
rich6700
If you don't wheel, they will last for a while. If your wheeling, adjustable control arms and drive shafts are in your near future.
rich6700 is offline   Reply With Quote Quick reply to this message
Unread 05-21-2015, 06:08 AM   #3
HappyTrails
Registered Voter w/ID
HappyTrails's Avatar
I agree!
If those pics are on flat ground, you are fine. But if they flex more that that, you are going to have problems.
2008 2-dr Rubicon, auto,
RK 2.5" Max Travel, Rancho 9000XL shocks, 37" Nittos, 5.38's, RR skids, Warn VR8000-S.
RIPP Gen 2 Stg 2 Supercharger.
"Boing Clash Boom!" - Dada Life
HappyTrails is offline   Reply With Quote Quick reply to this message
Unread 05-21-2015, 06:11 AM   #4
cyberpyrot
man if I only knew it was that easy to get some one to look at my shaft I would have done it a long time ago.
I have attention defiiiii hey is that a rabbit?
Thought of the day
Trust people who like big butts they cannot lie...
cyberpyrot is offline   Reply With Quote Quick reply to this message
Unread 05-21-2015, 06:20 AM   #5
Apettenon
Awww Ohh. I wheel a little . Can i just replace my rear DS (tomwood) and keep stock CA's? I just love the fixed stock CA's.
Unread 05-21-2015, 06:37 AM   #6
motoguy1251
How and when did you crawl under my jeep.
motoguy1251 is offline   Reply With Quote Quick reply to this message
Unread 05-21-2015, 06:56 AM   #7
duneslider
To run a TW shaft or any other double cardigan you will need to have at least upper rear arms to set the pinion angle.
Just run in until the joints get bad, what will most likely happen first is your boots will split and sling the grease out. When you see that happen you then order your new parts. My buddy has a similar setup as what you have and has been going several years that way and the shafts are still good.
My front finally gave out and I just rebuilt the joint and away I go again.
duneslider is offline   Reply With Quote Quick reply to this message
Unread 05-21-2015, 07:58 AM   #8
RockyClymer
RedRock4Wheeler
RockyClymer's Avatar
ditto - run them till they split open. Adj rear control arms will be needed if you replace with a double cardan joint drive shaft to set rear pinion angle. Personally, I resent the rear pinion angle with stock drive shafts and still going strong after close to seven years.
08 JK 23S - Colorado Jeep Club No. 204
Too much to list - see my profile for details on build
NRA Life member
"It takes a special kind of stupid to believe criminals will follow gun laws."
I do not consider myself a smartass. I point out the obvious, search for the truth, and speak fluent sarcasm. I am, by experience, an accomplished curmudgeon.
RockyClymer is offline   Reply With Quote Quick reply to this message
Unread 05-21-2015, 08:14 AM   #9
Apettenon
Ok upper rear CA's are not that bad, I woud replace them with teraflex's new fixed CA rear uppers that are for 2.5-3" lift. WIll this work? anddd do you think my rear or my front will go first??
Unread 05-21-2015, 08:27 AM   #10
duneslider
I have no idea if the fixed arms have enough of a change to correctly set your pinion angle in your particular setup. I would highly doubt it though. Spend the extra few bucks and get adjustable arms so you can set it correctly and be able to adjust it depending on what you do in the future.
Unread 05-21-2015, 09:06 AM   #11
jwmbishop
Accidental Obfuscator
jwmbishop's Avatar
2011 JK Wrangler
As long as you ain't wearing a trench coat when you say that I guess its all good....
J Wm Bishop EA, ASADE
My greatest fear, is that when I die, my wife will sell my Jeep for what I have told her it's cost ...
jwmbishop is offline   Reply With Quote Quick reply to this message
Unread 05-21-2015, 10:22 AM   #12
HappyTrails
Oh, Lordy...this thread is headed straight to Hell in a hand basket.
OP, spend the extra $$ and get ADJUSTABLE control arms. Replacing the stock ones with fixed aftermarket is pretty much not accomplishing anything, other than spending money.
Unread 05-21-2015, 10:34 AM   #13
jwmbishop
jwmbishop's Avatar
2011 JK Wrangler
Only problem is the caster goes away when taking out the angle... so either way I would expect to need adj balls later...
No that wasn't intentional...
Unread 05-21-2015, 10:56 AM   #14
Apettenon
can someone supply me with a visual (micro paint pic lol) of what my rear DS should look like when running stock DS and adj rear upper CA's? please!!
Unread 05-21-2015, 11:28 AM   #15
cyberpyrot
OO
ADJ Balls happens with old age..
Thought of the day
