Drag link adjustment - JeepForum.com
post #1 of 12 Old 10-09-2012, 10:06 PM Thread Starter
jcull35
2010 JK Wrangler
I am trying to re center my steering wheel.Does anyone have any advice to loosen up the drag link for adjustment. my drag link will not move and those bolt are very loose.
jcull35 is offline
post #2 of 12 Old 10-09-2012, 10:34 PM
rubicon1000
Should've very easy to rotate
'12 unlimited sport S, 3.73, trac loc, towing package, rubicon unlimited springs and shocks
SOLD 03 Rubicon , nv 3550 ,4'' RC lift ,1'' RC MM lift, 1.25'' body lift, HD rear bumper, hummer snorkel cap with buick airbox and custom piping, 265/75 r 16 tread wright retread mud tires on stock rubicon wheels, smitty built 8k winch, cobra cb radio, rrc front bumper, pre-runner rear bumper, HID headlights in Hella housings
rubicon1000 is offline
post #3 of 12 Old 10-09-2012, 10:41 PM
RockyClymer
RedRock4Wheeler
RockyClymer's Avatar
WD40 overnight & tap with a hammer.
08 JK 23S - Colorado Jeep Club No. 204
Too much to list - see my profile for details on build
16 JK Rubi with all the trimmings
NRA Life member
"It takes a special kind of stupid to believe criminals will follow gun laws."
I do not consider myself a smartass. I point out the obvious, search for the truth, and speak fluent sarcasm. I am, by experience, an accomplished curmudgeon.
RockyClymer is offline
post #4 of 12 Old 10-09-2012, 10:45 PM
Jeffro06
Jeffro06's Avatar
pipe wrench
Jeffro06 is offline
post #5 of 12 Old 10-10-2012, 06:58 AM
paul84043
? You have a 2010 and it's already seized up? I had no problem at all.. Not that it helps you at this point.
I'd try a pair of pliers, vice grips, robo grips, monkey wrench, whatever you have.
You are loosening the two 15mm bolts right? (just checking).
Mine turned by hand very easily....
Make a man a fire and you keep him warm for a day....Set a man on fire and you keep him warm for the rest of his life....
paul84043 is offline
post #6 of 12 Old 10-10-2012, 08:15 AM Thread Starter
jcull35
2010 JK Wrangler
The 15 mm bolts are very loose. I give those Ideas a try this weekend
jcull35 is offline
post #7 of 12 Old 10-10-2012, 08:39 AM
Noxian
2011 JK Wrangler
Vise grips always do the trick for me.
Noxian is offline
post #8 of 12 Old 10-10-2012, 08:59 AM
VoodooTacos
2009 JK Wrangler
I had to apply an ungodly amount of liquid wrench, took me about 20-25 minutes of working it back and forth with vice grips while rejuicing to get it unstuck. Nothing magic here, just throw on enough penetrating oil and add lots of patience.
VoodooTacos is offline
post #9 of 12 Old 10-10-2012, 07:23 PM
brianjw
May be worth unthreading the whole thing and applying anti-seize to the threads.
brianjw is offline
post #10 of 12 Old 10-10-2012, 07:56 PM Thread Starter
jcull35
2010 JK Wrangler
When I take care of it this weekend and just going to spray it down good. Has any one used a screw driver on it?
jcull35 is offline
post #11 of 12 Old 10-10-2012, 09:34 PM
Jeffro06
Jeffro06's Avatar
Nope, the pipe wrench should make quick work of it though.
Jeffro06 is offline
post #12 of 12 Old 10-12-2012, 04:12 AM
aldaman
x2, on the pipe wrench method. You could also "PB blast" that overnight before turning it with the pipe wrench. Fortunately for me I was able to loosen the two bolts and turn it with my hand to straighten up the steering wheel....
aldaman is offline
