Double Din install for Jk - JeepForum.com
post #1 of 12 Old 01-13-2012, 12:39 PM Thread Starter
ryan5991
I just bought a double din touch screen stereo off of eBay. I know how to install it however the actual opening in the dash is not big enough to go over the head unit (the head unit is barely taller than the opening in the dash). i didn't want to cut any plastic in visible areas but it looks like im going to have to. Has anyone else had this issue when installing a 2din?
ryan5991 is offline
post #2 of 12 Old 01-13-2012, 04:42 PM
RubiHD
2011 JK Wrangler
Try crutchfield. They have vehicle specific bezels to match. Here is an example. They have GREAT customer support too.
http://www.crutchfield.com/p_1209565...t.html?tp=3121
RubiHD is offline
post #3 of 12 Old 01-13-2012, 05:23 PM
Prot
Prot's Avatar
2014 JK Wrangler
What make and model did you buy?
2014 JKU Copperhead Pearl
Too many mods to list. Too awesome to sell.
Prot is offline
post #4 of 12 Old 01-13-2012, 09:18 PM
Rudinater
2009 JK Wrangler
Never mind
Thanks
Rudy Ackerman
In Oregon for now
Red 09 Unlimited Rubicon - Teraflex 4inch long arm lift, Elka shocks, 5:38 gears, 37inch GY MTR's, Expedition Core front bumper with Warn PowerPlant HD, RS-E rear bumper and carrier, RS-E step rock sliders.
Rudinater is offline
post #5 of 12 Old 01-14-2012, 02:07 AM
1222
RIP John
1222's Avatar
Originally Posted by Rudinater View Post
Never mind
What kind of post is that?
1222 is offline
post #6 of 12 Old 01-14-2012, 04:53 AM
Jkm57
2010 JK Wrangler
I ordered a double din pioneer and after rigging it and having it Half hanging out for a few months I took a drill to the back metal support brace. Mine hit both the back and top but fits good now.
Jkm57 is offline
post #7 of 12 Old 01-14-2012, 08:53 AM
Rudinater
2009 JK Wrangler
Its a post that does not contain any incorrect information
Thanks
Rudy Ackerman
In Oregon for now
post #8 of 12 Old 01-14-2012, 12:24 PM
GXP20T
2010 JK Wrangler
You have to remove the metal bracket in the dash that held the factory radio in. It will give you more room for installation.
GXP20T is offline
post #9 of 12 Old 01-14-2012, 01:08 PM Thread Starter
ryan5991
Yeah, I've removed the metal bracket in the back with no problem. its just actually getting the head unit through the opening in the dash. I didn't want to cut the dash to make it fit. I measured the opening in my dash and its just shy of 100mm which is the size of a double din. I was just going to try to force it over the stereo.
ryan5991 is offline
post #10 of 12 Old 09-15-2017, 11:17 PM
gacjeep
"removed the metal bracket in the back with no problem"? On a 2008 Jeep Wrangler? How? I have the bolts removed and the bracket is loose, but I cannot get it through the dash openings. Did you remove more dash panels than just the top plate and the front center panel (where the vents, hazard button are)?
gacjeep is offline
post #11 of 12 Old 09-16-2017, 07:52 PM
TJ's02TJ
2017 JK Wrangler
Most install videos I have seen have you cut out that plastic piece at the top.
2004 Wrangler TJ 2.5" lift with 31s.
2017 Wrangler JKU currently stock.
TJ's02TJ is offline
post #12 of 12 Old 09-19-2017, 09:57 AM
Psycho-X-Jeep
2009 JK Wrangler
Once the bolts holding the metal piece are removed its not extremely easy to get the metal piece out without fully removing the dash, but it can be done. I definitely scratched everything inside of the cavity while trying to get mine out. I finally got it at an angel where it came out, but took five minutes worth of scratching my head and pushing plastic crap out of the way. I was about to resort to cutting the metal bracket in half with a dremel.... but decided putting a few scratches on the inside was better than cutting something on accident.
Call me Eddo
09 JKUR
13 WK2 Trailhawk
Psycho-X-Jeep is offline
installation , stereo
Double Din in a JK Heatgriff JK Wrangler Technical Forum 15 11-10-2011 12:21 PM
Radio delete plate / double switch panel install southbound YJ Wrangler Technical Forum 14 10-28-2010 05:57 PM
double cardan install question guerrilla TJ Wrangler Technical Forum 3 01-11-2010 08:59 PM
double - double cardon DS worth the extra $$? BNovak TJ Wrangler Technical Forum 9 01-27-2005 07:38 PM
Olympic Double Nerf Install Complete...Question... AldoD TJ Wrangler Technical Forum 8 07-21-2003 11:59 AM
