Dot 3 Brake fluid. Does it matter??? - JeepForum.com
post #1 of 9 Old 05-30-2013, 07:47 AM Thread Starter
ctappan94
1983 CJ7
Hey guys,
Want to know what dot 3 brake fluid I should use when flushing my '12? I have two bottles of DOT3 napa...is that good enough or is it ****ty? I live in the rust belt so do you think I need one with extra corrosion inhibitors? or is this good
Thanks,
Chris
ctappan94 is offline
post #2 of 9 Old 05-30-2013, 08:01 AM
rha600
DOT 3 is fine, but you can use DOT4.
here is some info on the grades.
http://ebcbrakes.com/product/ecb-brake-fluids-index/
rha600 is offline
post #3 of 9 Old 05-30-2013, 08:11 AM
Jiblet
Originally Posted by ctappan94 View Post
Hey guys,
Thanks,
Chris
rha600 is correct.
But if either of those bottles has been open for a while I wouldn't use it. I'd stick with fresh fluid that hasn't had the chance to pick up any moisture.
Any reason you are changing the fluid after just one year or so?
Jiblet is offline
post #4 of 9 Old 05-30-2013, 08:22 AM Thread Starter
ctappan94
1983 CJ7
Reason isn't because of brake fade or anything. I'm mounting my 37's soon so I want to have the brakes in tip-top shape. lol. I like a stiffer feel. IDK about you but my JK brakes have never felt as stiff or responsive as my friend's lifted TJ on 33's with stock brakes.. His stops on a dime with the 33's and yet my 32's ... not so much
post #5 of 9 Old 05-30-2013, 08:47 AM
BigBlue7
2010 JK Wrangler
use DOT 3
Rock Krawler | TeraFlex | Synergy | Fox | Poison Spyder | Genright | Nemesis |Beer
BigBlue7 is offline
post #6 of 9 Old 05-30-2013, 09:35 AM
Godholio
As mentioned, the big thing to make sure is that they're newly-opened bottles. Once you break that seal the fluid absorbs moisture which is not what you want in your lines. This is also why you should flush/bleed your brakes every couple of years.
Utah Jeep Crew #148
No powerball here? How am I supposed to finance the mods?!?
'12 Sport...miss my YJ for all the wrong reasons though
Godholio is offline
post #7 of 9 Old 05-30-2013, 10:03 AM
Jiblet
good reason to change the fluid!
The electronic safety stuff is probably a lot of the reason the brakes feel softer.
There are some beefier brake systems you may want to look into for those 37s.
Jiblet is offline
post #8 of 9 Old 06-01-2013, 12:08 PM
Rooster76
Teraflex has a bigger break kit, or you can just buy the master cylinder that gives more flow. I cannot say anything good or bad about it. I just happened to run across it doing a search awhile back.
This is the master cylinder
http://www.teraflex.biz/brake-master...ized-bore.html
2012 JKR 2DR 6-Speed
Rooster76 is offline
post #9 of 9 Old 06-01-2013, 11:01 PM
COLOUXJ
2010 JK Wrangler
Then his TJ must have been a special edition. My JK on 35's stops almost as quick as my buddies LJ on 33's with blaines big brake kit. I rode in his LJ when he had stock brakes and 33's and it was scary.
COLOUXJ is offline
