doors off, rear floor mats go airborne - fixed - JeepForum.com
post #1 of 17 Old 04-19-2011, 06:39 AM Thread Starter
Mol
Disclaimer: I'm Polish
Mol's Avatar
This is pretty simple and extremely inexpensive.
Supplies:
Hot glue gun
(2) 2-packs of wide industrial strength sticky back velcro
I was afraid that the velcro would not have a solid enough contact surface to stick to the bottom side of the floor mat, so I applied the hot glue before sticking the pads down.
Let it cool for a few minutes before attaching the other pieces of velcro (so you don't have to worry about proper alignment when attaching to the jeep carpet). Remove backing, carefully set floor mats back in place, and apply pressure to the velcro areas.
This should keep them from flying off the next time you remove your doors
Mol is offline
post #2 of 17 Old 04-19-2011, 08:35 AM
1AAdam
wow! great fix! didn't have floor mats in my TJ so didn't even think this could be an issue.
Adam
1aauto.com
888-844-3393
1AAdam is offline
post #3 of 17 Old 04-19-2011, 08:37 AM
JackAce
2009 JK Wrangler
i haven't gotten to take the doors off yet so i never thought about this either.
the front ones have those lock down things from the floor though, the rear one is just one huge strip but i wouldn't want it to fly out so i'll look into doing this. thanks!
God grant me the serenity to accept the impossible trails I cannot crawl, courage to crawl the twisted trails I can and the wisdom to keep tire side down.
JackAce is offline
post #4 of 17 Old 04-19-2011, 09:12 AM
treck4life
2011 JK Wrangler
Haven't had a problem yet, drove down the freeway at 110 kph with the doors and roof off: A- it was freaking cold at -4 degrees but worth it :P and B- the slush mat didn't move but it's a good idea just incase
Good Idea
treck4life is offline
post #5 of 17 Old 04-19-2011, 10:15 AM Thread Starter
Mol
Mol's Avatar
Is yours a 2-door, or did they change the floor mats for '11? My unlimited has two seperate floor mats...I didn't think it would be an issue because they have slots in them that go around the from to the rear seat, but they have flipped over and ended up sitting on the back seat on short trips at no more than 45mph - go figure Chrysler couldn't add the hold downs to the rear...that might have cost them an extra $1 per vehicle
Good Idea
Yeah I guess I should have clarified - probably only necessary with the 4-doors - what the hell were you doing with the doors and roof off in sub zero temps
Edit: I see yours is a 4-door...do you have one solid mat like Ace?
Mol is offline
post #6 of 17 Old 04-19-2011, 10:16 AM
Layth
I can attest that in a JK Unlimited with the doors off even that heavy 1-piece rubber slush mat in front of the back seat will rise off the floor about 1.5 feet and float there at 65mph. The little carpet mats that come standard would be history at that speed. I always threw a brick on each side of the floor mat. But Velcro is much more elegant. I'll be doing that for sure!
Layth is offline
post #7 of 17 Old 04-19-2011, 10:19 AM Thread Starter
Mol
Mol's Avatar
yeah, loose bricks in your rig might not be the best idea in the event of a wreck
Mol is offline
post #8 of 17 Old 04-19-2011, 11:30 AM
Layth
In fairness, the steak-knives I tried first weren't heavy enough.
Would you mind sharing what store (or type of store) you found those large, heavy-duty Velcro pads at? Seems like every time I need some all I find are those wussy little round quarter-sized pads.
Layth is offline
post #9 of 17 Old 04-19-2011, 11:41 AM
JackAce
2009 JK Wrangler
nah i have a 4 door but my floormats are the rubber aftermarket ones from quadratic
JackAce is offline
post #10 of 17 Old 04-19-2011, 12:33 PM Thread Starter
Mol
Mol's Avatar
Lowes
Ahhh, copy
Mol is offline
post #11 of 17 Old 04-19-2011, 02:45 PM
treck4life
2011 JK Wrangler
Lowes
Ahhh, copy
Ya its one solid piece, and I'm canadian If I don't try it in sub zero then I will never try it out hahaha jk it was just a cold night it's was fun and the without my cheesy seat earners I probably would have dies lol
post #12 of 17 Old 06-06-2011, 11:24 AM
mdc144
2009 JK Wrangler
looking through the mods section of FAQ...ran accross this one a little late. Took my floormats out long ago after they flew around the jeep at high speed. No idea what I did with them...
mdc144 is offline
post #13 of 17 Old 06-06-2011, 02:53 PM Thread Starter
Mol
Mol's Avatar
Glad you brought this up - I need to redo mine, as I replaced the stockers with weathertech digital fits...
Mike
Mol is offline
post #14 of 17 Old 06-06-2011, 04:03 PM
BlueLesPaul2006
I just take mine out. but I may try this
OK, then...the hood is not supposed to flop up and down??
Dang, all this time and I thought it was the famous Jeep Wave!! ~bluegrassguitar
BlueLesPaul2006 is offline
post #15 of 17 Old 06-06-2011, 04:20 PM
goldenglory18
The 2011 I have came with two in the back, not the one piece.
Gone and I dont miss it at all - 2011 JKU
goldenglory18 is offline
