Quantcast Don't overtighten the Freedom Top hand screws - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > Don't overtighten the Freedom Top hand screws
Front and rear Drive shafts @ free shippingPoison Spyder February Special: FREE Rubber Liners when yoSlappin' on 61,510 Rigid Industries Lumens for Big Red
Old 04-15-2008, 01:23 PM   #1
rlabbott
Wow, my Jeep is 1 yr. old... I had noticed some 'creaking' of the top lately, so the last time I put the freedom panels on, I tightened the hand screws (that go thru the soundbar) a little more. I just did this by hand. Well, I just noticed they are poking the top of the freedom panels, and I have cracked and bubbled up the panels... OUCH.
Anyone else done this? Seems odd you could tighten enough by hand to do cause this... but there are the results... doh!
I wonder if the gasket on the main roof, has compressed over the year, and I kept cranking down a little more each time without really knowing what I was doing.... Oh well, I'll be this is gonna be expensive
I'll have more respect for these in the future.
rlabbott is offline   Reply With Quote
Old 04-15-2008, 02:42 PM   #2
naplesrubicon
wow that sucks
you must have big lumberjack hands
i never went through the top but i did overtighten them once and thats what caused my leak after backing them out a little the leak went away
2008 jk unlimited rubicon black everything except auto trans,remote start and soft top $1000.00 off sticker 2 month wait and a 39 month chrysler lease
1st JK 4th jeep(1 CJ 2 TJ's)
warranty issues so far: replaced mygig,replaced amp
replaced front right u-joint replaced throw out bearing fixed leak in t-case fixed door latches
mods so far:
mopar heated seats, mopar slush mats, mopar door visors and bug shield, gentex self dimming rearview mirror with map lights,add on factory footwell lights and underhood light, bestop black spare tire cover, silverstar headlight and fog bulbs, amsoil fluids and filters, 20% tint on front doors, flat black painted antenna, front and rear grab handles, mopar freedom top bag, homemade CAI, magnaflow muffler, drilled mirrors, mopar factory keyed locking gas cap, prestone antifreeze flush kit, mopar black plastic door sill protectors,gloss black painted keyholes,black painted(inside)hardtop,coastaltech mic. TO BE CONTINUED
naplesrubicon is offline   Reply With Quote
Old 04-15-2008, 02:55 PM   #3
scottlaroc
I'm not sure i understand .Any pics?
scottlaroc is offline   Reply With Quote
Old 04-16-2008, 08:17 AM   #4
mdlott
1978 CJ7
I was under the impression that you didn't need to use the hand screws unless you were running the front panels only with the rest of the top off. I took my screws out when I first got the Jeep (1 year ago) and haven't put them back in yet. So far I haven't had any leaks or other issues.
mdlott is offline   Reply With Quote
Old 06-23-2008, 01:57 PM   #5
rlabbott
Update
Update: Chrysler replaced both Freedom panels. I was very lucky. My advice is to GENTLY tighten those freedom panel screws... or even remove them as many users have.
I was impressed that Chrysler replaced them, but the service manager at my dealership is the best I have ever met, and he really goes to bat for his customers.
Old 06-23-2008, 02:19 PM   #6
wolfman064
Is that correct that you don't need the hand-screws unless you are sporting the freedom tops without the rest of the top?
wolfman064 is offline   Reply With Quote
Old 06-23-2008, 02:44 PM   #7
FatBuoy
Yes and they are great for when you are being chased. Simply unlatch the two latches on each side and let em fly!!!!!
Rescue Green Auto Unlimited Rubicon, and lovin' it!
So far: Rugged Ridge front bumper, rear bumper/tire carrier and side armor, 37" Toyo Open Country MTs, Argent AEV Pintlers, AEV hood, 5.13 gears, Teraflex 4" Long Arm lift, JE Reel front shaft. Flat fenders-Bushwacker. Superchips Flashpaq
Waiting to be installed: Nuttin!
On order: Nuttin!
Some day: I may grow up, but I seriously doubt it. Oh, and a Hemi!
FatBuoy is offline   Reply With Quote
Old 12-12-2011, 10:14 PM   #8
gumbydammit
Eff, wish I has read this earlier. The screws on my '07 were going in pretty tight so I cleaned them up good and turned them back in. With the new easy-in and cold weather I cracked one of the panels.
I guess I'll put a couple of drops of epoxy into the end of the screw hole and a drop in the crack on top so no water gets into the crack and opens it up. Any thoughts? Just pisses me off! Anyone running leakless without them for a long time?
gumbydammit is offline   Reply With Quote
Old 12-13-2011, 08:38 AM   #9
JemLT1YJ
2011 JK Wrangler
If the fiberglass is cracked you gotta stop it from spreading, i uad a fairly big crack in mine and could tell it was spreading. Drill a hole no bigger then the crack at each end of it and then go buy a fiberglass repair kit, really not to hard and itll last work well for a long time.
JemLT1YJ is offline   Reply With Quote
Old 12-13-2011, 08:43 AM   #10
HOKIES2010
HOKIES2010's Avatar
2011 JK Wrangler
Don't use those screws here. Actually do not use my hard top much in FL.
Originally Posted by BRad704
I didn't realize Michael Moore was a member on JF... :dunno:
Originally Posted by STIFLER View Post
If I could eat a Jeep I know now what my **** would look like
Originally Posted by ncb View Post
I purchased a black JK so all the Tupperware wouldn't be so obvious.:D
HOKIES2010 is offline   Reply With Quote
Old 12-13-2011, 09:19 AM   #11
fmfa0801
2009 JK Wrangler
Crap I just tighten mine up a few days ago (only used my hand) I just looked a one has a crack. Do you think the warranty will cover it?
fmfa0801 is offline   Reply With Quote
Old 12-13-2011, 09:24 AM   #12
5foot19
2011 JK Wrangler
I guess I know what I'll be checking on my break shortly...
5foot19 is offline   Reply With Quote
Old 12-13-2011, 09:32 AM   #13
ncb
ncb's Avatar
2009 JK Wrangler
It's best to get the thumb screws just tight enough so they don't rattle in the sound bar.
ncb is online now   Reply With Quote
Old 12-13-2011, 10:52 AM   #14
GunDude
2011 JK Wrangler
Was not be chased but, I had a camero lose it's glass T-top comming at me from the opposite direction, right throught my front windshield at 45mph and hit me in the arm and pepper me and the metal cargo barrier behind me with glass. I looked like someone blased me with a 12ga full of rock salt.
GunDude is offline   Reply With Quote
Old 12-13-2011, 11:19 AM   #15
SilverStreaker
SilverStreaker's Avatar
Good to know. I just backed mine out a few turns just to be safe. I'll probably just remove them all-together when I get home.
My Jeep - 2012 Wrangler Unlimited Sport S
SilverStreaker Build Thread
My Wife's Jeep - 2007 Grand Cherokee - only mod - K&N Cold Air Intake system
SilverStreaker is offline   Reply With Quote
Glock Forum
