Does your automatic lug your motor? - Page 2 - JeepForum.com
post #16 of 42 Old 07-02-2013, 02:42 PM
justin credible
My 2012 doesn't seem to have this problem.
Your description really does sound like an issue with the ECU still thinking you have smaller tires.
justin credible is offline
post #17 of 42 Old 07-02-2013, 05:35 PM Thread Starter
Butterjeep
2015 WK
I hope this is the case, the reason I have my doubts is because my 2010 WK lugged as well. My fear is that this is the new reality where manufacturers have to wring every bit of efficiency out of every drop of gasoline to the point where they have programmed transmissions to upshift as soon as possible.
I shoulda boughta manual.
2014 Mustang GT Track Pack
2015 WK2 Limited 4x4
Butterjeep is offline
post #18 of 42 Old 07-02-2013, 07:58 PM
JTPhoto
JTPhoto's Avatar
Something to think about... My daughter has an 09 JK which was a dealer demo and actually only driven by the dealerships family members. At some point the transmission was reprogrammed by some knowledgable tech because this JK shifts like no other JK whether 3.8 or 3.6 that I have driven. Un programmed with 35" tires this JK shifts like all JKs should. The slightest touch of the throttle downshifts and it holds gear until the right speed and rpm to maintain momentum.
The downside, this 2 door that shifts so perfectly is harder on gas then my JKU with the same tires.
^^Jeff^^
2008 Black and Khaki Sahara Unlimited Trax-Lok rear diff. 3.5" Rock Krawler fr springs, rear TeraFlex 2.5 BB, 37x12.50x17 Pitbull Rockers on ProComp 7069 Alloys, AEV Prem Bumper ETC..
JTPhoto is offline
post #19 of 42 Old 07-02-2013, 08:38 PM
insaneinline
My 2013 Jku all stock with 3.21 gears does the same thing I think its the way it programmed with this Eco crap now . I was playing around with the dash and it looked like you could turn the Eco off or maybe it meant just the Eco that shows on the gauge cluster but I haven't tried it . I wanted to lift mine with 33s but I don't like the way it feels with stock tires so I might hold out until I can swap gears and just go with 35s idk
insaneinline is offline
post #20 of 42 Old 07-02-2013, 08:46 PM Thread Starter
Butterjeep
2015 WK
I'd gladly pay more in gas to have my Jeep be more driveable.
post #21 of 42 Old 07-02-2013, 08:58 PM
floridajpr
2015 JK Wrangler
I have a 2012 JKUS and when I had my RK 2.5" Max Travel Pro lift installed w/ 35x12.5x17R tires, "I also re-geared to 4:88 under the instruction of my mechanic", it drives a lot better than w/stock 3:73 gears and the stock tires from before. If you go up in tire size and do not re-gear or at least program for tire size, the auto trans bogging down is usually what happens.
I love my 12 JKUS with the 4:88 gears & 35's. I know it may be a little over geared but going to get some axle work & 37's when my 35's are done. I can't wait to go to NC for vacation in the mountains in October.
Florida Native Cracker Just Tryin to Stay Above Sea Level
floridajpr is offline
post #22 of 42 Old 07-02-2013, 09:04 PM
ronjenx
ronjenx's Avatar
I know you said you feel you shouldn't have to, (tap the shifter), but don't let that keep you from managing the transmission as you see fit. It's why the tap shift was programmed into it.
I do it with my 3.8/42RLE, and it's fine. You are way ahead with the engine/transmission in your JK.
ronjenx is offline
post #23 of 42 Old 07-02-2013, 09:06 PM
pismo61
pismo61's Avatar
2015 JK Wrangler
I fought this on two TJs with the 42rle auto,hated it.Thats why I bought the 2013 with the 6 sp. Man.That being said I didnt know much about the new 5 sp. autos.But what Ive read they are geared prefectly and kind of thought I should of went that route.So I dont know,but if you regear it will most likely shift at the same rpms.So,it will just shift faster and have a higher freeway rpm.This was my experience with my TJ autos.regeared them both 4.56 and 4.88 with33s.(2004 and 2006).I really like the 6sp. man. I have now,just hope it gives me good service over the long hall.
2015 Red 2 Door(half) 6sp.
pismo61 is offline
post #24 of 42 Old 07-02-2013, 09:23 PM
JTPhoto
JTPhoto's Avatar
If it's worth 14mpg highway to you, as it is us, cool. But unfortunately most anyone getting 14mpg with a 2dr would be livid. Especially when you can get 18 with a JKU on the same tires.
The alternative is to manually shift or what I find works to wake up the computer is just take it out on the freeway once in awhile and hammer it, blow some of that carbon out and relearn the computer. The throttle by wire also plays a part in the shift up/down scenario. Learn to throttle up in a steady motion and not letting up too soon as to have it kick into the next gear too soon.
We run our JKs with factory gears and OD off all the time maintaining constant 2100-2300rpm on the highway which seems to keep the engine happy. I attribute this to the fact that we don't find our JKs to be underpowered with 35s until I try and pull a trailer uphill.
My goal this fall will be to download the advanced transmission shift programming ability for the Superchips and see if I can figure out how to optimize up/down shift patterns.
^^Jeff^^
JTPhoto is offline
post #25 of 42 Old 07-03-2013, 02:22 PM
Godholio
The ECO display on the dash doesn't actually do anything...its just tells you if you're driving in a relatively fuel efficient manner. Basically a skinny-pedal monitor.
Utah Jeep Crew #148
No powerball here? How am I supposed to finance the mods?!?
'12 Sport...miss my YJ for all the wrong reasons though
Godholio is offline
post #26 of 42 Old 07-05-2013, 06:02 PM
Don-T
This happened to me when I installed 35s. The Procal fixed it.
12 Rubicon
Don-T is offline
post #27 of 42 Old 07-09-2013, 03:05 PM Thread Starter
Butterjeep
2015 WK
My AEV arrived today. Can't wait to go home and install it and see if it corrects the problem.
post #28 of 42 Old 07-09-2013, 03:32 PM
HappyTrails
Three letters: EPA
The computer is probably trying to keep your RPM's low to get better gas mileage (I know it's a Jeep, but....).
2008 2-dr Rubicon, auto,
RK 2.5" Max Travel, Rancho 9000XL shocks, 37" Nittos, 5.38's, RR skids, Warn VR8000-S.
RIPP Gen 2 Stg 2 Supercharger.
Political Correctness offends me.
HappyTrails is offline
post #29 of 42 Old 07-09-2013, 05:50 PM Thread Starter
Butterjeep
2015 WK
Came home, unpacked my ProCal and the install was a snap. I had already read the directions online and pre-measured my tires. Took the JK for a spin and it's better. I still feel like the transmission is lugging the motor but not as bad. This is about how it felt stock. I guess I am happy. I may experiment and program a tire that's larger to trick the computer into thinking it has taller tires which may encourage it to hold a gear a bit longer before upshifting. The only downside I can think of is that it will cause my speedometer to be slightly optimistic and register that I have slightly more miles than I actually do on the odometer but I feel that would be worth it.
I do agree that Jeep programmed the transmissions to kinda shift early in the name of gas mileage. My WK was really bad. When you're driving up a fairly steep hill and the motor is struggling at 1200 rpm and you have to nearly floor it to get the transmission to downshift, it's enough to make you trade it in for a 2014 WK2! Oh wait, I did do that...
Anyway, I'm not knockin' the ProCal, it's certainly a great product and did what it advertised to do. My issue was more with how the Jeep behaved from the factory. My next one'll be a manual!
post #30 of 42 Old 05-16-2014, 09:43 PM Thread Starter
Butterjeep
2015 WK
Just bumping this to see if anyone has more input. Mine still lugs after the procal but I just live with it.
