does anyone know what this fluidis? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > does anyone know what this fluidis?
Save 5% Off Of All Orders In August - Promo CodeJeep Wrangler Bushwacker Flat Fender Flare Sale at BaselinTJ & LJ Safari Cab Hardtops - $450 off expire 8/31/201
Unread Yesterday, 02:25 PM   #1
BROWNING3250CAL
I noticed fluid all over the inside of my passenger front tire. Its all over the axle C as well. Maybe its nothing but just curious to see experienced peoples opinions. Thanks.
It could just be water from driving through a puddle but who knows.
BROWNING3250CAL is online now   Reply With Quote Quick reply to this message
Unread Yesterday, 02:35 PM   #2
HappyTrails
Registered Voter w/ID
HappyTrails's Avatar
Looks like the inner axle seal is ripped, letting differential fluid out.
There is a seal around the axle shaft where it enters the differential.
Have you recently removed the axle shaft? If so, the splines of the end of the axle shaft can tear those seals when you install the shaft.
I doubt it is water. Look at the spray pattern. The fluid is dripping from the axle/center of the wheel, and being slung outwards as the wheel turns.
2008 2-dr Rubicon, auto,
RK 2.5" Max Travel, Rancho 9000XL shocks, 37" Nittos, 5.38's, RR skids, Warn VR8000-S.
RIPP Gen 2 Stg 2 Supercharger.
Political Correctness offends me.
HappyTrails is offline   Reply With Quote Quick reply to this message
Unread Yesterday, 03:18 PM   #3
ravenworks
ravenworks's Avatar
Looks like you had new tires put on by looking at thoose shiny wheel weights.
So my guess would be that it is soap.
Semper-Fi "81-84"
I.U.O.E. - 18
ravenworks is offline   Reply With Quote Quick reply to this message
Unread Yesterday, 03:26 PM   #4
BROWNING3250CAL
I haven't done anything to the axles but that doesn't mean the seal isn't leaking. I will definitely look into it. Thanks for the suggestion.
Unread Yesterday, 03:33 PM   #5
HappyTrails
NP. Mine started leaking at about 30K miles, and I had never touched the shafts (yet).
Unread Yesterday, 06:32 PM   #6
1222
Make mine a Jeep!
1222's Avatar
Attachment 2296889
If I were you I would clean everything off the tire and area around the axle end first. Then drive around and see if you can notice were the leakage is coming from, if from anywhere.
Dash mount for 2011-2015 JKs
1222 is offline   Reply With Quote Quick reply to this message
Unread Yesterday, 06:53 PM   #7
joeyprice
joeyprice's Avatar
2014 JK Wrangler
Wouldnt you know just by the smell if its diff fluid? 90 weight smells pretty freakin bad.
Originally Posted by martinsburgjeep
what can I say, every time I think of you my colon explodes
joeyprice is offline   Reply With Quote Quick reply to this message
Unread Yesterday, 07:12 PM   #8
JIMBOX
Happy trails/Joeyprice have pulled a Sherlock Holmes delight-
Judging by the symmetrical display and the smell----
I'd hafta conclude--Axle seal-
There ain't no reason forit, it just happens !
Overfill usually causes the breather tube to "drain", not in the outer axle area !
Good luck
JIMBO
Yellow Jeep No. 683
http://i294.photobucket.com/albums/m...10-snow027.jpg
--YA GOTTA HAVE CLASS--
JIMBOX is offline   Reply With Quote Quick reply to this message
Unread Yesterday, 08:54 PM   #9
BROWNING3250CAL
Thanks everyone. Yup, it's definitely axle seal leaking. Should be OK until it gets repaired as long as I don't use 4 wheel drive right?
Unread Yesterday, 09:22 PM   #10
SLADE
You still need to keep gear oil in it. JKs have live front axles, so the gears are always turning. I wouldn't avoid using 4 wheel drive as long as its topped off with oil.
2014 Wrangler JKU
2013 Wrangler JK
2004 Wrangler TJ on LEAFS
2001 Dodge Ram 2500
SLADE is offline   Reply With Quote Quick reply to this message
