Do Not Over Tighten Freedom Panels ! - JeepForum.com
post #1 of 1 Old 10-07-2006, 07:15 AM Thread Starter
Sahara GT
2011 JK Wrangler
Stopped by a local dealer and found the Freedom Panel Attaching Rod laying in the ashtray.It would not screw back into the Freedom Panel--The reason is that the threaded nut that is attached to a metal collar that is embedded in the panel was broken off from its collar mounting.Apparantly someone overtightened the screw post when securing the panel and broke the threaded nut weld...H
Hope this is just a case of misuse and not a flimsy design.Once the nut is broken off there is no way of putting in the screw post which might require a new panel.
Sahara GT is offline
WTB Freedom Top Panels for Unlimited AFhockey31 JK Wrangler Technical Forum 1 12-22-2009 07:11 PM
Paint For Freedom Top Panels DLeeWebb JK Wrangler Technical Forum 7 07-20-2009 07:34 PM
'09 front freedom top panels on an '08 nycrd JK Wrangler Technical Forum 3 07-07-2009 08:22 AM
Water in Freedom Top Panels asyrp43 JK Wrangler Technical Forum 7 07-01-2008 04:28 PM
Locks for the front panels of the '07 Freedom Top??? notseriousimJK JK Wrangler Technical Forum 3 05-20-2008 06:10 PM
