Do i need lift for 33"s on an 07'Rubi 2dr? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > Do i need lift for 33"s on an 07'Rubi 2dr?
Ruffstuff 10 year saleRegear now with Gear Packages from JeepHut.comSmittybilt M1 Fender Flares + FREE Machete
Unread 07-25-2013, 01:30 AM   #1
Habber
I've tried searching the FAQ and too much conflicting info. Can anyone shed some clarity if I can run the 33's without rubbing or will I need some lift? If yes, how much lift? Don't rubis sit around 1" higher than sports?
Jeep TJ 2001 4.0 5MT
Habber is offline   Reply With Quote Quick reply to this message
Unread 07-25-2013, 08:29 AM   #2
ncb
The little bit of extra height on a Rubicon doesn't change the max tire height because all stock JKs have the same bumps tops. On a stock JK you can fit 33s with minimal rubbing. If you go with a 285 width 33 (such as a 285/70/17) you'll need wheel spacers or wheels with 4.5" back spacing.
I had BFG KM2s 285/70/17 on 17X8 wheels with 4.5" back spacing on my JKUR when it was stock. At full stuff the rub was so minimal it didn't hurt anything.
If post a pic but the forum won't let me. Not sure why.
ncb is offline   Reply With Quote Quick reply to this message
Unread 07-25-2013, 09:07 AM   #3
JoeJackson
2011 JK Wrangler
Im running 305/65/17 with 4.75 backspacing and i have minimal rubbing. I havent done any hard off roading yet however. I would imagine that with the sway bar diconnected there would be much more rubbing.
I would say go for it.
I live vicariously through myself
JoeJackson is offline   Reply With Quote Quick reply to this message
Unread 07-25-2013, 09:13 AM   #4
222Doc
it will rub if they are 12.5 wide. In hard flex at lock off road it may knock a plastic fender lose.
10.5 wide will have less issues but still will rub.
I have seen 33x12.5 on a 2" rub in a hard flex, but just very lightly
The lowest cost way to have larger tires on a Jk is to trim the plastic flairs. remove and 35"s fit easy even 37". with the right off set.
http://www.parker4wheelers.net
www.bullhead4wheelersinc.com
222Doc is offline   Reply With Quote Quick reply to this message
Unread 07-25-2013, 09:18 AM   #5
MountainMan864
Just throw a set of aluminum 1" coil spacers all around and call it good and put some 1.25 spacers on and some 285s or 305s.
MountainMan864 is offline   Reply With Quote Quick reply to this message
Unread 07-25-2013, 11:51 AM   #6
Tbasham
Are you asking this about for a JK or a TJ? This is the JK section and in your orginal post you list your jeep as a TJ.
Tbasham is offline   Reply With Quote Quick reply to this message
Unread 07-25-2013, 12:28 PM   #7
ncb
Title explains it all. 07 Rubi 2 door.
Unread 07-25-2013, 01:30 PM   #8
Habber
JK baby! I'm looking at getting into one. Thanks for the advice guys. Keep it coming.
