Do I need adjustable control arms? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > Do I need adjustable control arms?
8500 Lb. Rugged Ridge Winch $239.95 Delivered after $20 MaXJ guys, clock your transfer case!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 01-04-2011, 06:47 PM   #1
AJ in Japan
Jeeps and Bikes - Yea!
Hey gang,
I ordered track bar relocation brackets/braces from Australia (RHD Jeep).
They come with all the hardware, high steering kit, etc.
Does anyone know if I need to get adjustable control arms to make this work?
'07 Sahara 2-door w/3.5" Skyjacker suspension lift, 35" BFG MTs.
AJ in Japan
2007 2-Door Sahara in Black - "Sarah"
2004 Vulcan 2000 - "The Dude"
Mods:
3.5” Skyjacker lift / Currie adjustable control arms (all 8) / Skyjacker dual steering stabilizer /
Poly Performance front and rear track bar relocation kits RHD / Poly Performance high steer kit with drag link flip adapter / 35/12.50/18 BFG Mud Terrain tires on stock painted rims with 1.5” Spidertrax wheel spacers / 5.13 Superior Gears front and rear /gear ratio, tire size and 91 octane performance adjusted with Superchips controller / ARB differential covers / Skid Row front skid plate / Mopar undercarriage skid plates (stock in Japan) / Mopar Rock Crawler bumpers front and rear with rear tire carrier / High Lift Jack mounted on rear bumper (when off roading) / Smittybuilt black D-Rings front and rear / Rampage Products Convertible Side Bar/Rocker Guards / AEV Heat Reduction Hood with AEV Snorkel / 1” over fender extensions / KC running lights on windshield and front bumper / Stubby antenna in black/ Warrior Products Mirror Relocation Brackets when doors are off / Meiwa Ultra Performance Muffler / B & M transmission cooler / Quadratec Ultimate Front Floor Liners / Off Road Heroes Soft Top / Daystar Hood latches and spare tire bump stops / Glass lens headlights with H-4 bulbs (stock in Japan) – headlight and fog bulbs changed to Sylvania Silverstars / Off Road guards for headlights, fog lights and tail lights / MS Plus Navigation System / rear seat removed (1st mod) / and other stuff I can’t remember now
Next: Change the junk Skyjacker Nitro shocks to Bilstein 5100s (on back order now per Dave at Northridge) and change the junk Skyjacker sway bar disconnects to JKS.
http://share.shutterfly.com/action/w...8AcOGjlq3YtGLj
http://www.vroc.org/view_profile.php?user_id=998
http://rogueownersgroup.com/MemberPage.aspx?id=10
Doing it on the left side in Kanazawa, Ishikawa Japan.
Riding a motorcycle is the only time in my existence when I can completely lose myself only to find myself.
It's not the destination.........
It's the ride!
AJ in Japan is offline   Reply With Quote
Unread 01-04-2011, 07:17 PM   #2
RockyClymer
RockyClymer's Avatar
The track bar would have little to nothing to do with control arms, however, the 3.5 inch lift is enough to increase your caster angle to the point of needing adjustment IMO. Hence, you can use adj uppers to slightly lengthen the CA or adj lowers to slightly shorten the CA. This is because the upper CA has a shorter length (arc radius) and lifting forces the top of the axle and Cs to the rear....Hope this helps you.
08 JK 23S - Colorado Jeep Club No. 204
Too much to list - see my profile for details on build
NRA Life member
"It takes a special kind of stupid to believe criminals will follow gun laws."
I do not consider myself a smartass. I point out the obvious, search for the truth, and speak fluent sarcasm. I am, by experience, an accomplished curmudgeon.
RockyClymer is offline   Reply With Quote
Unread 01-05-2011, 12:05 AM   #3
AJ in Japan
So I should go with uppers? Which ones do you recommend. They seem a bit pricey, but I don't want to get junky ones either.
AJ in Japan
Mods:
It's the ride!
Unread 01-05-2011, 02:26 PM   #4
aristobrat
2010 JK Wrangler
In addition to adjustable control arms, you also can use the AEV control arm drop brackets. These brackets remount your stock arms at different angles.
IMO,
PROS:
cheaper than control arms (US$99 vs US$300+)
addresses camber issue ("flightly" feel) caused by bigger lifts
increases anti-dive, which helps with braking performance
helps ride-quality by directing more of the force from impacts (bumps, etc) into shocks vs. the frame
CONS:
leaves your front control arms mounted about an inch lower than the stock position
designed for 3.5"/4.5" lifts, not adjustable if you decide to run a lift that's bigger/smaller
There's some more detailed info over at http://jeepin.com/news/aev_brkts
Going back to your orig question, unless you're having an issue with your JK feeling "flighty" at higher-speeds, I wouldn't say that new control arms are absolutely required?
aristobrat is offline   Reply With Quote
Unread 01-05-2011, 03:15 PM   #5
RockyClymer
I don't know about others experience, but there is no way I would use the drop brackets...as is, my lower brackets get beat up enough where they are at...lowering them is asking for problems IMNSHO when rock climbing...
NRA Life member
Unread 01-05-2011, 04:37 PM   #6
aristobrat
2010 JK Wrangler
Unfortunately, my JK's 95% on-road, and the rock crawling around here is medium-hard at its worst. I think I'm the ideal use case for control arm drop brackets. I'd def reconsider them if I was seriously into crawling, but after a summer of VA/NC/PA wheeling, they've not posed any issues.
