DIY Jeep Hood Latch - Page 2 - JeepForum.com
post #16 of 50 Old 11-22-2013, 08:21 AM
R3dRid3r
Cleaver fix. I haven't notice a flutter on my new '13 but guess one can develop over time. Need these ideas in case it does.
"You'll Shoot Your Eye Out"
R3dRid3r is offline
post #17 of 50 Old 11-22-2013, 09:05 AM
Cooneys08JK
Cooneys08JK's Avatar
Originally Posted by JIMBOX View Post
Sorry it didn't work for, but
Read post #8, it's notta wifes tale-
JIMBO
I read your post. I thought the rubber gasket idea was great. I think that is what has prevented the flutter and not the removal of the hood spring. I am just going by my experience. Removing the spring did nothing. I wish I knew about the rubber gasket idea! Next time
'08 Black 2door JK- DD
'99 Chilli Pepper XJ- Wheeler- BFG ATs, 2 " BB + bolt on stuff
Cooneys08JK is offline
post #18 of 50 Old 11-22-2013, 09:08 AM
Cooneys08JK
Originally Posted by bcbass51 View Post
Removed the spring on my 2007 right after I got it and haven't had any hood flutter at all! Not a wives tale!
Then you are lucky! Didn't have to spend any money
Do you still have the air damn on?
post #19 of 50 Old 11-22-2013, 01:26 PM
Godholio
It all depends on the relative speed of the wind under there. Lots of people still have problems after removing the spring.
Utah Jeep Crew #148
No powerball here? How am I supposed to finance the mods?!?
'12 Sport...miss my YJ for all the wrong reasons though
Godholio is offline
post #20 of 50 Old 11-22-2013, 02:27 PM
JIMBOX
Heh Heh, you're probably right, but
I have an old box full if different rubber gasket lengths I bought years ago, when restoring one of my Dodge Ramchargers and the rubber trunk gasket mat'll just looked RIGHT for that job and it was--
Jeeps is money takers-
JIMBO
Yellow Jeep No. 683
--YA GOTTA HAVE CLASS--
JIMBOX is offline
post #21 of 50 Old 11-22-2013, 03:22 PM
ncb
Seems like the air going through the radiator or under the front bumper pushing against all the square inches of the hood would be the cause of lifting. Mine still bounces with out the little spring.
ncb is offline
post #22 of 50 Old 11-22-2013, 03:42 PM
JIMBOX
Well, thats a good point, I guess thats what the stock "AIRDAMs" main purpose is--however
Most ofus have already removed that and the mechanical hindrances/radiator will slow down the air velocity/vertical mass-and the air velocities at the hood front/side edges is still at 60/70/80 mph-
Now on mine, I don't have the plastic airdam, but do have a forward skidplate that directs air DOWN and my radiator airflow is hindered by the A/C condenser/Aux cooler and I've got the front hood forward "LIP" gasket-
Now, if you want to figure pure airflow/velocity/mass/lift capacity/hood mass/weight/reciprocating flutter capacity--you'll have one answer-
My hood doesn't flutter at any legal freeway speed and that includes crosswinds /w oncoming 18 wheelers !
Smokemifyougotem
JIMBO
Yellow Jeep No. 683
JIMBOX is offline
post #23 of 50 Old 11-23-2013, 08:25 AM
SoK66
2009 JK Wrangler
Removing the hood spring does not work. I feel like that is some old wive's tale. I had horrible hood flutter after removing my air damn on a rock. I tried removing the spring. No change, at all. So I bought the Daystars from Amazon, reinstalled my hood spring and have had 0 flutter, even in very windy conditions. It doesn't move at all. I forget all about what I was going through until I see threads like this. Daystars also do not bend the hood. That is just false. Op, your's look great! I actually like that look better than the Daystars, it reminds me of the Drake hood pins. Nice job!
Beg to differ. Removing the hood spring was a 100% fix for me. Further, the Daystars DO pull the hood corners into a bend. There is insufficient support under the latches to brace against the Daystar's increased force.
Jeeps: Where my 401(k) went to die!
SoK66 is offline
post #24 of 50 Old 11-23-2013, 03:26 PM
Godholio
Just because a symptom goes away doesn't mean it's cured.
Lack of a problem isn't proof that the problem doesn't exist. If it worked for you, great. It's not a bad first step. But you can't point to yours and say "It fixed this one so you're wrong!" to someone who's still having the problem. That's no different than if I argued with people who need 3.6 head replacements just because mine hasn't started the death-tick yet.
Utah Jeep Crew #148
Godholio is offline
post #25 of 50 Old 11-25-2013, 09:13 PM
SoK66
2009 JK Wrangler
Originally Posted by Godholio
Just because a symptom goes away doesn't mean it's cured. Lack of a problem isn't proof that the problem doesn't exist. If it worked for you, great. It's not a bad first step. But you can't point to yours and say "It fixed this one so you're wrong!" to someone who's still having the problem. That's no different than if I argued with people who need 3.6 head replacements just because mine hasn't started the death-tick yet.
Removing the hood spring has worked for many people with the issue, that's how we learned about it and it worked for us. Problem solved.
SoK66 is offline
post #26 of 50 Old 11-26-2013, 04:42 AM
TheBoss
To the op , nice work! I cheaped out and put in Daystars at around 10, 000 miles. Up until that point I thought maybe they stiffened the rubber for the 2012's , but they wear out just like the others.
TheBoss is offline
post #27 of 50 Old 11-26-2013, 06:20 AM
Cooneys08JK
Originally Posted by SoK66
Remloving the hood spring has worked for many people with the issue, that's how we learned about it and it worked for us. Problem solved.
You can't just finish your post with blanket statements "Problem Solved". Just as many of us have tried to remove the hood spring and still had flutter. Me included. Obviously that is not a fix for all. I put my hood spring back in after I installed the Daystars and my hood hasn't moved. If your hood spring theory is correct shouldn't my hood be fluttering again??
Similar to, I got death wobble on my ride home today. Swapped in a new steering stabilizer..problem solved.
post #28 of 50 Old 11-26-2013, 07:56 AM
Jiblet
I can't remember the last time I had hood flutter. Not since it was new.
The only thing I did to that area was grill inserts. Maybe that is why I don't get the flutter anymore.
I think I have the metalcrafters set. One piece unit.
Jiblet is offline
post #29 of 50 Old 11-26-2013, 09:04 AM
TheBoss
I have DIY inserts that have been in since it was new, but the hood flutter and buffeting still crept up with time. I live near some windy flat lands so that may have stressed the stock rubber prematurely.
TheBoss is offline
post #30 of 50 Old 11-26-2013, 10:18 AM
Godholio
Hey guys, I plugged that water leak with some duct tape! Problem solved.
Utah Jeep Crew #148
Godholio is offline
