Discount Tire mounting 12.5 tire on 7.5 rim - Page 2 - JeepForum.com
post #16 of 24 Old 05-31-2013, 10:16 PM
WhiteOut
WhiteOut's Avatar
This is why you need "a guy".
My tire guy will mount any tire I show up with to any tire I have, plus I get it cheap.
WhiteOut is offline
post #17 of 24 Old 06-13-2015, 08:52 AM
Dovi82nd
I found some 35"s that are 285, could I fit them on the stock rims? and if so someone told me that if I were to get 35" i would lose power
Dovi82nd is offline
post #18 of 24 Old 06-13-2015, 10:30 AM
jwmbishop
Accidental Obfuscator
jwmbishop's Avatar
2011 JK Wrangler
Simple answer yes and yes.
I have two sets of tires - on the 7.5 rim I dont care much for the 35" AT tire - it ends up with a lot more sidewall deflection. The increased slip angle makes at speed turns feel lazy (under-steered entry) to me. Not enough that I've taken em off yet (total body roll is still not trying to overcome the tire enough to worry me). And honestly as my on road set - i've never aired down below 23 - my cold PSi is 28 - at 30 cold it grows to 34 and the pyrometer shows me hot center.
But my off road set (and yes I know its a different tire but they match load rate) is 35 PitBulls on 9" and the feel is a ton more responsive (less mush when going into a curve at 65) to me.
Yes a larger diameter tire changes your final gear ratio so engine torque is not being multiplied at the same rates. It will feel more underpowered at the high demand times - but carry more momentum in the cruise and scrub velocity faster in decel. SO as you loose acceleration multiplication - make it up by driving style that uses momentum more, or regear. I LOVE gearing and its feel. SO for me 35 and 5.13 was done at same time - with a plan for 33" on 7.5 road set (my driving style is to hit both ends - accelerate hard carry momentum and use the brake hard in an automatic - yes I go through brakes in about 80% of fleet average miles lower 20 percentile) - but that changed when I got five good Duratrac 35s free...
J Wm Bishop EA, ASADE
The wagon should, of course, be as light as possible, but strength should not be sacrificed to lightness, for on any but the regularly traveled roads, the wagon will get many a
jwmbishop is offline
post #19 of 24 Old 06-14-2015, 08:46 PM
Dovi82nd
How noticeable is the difference... its a jeep so honestly Im not expecting a 0-60 in under 10 seconds but i do like zipping out real quick. Is it very noticeable or just a little different, on a scale of 1-10 where 10 is a significant difference. Also whats the different in MPG?
Dovi82nd is offline
post #20 of 24 Old 06-15-2015, 06:45 AM
jwmbishop
jwmbishop's Avatar
2011 JK Wrangler
Keep in mind I did not experience under geared - I mounted 35s while it was getting gears so both went at same time. But it was a zippy little bastard coming home on stock 32s with 5.13! Try them. They're only tires, not a lifetime commitment - you can probably find a swap out if you don't like em... That's how I got my 35 street tire - traded my 32swhhels and all with a guy who had 35s on the 3.21 stick sport and hated it. And I think the throttle management on these things makes undergearing feel worse than really is. Understand it comes down to expectations - so for me its up around 8 on the scale, my brother is a very mellow driver and would probably put it around 6. Grandma would not even notice. ��
post #21 of 24 Old 06-15-2015, 10:08 AM
duneslider
I had 15x7 wheels for a long time with 35x12.5 tires. I didn't have any issues. The wheels I have now are 15x8 with 35x12.5. I didn't notice any difference between the wheels.
I run 26-28 psi.
duneslider is offline
post #22 of 24 Old 06-15-2015, 06:27 PM
Dovi82nd
My stock tires are 31"s and I'm guessing that you lost the zippy feeling AFTER you switched the stock tires out?
and to dune slider thanks very much! this is very helpful!
Dovi82nd is offline
post #23 of 24 Old 06-16-2015, 09:23 AM
riddoch
The real question is how did they react to your wheel spacers? I assume you're running them with stock rims and no lift? I've had retailers refuse to work on previous cars because they just thought I had spacers (I didn't) and I've heard discount tire can be sticklers about it as well. Maybe you just took the wheels off and had the tires mounted? I want 295 trail grappers with stock rims and DT is the only nitto dealer I can find.
riddoch is offline
post #24 of 24 Old 06-17-2015, 11:22 AM
Dovi82nd
I have a two inch budget boost. I am using stock 17" rims. I was just going to buy the tires them selves and take them to get balanced at the MWR Auto Shop on Ft. Belvoir
Dovi82nd is offline
Will discount tire upgrade my tires? KristaVsMi Wrangler General Discussion 20 05-17-2010 08:27 PM
12.50 tire mounting question GlennM YJ Wrangler Technical Forum 16 05-17-2009 05:02 AM
Who is crazy? Discount Tire, American Racing, or me? Wazinga TJ Wrangler Technical Forum 3 08-13-2007 04:24 PM
Un-Mounting a Tire? bruker TJ Wrangler Technical Forum 17 06-14-2007 09:01 PM
Tire mounting NEWtoTHEjeepLIF TJ Wrangler Technical Forum 10 06-18-2006 02:35 PM
