Discount Tire mounting 12.5 tire on 7.5 rim - JeepForum.com
post #1 of 24 Old 08-06-2010, 07:31 AM Thread Starter
jarrod318
I just dropped my Jeep off to Discount to mount my new Nitto Trail Grapplers. The tech said that i am an idiot for tryign to mount a 12.5 tire on a 7.5 rim. I have done my homeowork and seen many Jeep running this set up with no issues so i was pretty angry. After speaking with the manager and showing the forum he made me sign a waiver. They did freak me out a bit though. Will i have any issues with this set up? The Trail Grapplers are rated E grade so the sides are stiff if that makes a difference.
jarrod318 is offline
post #2 of 24 Old 08-06-2010, 07:33 AM
MilitaryJK4455
2010 JK Wrangler
No... As long as you arent trying to run the max tire pressure (dumb to do it the first place) all that is going to do is give you a tighter bead at lower pressure... Ask them what size rim they would recommend when your only running 10 PSI with that tire and see how dumb they feel then.
MilitaryJK4455 is offline
post #3 of 24 Old 08-06-2010, 07:36 AM Thread Starter
jarrod318
Thats what I was thinking too. What PSI would you recommed for the 35 inch Trail Grapplers?
post #4 of 24 Old 08-06-2010, 07:36 AM
tomwbates
2009 JK Wrangler
What pressure would you recommend running them at for Highway driving?
'09 JK Unlimited Red Rock
tomwbates is offline
post #5 of 24 Old 08-06-2010, 07:40 AM
MilitaryJK4455
2010 JK Wrangler
Start at 30 (I run about 29 on my BFG's) and do the chalk test or adjust according to whether you want a stiffer or softer ride... Best to do the chalk test for even wear though... It all depends on how heavy your Jeep is according to bumpers/winches/lift and whether its a 2dr or 4dr... 30 is a good start pressure though. Off road, I would air down to 10-15psi if needed, i.e. sand, rocks, so on and so forth.
post #6 of 24 Old 08-06-2010, 08:24 AM Thread Starter
jarrod318
Nice, thanks again Military.
post #7 of 24 Old 08-06-2010, 08:28 AM
Blu-Jacket
2009 JK Wrangler
While you're at Discount tire have them use the finger plates for balancing. They usually have them available.
Blu-Jacket is offline
post #8 of 24 Old 08-06-2010, 08:31 AM
SaxManClay
Even myself knowing a lot about tires, it's always a pain in the butt when these "professionals" think they know everything. I had my tires balanced at NTB, and they even gave me a hard time for having my tires at 28 psi and said, "that's good for driving in the sand but not on pavement". Really!? They recommended them at 33 psi. I didn't want to argue with them, but I did tell them that if they REALLY think that 5 psi is going to make a difference be my guest. I later put them back at 28.
My Jeeps name is TUG!
What I'm all about.
SaxManClay is offline
post #9 of 24 Old 08-06-2010, 08:47 AM
RockyClymer
RedRock4Wheeler
RockyClymer's Avatar
I happen to have had good experiences at Discount - on the other hand, my recent experience with selling a set of USED 32s to a person who took them to Discount or Wallmart and they would not mount them - too used they said. These "professional" tire people seem more interested in selling new tires and rims - no money to be made in mounting used tires on old rims! Sign of the economy if you ask me...anyway, mount them, run them, use them...ignore the sales pitch.
08 JK 23S - Colorado Jeep Club No. 204
Too much to list - see my profile for details on build
16 JK Rubi with all the trimmings
NRA Life member
"It takes a special kind of stupid to believe criminals will follow gun laws."
I do not consider myself a smartass. I point out the obvious, search for the truth, and speak fluent sarcasm. I am, by experience, an accomplished curmudgeon.
RockyClymer is offline
post #10 of 24 Old 08-06-2010, 01:44 PM Thread Starter
jarrod318
Ok so they installed the tires and we are GTG. The lift goes on tomorrow which is a 3.25 RC.
post #11 of 24 Old 08-06-2010, 02:58 PM
MilitaryJK4455
2010 JK Wrangler
I hate to say it.... But I told ya so Just kidding man... They look great! You will like it even better once the lift is on... You didnt have a problem with the rear tires hitting the pinch seam?
post #12 of 24 Old 08-06-2010, 03:03 PM Thread Starter
jarrod318
HAHAH, yes you did.
It is very close to the pinch seam but I have about an inch. I will post pix after the lift is done tomorrow.
post #13 of 24 Old 08-06-2010, 03:08 PM
MilitaryJK4455
2010 JK Wrangler
Originally Posted by jarrod318 View Post
HAHAH, yes you did.
Cool beans man
post #14 of 24 Old 05-31-2013, 09:51 PM
jacobcasillas
i work at discount tire and the only reason they want you to get a bigger rim is because the bead of the tire can litteraly blow off the tire from the rim and act as a mini bomb if you hit a bump hard. Ive worked on jeeps (and own one myself) where this has happened. as long as you dont put it to the max tire pressure ull be fine. but as for them filling up ur tire pressure. most of those guys don't know what the hell to fill up a tire lol. just make sure your not over/under inflating your tires cause ull screw up the tire itself. 23-30 is perfect for on road and 7-15 is perfect for on road.
jacobcasillas is offline
post #15 of 24 Old 05-31-2013, 10:05 PM
COLOUXJ
2010 JK Wrangler
They do it because of the liability. Tire manufacturers recommend 8.5" or more to mount a 12.5 tire. Imagine if a company did this without saying anything someone had a crash because a bead came off the wheel and then showed that to the courts. Bad news for said company. You are lucky that they let you sign a waiver. The discounts up in my area will refuse to do that work.
Its not to sell tires. I have seen way to many people put used tires on and then run them past the chords on the tire. As I said above its all liability and the company protecting itself. why would you want to risk something like that when the only thing touching the road on your Jeep are those tires.
COLOUXJ is offline
Will discount tire upgrade my tires? KristaVsMi Wrangler General Discussion 20 05-17-2010 08:27 PM
12.50 tire mounting question GlennM YJ Wrangler Technical Forum 16 05-17-2009 05:02 AM
Who is crazy? Discount Tire, American Racing, or me? Wazinga TJ Wrangler Technical Forum 3 08-13-2007 04:24 PM
Un-Mounting a Tire? bruker TJ Wrangler Technical Forum 17 06-14-2007 09:01 PM
Tire mounting NEWtoTHEjeepLIF TJ Wrangler Technical Forum 10 06-18-2006 02:35 PM
