Disconnects install - JeepForum.com
post #1 of 6 Old 04-22-2013, 10:58 PM Thread Starter
robski85
Disconnects install
So I recently purchased the teraflex quick disconnects and going to install them tomorrow. I have a 2012 2 dr and I'm currently running 285's km2 with tuff country 2" in the front and 1" in the rear spacers. I'm curious if ill run into any issues with my brake lines once all is said and done and I'm disconnected at full flex? Also, any recommendations on a synthetic grease for the zerks? Thanks for the help!
robski85 is offline
post #2 of 6 Old 04-22-2013, 11:03 PM
RockyClymer
RedRock4Wheeler
RockyClymer's Avatar
When you install them, jack up the frame and let the axle drop with them disconnected and see what play you have in the brake lines? I used white lithium grease in my disconnects when I had them...
08 JK 23S - Colorado Jeep Club No. 204
Too much to list - see my profile for details on build
16 JK Rubi with all the trimmings
NRA Life member
"It takes a special kind of stupid to believe criminals will follow gun laws."
I do not consider myself a smartass. I point out the obvious, search for the truth, and speak fluent sarcasm. I am, by experience, an accomplished curmudgeon.
RockyClymer is offline
post #3 of 6 Old 04-23-2013, 07:50 AM
XTJake
ExtremeTerrain.com
XTJake's Avatar
Robski,
Before you attach them finally, just flex the Jeep out and check all of your clearances. This will also allow you to check your bumpstops and make sure you wont put a tire into your fender.
Let me know if you have any other questions. I'll be happy to help.
-Zach
Jake R. |
Off-Road Outfitters
Toll Free: 800-988-4605 | Mon-Fri 10AM-6PM EST
Free Shipping on Orders Over $75!
PM me for our JeepForum Discount Code (must have 25 posts) or Price-Matching!
XTJake is offline
post #4 of 6 Old 04-23-2013, 08:09 AM
TheBoss
With a 2012-2013 you may need to disconnect the brake line bracket at the axle, it is bolted to the spring perch.
TheBoss is offline
post #5 of 6 Old 04-23-2013, 06:57 PM Thread Starter
robski85
Well got them installed pretty quick and easily. Going try them out tomorrow and see how much play in the lines I get at full flex... Ill throw up some pics tomorrow w them connected vs. disco'd... Also need to pickup a rubber mallet and add it to my tool box... Little extra persuasion to get them back on haha
robski85 is offline
post #6 of 6 Old 04-24-2013, 07:03 AM
XTJake
ExtremeTerrain.com
XTJake's Avatar
Robski,
It's always best to make sure you're putting them back on while on a level surface. That will make it much easier and you won't have to hammer them on.
-Zach
Jake R. |
Off-Road Outfitters
XTJake is offline
