Dipstick reading high - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > Dipstick reading high
FS: Wranger BRIGHT License Plate LED! Just $3! Great valueBest deals on Yukon Gears at JeepHut.comNeed Ace Engineering products? JeepHut has you covered.
Unread 06-26-2013, 04:45 PM   #1
Cosmobull
Has anyone noticed if the oil dipstick reads high on the pentastar? I put in just shy of 6 quarts and it is reading 1/2" over the top of the metal marker. I did let it drain with the filter out for a good 15 minutes. I ended up taking a quart out and it still was reading over the top hash mark.
Cosmobull is offline   Reply With Quote
Unread 06-26-2013, 05:22 PM   #2
RockyClymer
RedRock4Wheeler
RockyClymer's Avatar
Turn the engine over for half a minute or so to fill the filter. If it is still high, drain some out. Do not run overfull unless you want a ring job IMO.
08 JK 23S - Colorado Jeep Club No. 204
Too much to list - see my profile for details on build
NRA Life member
"It takes a special kind of stupid to believe criminals will follow gun laws."
I do not consider myself a smartass. I point out the obvious, search for the truth, and speak fluent sarcasm. I am, by experience, an accomplished curmudgeon.
RockyClymer is offline   Reply With Quote
Unread 06-26-2013, 05:27 PM   #3
Cosmobull
I just took it in for an oil change, I didn't want to run high and at the same time I didn't want to run low if the dipstick was just wrong. I have yet to check the dipstick after they finished. I have a feeling something is just fishy with the dipstick since I drained every last drop out and put in roughly 5.75 quarts.
Unread 06-26-2013, 07:05 PM   #4
pismo61
I have always put the amount the owner manuals say for oil and filter changes and never had a problem.They should state dry fill or refill if theres a big difference.I think.
2000 XJ 4 door Auto.
pismo61 is offline   Reply With Quote
Unread 06-27-2013, 10:28 AM   #5
SilverStreaker
Originally Posted by Cosmobull View Post
I have a feeling something is just fishy with the dipstick...
You may just be one of the fortunate ones who has a longer dip stick thus the deeper you can insert it the wetter it will be. Lucky Bastard
On a side note, you may want to get it checked if it's fishy
My Jeep - 2012 Wrangler Unlimited Sport S
[URL="http://www.jeepforum.com/forum/f22/its-started-silverstreaker-jk-build-thread-1306308/"]SilverStreaker Build Thread[/URL]
My Wife's Jeep - 2007 Grand Cherokee - only mod - K&N Cold Air Intake system
SilverStreaker is offline   Reply With Quote
Unread 06-27-2013, 11:19 AM   #6
Cosmobull
Well after the dealership did the oil change it is over the top of the metal on the dip stick, I'm guessing that's my problem. Not sure if this is a common problem but I would have run a quart low if I were to rely on the dipstick- not good.
Unread 06-27-2013, 11:49 AM   #7
ncb
Maybe the dipstick is too long. You could compare the dipstick to another to see how it compares. That doesn't sound right, LOL.
ncb is offline   Reply With Quote
Unread 06-27-2013, 07:07 PM   #8
Butterjeep
I've had the same problem with my oil level! Maybe we should measure our dipsticks and compare.
2012 JK
2014 WK2
Butterjeep is offline   Reply With Quote
Unread 06-27-2013, 08:52 PM   #9
Cosmobull
I'll measure mine from the o-ring to the bottom of the metal when I get home.
Unread 06-27-2013, 10:16 PM   #10
Cosmobull
Mine is exactly 28" from the under the o-ring to the very bottom of the metal end. Anyone else care to measure?
Unread 06-28-2013, 08:23 AM   #11
Wrigley
You are better off being a quart low than being a quart too much. Rule of thumb I always go by: I drain and then service to one quart less than called for. Start the motor and let it run for about 5 mins then shut it off and check the level in about 5 mins. Adjust oil level from there.
Mike
Wrigley is offline   Reply With Quote
Unread 06-28-2013, 11:09 AM   #12
Cosmobull
Could this have something to do with the filter position? If I check my oil 5 seconds after shutting it off it seems right but then it starts going over full, maybe due to the filter not retaining any oil?
Unread 06-28-2013, 06:23 PM   #13
Butterjeep
I'll go measure mine and post. 2012 jk with 3.6, be back in a few min.
2012 JK
2014 WK2
Unread 06-28-2013, 06:30 PM   #14
Butterjeep
28 inches here and I have noticed that mine is always way overfilled too.
2012 JK
2014 WK2
Unread 06-28-2013, 07:04 PM   #15
Cosmobull
Anyone have a measurement of one that doesn't read way over full??
