Differential lube fluid? - JeepForum.com
post #1 of 84 Old 02-13-2011, 01:14 PM Thread Starter
taoshum
When a dealer in PHX did the latest recall they told me that I needed to change the front and rear differential lube fluid, every 15,000 miles... especially after the first 15,000 miles.
I told 'em I didn't have time when I was there 'cuz I wanted to find out if it's true? Is it? The service bay guy says it's because of the limited slip differential.
Geezer from NM
"Wisdom isn't cheap; we pay for it with pain
taoshum is offline
post #2 of 84 Old 02-13-2011, 01:29 PM
McKBrew
JK Wrangler
The time requirements for changing differential fluid are going to vary based on driving conditions (do you tow, off road, etc...)
I just did my rear differential at slightly over 15K and it needed it. FWIW, you can do this service in your own garage or driveway (if you can get away with it). It is pretty simple.
McKBrew is offline
post #3 of 84 Old 02-13-2011, 01:35 PM
ncb
It's an easy task. Most auto parts stores will take the used oil.
ncb is offline
post #4 of 84 Old 02-13-2011, 01:39 PM
RockyClymer
RedRock4Wheeler
RockyClymer's Avatar
If you do any off-road or towing definitely needed and also check the OM. Yup, easy to do with a small kit I got at the local auto parts shop, suction it out, fill it up, and they take the old fluid for free.
08 JK 23S - Colorado Jeep Club No. 204
Too much to list - see my profile for details on build
16 JK Rubi with all the trimmings
NRA Life member
"It takes a special kind of stupid to believe criminals will follow gun laws."
I do not consider myself a smartass. I point out the obvious, search for the truth, and speak fluent sarcasm. I am, by experience, an accomplished curmudgeon.
RockyClymer is offline
post #5 of 84 Old 02-13-2011, 01:54 PM
ncb
Why use suction for the change when the diffs have drain plugs? What's the OM?
ncb is offline
post #6 of 84 Old 02-13-2011, 02:14 PM
McKBrew
JK Wrangler
I did a full change with mine.
Drained the differential, pulled the cover, cleaned everything with brake cleaner and then refilled.
Make sure you pay attention when draining and think you have the drain bolt removed when it's really only the fill bolt. The resulting oily sludge that pours out when you knock the cover off with the BFH isn't too pleasant. (I don't know anyone who actually did this, I'm just sayin")
McKBrew is offline
post #7 of 84 Old 02-13-2011, 02:41 PM
RockyClymer
RedRock4Wheeler
Maybe your diff cover has a drain plug, mine does not front or rear, that I could readily see. Just followed the maintenance manual though....guess there is a problem sometimes in just RTFM...is there a plug in the housing itself? Always willing to learn.
NRA Life member
post #8 of 84 Old 02-13-2011, 04:01 PM
saharac
what brand fluid do you guys recommend?? also synthetic or not??
saharac is offline
post #9 of 84 Old 02-13-2011, 04:02 PM
PanthersFan
If you have JK axles, you have differential drain plugs. They are located at the bottom of the housing. Not on the cover.
You need a 3/8 socket extension the back them out.
THE Conventions of a number of the States, having at the time of their adopting the Constitution, expressed a desire, in order to prevent misconstruction or abuse of its powers, that further declaratory and restrictive clauses should be added: And as extending the ground of public confidence in the Government, will best ensure the beneficent ends of its institution.
PanthersFan is offline
post #10 of 84 Old 02-13-2011, 04:07 PM
McKBrew
JK Wrangler
Some people swear by synthetics, I went with Mobil Brand Gear Fluid only because of the cost.
McKBrew is offline
post #11 of 84 Old 02-13-2011, 04:17 PM
RockyClymer
RedRock4Wheeler
OK, guess I did not see them - sounds like need to insert the end of a 3/8 drive then....tnx, live and learn I hope.
NRA Life member
post #12 of 84 Old 02-13-2011, 04:30 PM
McKBrew
JK Wrangler
Yep, definitely beats the hell out of trying to suck them out.
McKBrew is offline
post #13 of 84 Old 02-14-2011, 07:47 AM Thread Starter
taoshum
Are there any "additives" needed for the limited slip feature? The d/stealer said it's a "special" fluid for limited slip?
Geezer from NM
taoshum is offline
post #14 of 84 Old 02-14-2011, 07:49 AM
20181c
2009 JK Wrangler
I used Royal Purple front & rear. Easy job to do yourself.
09 Rubi Unlimited Stone White
ORH liner, Cooltech, CB, Weathertech, Thule Track system.
20181c is offline
post #15 of 84 Old 02-14-2011, 07:53 AM
mrchips59
Yes you need to use oil that has a Limited Slip additive. Try Royal Purple Synthetic and it has the additive included.
mrchips59 is offline
Lube Lockers Differential Cover PSYCH0 JK Wrangler Technical Forum 26 10-21-2010 07:19 AM
Lube Locker differential gaskets phylodog TJ Wrangler Technical Forum 6 09-15-2009 07:08 AM
differential lube question?????? dabrogger TJ Wrangler Technical Forum 7 05-11-2009 11:31 PM
Differential lube Rush TJ Wrangler Technical Forum 10 05-22-2006 08:45 AM
Differential lube every 15k miles? Westy TJ Wrangler Technical Forum 14 04-24-2005 03:06 PM
