Differential Fluid Change - Page 5 - JeepForum.com
post #61 of 73 Old 02-29-2012, 02:48 PM
wheels082
2010 JK Wrangler
I use have been using Amsoil gear lube in my Jeeps for years, including the JK. No additional additives are required with Amsoil.
wheels082 is offline
post #62 of 73 Old 03-08-2013, 07:23 PM
mikesewell
Someone mentioned using a Fluid Pump? What brand / Where does one pick this up?
Someone mentioned in this thread -- that using a Fluid Pump is the way to go and to have one for all the different fluids. My question is what is the name of the pump? Brand? Where do you get it? About to do the diff fluid change and I could see where trying to get these bottles to tip could be a big problem.
mikesewell is offline
post #63 of 73 Old 03-09-2013, 05:36 AM
Prot
Prot's Avatar
2014 JK Wrangler
The pump is usually right on the shelf in the store next to the gear oil.
2014 JKU Copperhead Pearl
Too many mods to list. Too awesome to sell.
Prot is offline
post #64 of 73 Old 03-09-2013, 06:19 AM
xzy
A lot of guys on bitog love synthetics but not for the diffs. Seems they think non synthetic is better in this application. I'm running 85/140 Castrol in the rear diff. Cost about $7.00 a quart.
xzy is offline
post #65 of 73 Old 03-09-2013, 10:11 AM
JeffinWesternWA
2010 JK Wrangler
If not towing, wouldn't 80W(75W) -90 be a bit better for mileage? that's a pretty thick brew, I prefer the syns (if not having to change often from water immersion), though I still add the Xysler Posi additive to my LS rear...The Mobil One 75W-90 gives me good service w/ an extended interval...(though I prefer the Red Line when I have an application thats stubborn or needs special attention)
JeffinWesternWA
JeffinWesternWA is offline
post #66 of 73 Old 03-09-2013, 04:31 PM
JIMBOX
I use the Valvoline 75w-140 in both diffs-
MOPAR even recommends a syn 75w-140 use, for off-road/HD and towing--
JIMBO
Yellow Jeep No. 683
--YA GOTTA HAVE CLASS--
JIMBOX is offline
post #67 of 73 Old 03-09-2013, 04:41 PM
Wavedatya
2010 JK Wrangler
80-90 front 75-140 rear with L S additive. I use amsoil in the rear. Regular cheap stuff in the front
I tow. I cheated last two times but will take dif cover off this spring and do the seals again.
OF4WD member #7523. Durham 4x4 member.
Wavedatya is offline
post #68 of 73 Old 03-10-2013, 06:21 PM
Prot
Prot's Avatar
2014 JK Wrangler
75-140 synthetic here in both my front D30 and rear D44. The synthetic helps with the temperature. Mopar recommends 75-140 for towing and severe duty. The shop that installed my 5.13 gears recommends synthetic 75-140. BTW, I am getting my rear differential rebuilt with a Yukon Zip Air Locker on April 2.
Prot is offline
post #69 of 73 Old 03-10-2013, 10:38 PM
OregonVette
The 2008 Jeep JK owners manual suggests that The additive is only needed for vehicles with the Optional TracLok. Iirc, all Saharas came from the factory with Trac Lok included.
As such, i use Lucas Oil full synth 75-90 because it already has the additives included. No additional additives are needed.
To change front diff fluid:
Unbolt 3/8 socket plug at bottom of diff.
Drain the stuff that stinks like dead animals
Put 3/8 plug back into diff. Tighten it.
Loosen and remove top 3/8 plug
add one quart of LucasOil 75-90
Put 3/8 plug back in the diff cover
Drive away...
How to change rear diff fluid:
add two quart of LucasOil 75-90
Put 3/8 plug back in the diff cover.
Drive away...
You can use a handy pump tube to squeeze the new lube into the diff. Very handy. They cost $5
You can also use different brands and oil weight, 75-90, 80-90, 85-140, 75-140 Dino or Synth. Whatever. People have their own preferences. Personally, I just go with the owners manual. Ymmv.
Originally Posted by smcutter View Post
It's hard to give you good advice at this point. It's almost like you're saying, "I want to have sex, but don't want to get her pregnant. I can't afford condoms, so for now I just want to use Saran Wrap. What brand would you recommend?"
OregonVette is offline
post #70 of 73 Old 03-11-2013, 10:50 AM
JeffinWesternWA
2010 JK Wrangler
I've found in the past, even though "no additive is needed that several manufacturers of lube advertise", that at least with Auburn Posi units, that factory LS additive is still needed as they will balk and bind a bit w/o it, so my advice is to add the xysler additive to any posi unit regardlesss of lube used...Overall if a gear set is noisy, binds, balks (tranny or rear) that Redline fluids have made a difference, otherwise I gow/ M1 forteh ease of finding it and price, I like 75w-90 as I don't tow or have any severre duty and try to squeeze every mpg possible ut of my JK, it's averaged 20.0 mpg in 21K+ miles, best of 22+ highway so far..
JeffinWesternWA
post #71 of 73 Old 03-13-2013, 07:59 AM
krysmondello
I have a JK 09 the rear differential is being replaced by the dealer under warranty, 42K miles, yours might be under warranty. Were your rear brakes bad?
krysmondello is offline
post #72 of 73 Old 03-13-2013, 09:05 AM
ferninaz
ferninaz's Avatar
I use 75-140 synthetic in both my front D30 with an Aussie Locker and rear D44 with the Limited Slip nonsense that Jeep goes with.
ferninaz is offline
post #73 of 73 Old 03-13-2013, 04:35 PM
SubAtomicGenius
2011 JK Wrangler
My best advice: if you are inclined to do WATER CROSSINGS on a regular basis - buy a 5-gallon pail of dino diff fluid. No matter what you do, if you are doing water crossings, your oil will get milky from water ingress. Dino oil (certified to the right APA spec) will provide the best lubrication at the best price for frequent diff oil changes.
Sure, the benefits of synthetic diff oil are nice until you get milky synthetic oil and have to change it out at 3-4x the cost.
SubAtomicGenius is offline
diff fluid , differential , differential fluid change , differential fluid level , JK Wrangler , maintenance , wrangler
How do you change your differential fluid? TJShadow TJ Wrangler Technical Forum 16 11-29-2009 06:58 AM
Differential fluid change....... npomm JK Wrangler Technical Forum 51 10-07-2009 10:42 PM
differential fluid change mfm22 TJ Wrangler Technical Forum 9 12-26-2006 12:19 PM
Differential fluid change mkalcevic TJ Wrangler Technical Forum 21 05-03-2006 02:47 PM
Differential fluid change bryris YJ Wrangler Technical Forum 16 04-17-2006 06:01 PM
