Differential Fluid Change - Page 2 - JeepForum.com
post #16 of 73 Old 01-05-2010, 08:55 AM Thread Starter
-Zona-
Originally Posted by dirtyjpwrangler View Post
one more question, is it totally necessary to use a torque wrench? or can you just use a regular wrench until the bolts are tight? I don't have a torque wrench...
I have a torque wrench and didn't use it, haven't had any problems so far.
Originally Posted by cherrybomb05 View Post
Or Zona because he reminds me of charlie sheen
-Zona- is offline
post #17 of 73 Old 01-05-2010, 11:06 AM
JLC08JK
What was I thinking?
JLC08JK's Avatar
The concern is with (Over Torque) and to not deform the sheetmetal cover.
You should tighten the bolts in sequence as you would a valve cover or a wheel. Do not over tighten, you are just trying to compress the gasket enough to form a good seal. You can do this by feel, I use a small wrench so I can better judge equal force used on each bolt.
Jim
JLC08JK is offline
post #18 of 73 Old 01-05-2010, 11:50 AM Thread Starter
-Zona-
In sequence? There are only two plugs for filling and two for draining.
-Zona- is offline
post #19 of 73 Old 01-05-2010, 12:27 PM
MattJK09
2009 JK Wrangler
Maybe he thought the pumpkin cover was removed???
09 X 23S Flame Red 2door, tinted, Black Rock 997's, BFG 32" MT's, grab handles, RR XHD front bumper,BW trail armor,4door springs up front, KC's
MattJK09 is offline
post #20 of 73 Old 01-05-2010, 12:38 PM
JLC08JK
JLC08JK's Avatar
I did
If you ever take off the cover, Do what I said
Otherwise, Neverminde
Jim
JLC08JK is offline
post #21 of 73 Old 01-05-2010, 12:53 PM
waterboarder
waterboarder's Avatar
Actually, all of the plugs are there to keep the fluid from coming out (:
I didn't use a torque wrench either.
waterboarder is offline
post #22 of 73 Old 01-06-2010, 09:26 AM
Layth
I am due to change diff fluid as well.
Did you guys drive around first to warm up the fluid before you dumped it? Will driving even warm up gear oil enough to make a difference?
Layth
Layth is offline
post #23 of 73 Old 01-06-2010, 09:29 AM
waterboarder
Yes. I see no reason not to.
Dunno, but I don't see how it could hurt.
post #24 of 73 Old 01-06-2010, 12:33 PM
JeffinWesternWA
2010 JK Wrangler
Fluid should be warm, warm fluid drains easier and holds particles and impuritities in suspension, allow to thoroughly drain and "flush"! (Just like motor oil), for first time removing drain/fill plugs, check to "see" if any threads are visible and write it down and re-tighten to approx same thread view vice a torque wrench. sometimes therre are places where a torque wrench doesn't fit or can't be pressured accurate. Think a 10 lb "bag of sugar or potatoes" when torqing and adjust, better a bit loose than tight!
JeffinWesternWA
JeffinWesternWA is offline
post #25 of 73 Old 01-06-2010, 01:00 PM
Layth
'Boarder,
I was going to ask you if there were any special procedures for our silver Saharas since it has already been established they are the fastest and most capable... Well maybe not, but it sounds good.
Layth
Layth is offline
post #26 of 73 Old 01-06-2010, 01:01 PM
waterboarder
Unfortunately, they also suck the most gas ):
post #27 of 73 Old 01-09-2010, 05:31 PM
dirtyjpwrangler
I accidentally combined 75W-90 and 75W-140 in the rear axle.. is this ok? is there any downside to using 140 instead of 90?
dirtyjpwrangler is offline
post #28 of 73 Old 01-10-2010, 12:51 AM
asknight
You just have 75W-115 if they're the same product otherwise.
asknight is offline
post #29 of 73 Old 01-10-2010, 06:51 AM
jonnied
Don't forget to use teflon tape or pipe dope on the plug threads. I always use the teflon tape.
jonnied is offline
post #30 of 73 Old 07-29-2010, 11:46 PM
NYNurse
2010 JK Wrangler
LOL! Thanks for the laugh
Mobil might consider doing a special "dirtyjpwrangler" blend. Best of both worlds..
2010 Jeep Wrangler Sport
2005 Jeep Liberty
NYNurse is offline
diff fluid , differential , differential fluid change , differential fluid level , JK Wrangler , maintenance , wrangler
How do you change your differential fluid? TJShadow TJ Wrangler Technical Forum 16 11-29-2009 06:58 AM
Differential fluid change....... npomm JK Wrangler Technical Forum 51 10-07-2009 10:42 PM
differential fluid change mfm22 TJ Wrangler Technical Forum 9 12-26-2006 12:19 PM
Differential fluid change mkalcevic TJ Wrangler Technical Forum 21 05-03-2006 02:47 PM
Differential fluid change bryris YJ Wrangler Technical Forum 16 04-17-2006 06:01 PM
