Difference in engines between Rubis and non Rubis? - JeepForum.com
post #1 of 6 Old 11-20-2012, 02:49 PM Thread Starter
Roo2
Hey guys,
I'm looking at trying to buy a JK Rubicon where the engine doesn't work and then find another JK Rubi if possible but its going to be easier to find a non Rubi that has been rear ended and get it for cheap then swap the engines. I would assume that the engines are the same but I'm trying to figure out if there are any issues i would run into? Like maybe with the swaybar disconnect components/ wiring harnesses or the locking axle components/wiring etc. If anyone know of any problems that would arise please let me know. I plan on trying to get 2 JK's of the same year but again that limits my choices. Also if the bad engine is a 3.6 I would make sure the good engine is a 3.6 , same for the 3.8. I'm open to all comments and ideas.
Just trying to get another JK on the road.....and soon the trails
Thanks Guys!!
Roo2 is offline
post #2 of 6 Old 11-20-2012, 02:52 PM
BadTrainDriver
No difference in the engines.
2012 Jeep Wrangler Unlimited Rubicon
Stock, for now...
BadTrainDriver is offline
post #3 of 6 Old 11-20-2012, 03:01 PM Thread Starter
Roo2
What about transmissions? I've read manuals have longer driveshafts.
Roo2 is offline
post #4 of 6 Old 11-20-2012, 03:07 PM
RockyClymer
RedRock4Wheeler
RockyClymer's Avatar
Not sure about all years, but for the 08, the drive shafts are the same between manual and auto. There is a tail shaft spacer in the auto that makes it that way.
08 JK 23S - Colorado Jeep Club No. 204
Too much to list - see my profile for details on build
16 JK Rubi with all the trimmings
NRA Life member
"It takes a special kind of stupid to believe criminals will follow gun laws."
I do not consider myself a smartass. I point out the obvious, search for the truth, and speak fluent sarcasm. I am, by experience, an accomplished curmudgeon.
RockyClymer is offline
post #5 of 6 Old 11-20-2012, 07:48 PM
thedirtman
thedirtman's Avatar
Why dont you just pick up a used motor. Lots of hemi's going into jeeps and there is ample supply of good used 3.8 motors.
If you learned something new today, you had a good day.
thedirtman is offline
post #6 of 6 Old 11-20-2012, 07:50 PM
Coolcatracing
The JK rear shafts are all the same length from 07-11, given 2 door or 4 door remains the same. The only difference there was the Rubi's had a different transfer case and of course the axles. The sway bar disconnect isn't an issue since its just a box mounted to the bar itself. If you need an engine all JK's from 07-11 will work fine.
08 Unlimited Rubicon 6 speed, 315/70-16 Kelly TSR, 1.5" Spidertrax spacers factory Moab's, Rubicon Express Flex arm 3.5" lift, Smittybilt XRC front bumper with D-rings, Body Armor Extreme rock slider steps, AEV snorkel, trimmed fender flares, Hella 8" HID driving lights
Coolcatracing is offline
