Diff Ratios For Standard vs Auto Trans - JeepForum.com
post #1 of 6 Old 10-13-2017, 12:34 AM Thread Starter
tj2kj
Thinking about swapping my ZJ for a new JK Rubicon. Noticed on the build sheets that the standard trans comes with 4.10 axles while an auto trans comes standard with 3.73 - even with the tow package. Is there a reason for this other than to make more money charging you an additional $700 to go back and add 4.10 axles?
14 JK Unlimited Rubicon
98 (ZJ) Grand Cherokee, 3" lift, LED lights, diff locks, Ford rear
tj2kj is offline
post #2 of 6 Old 10-13-2017, 05:42 AM
OutcastJeeps
No reason and it makes no sense considering the standard trans has a lower 1st gear
Sent from my SM-G930V using Tapatalk
OutcastJeeps is offline
post #3 of 6 Old 10-13-2017, 08:49 AM
222Doc
222Doc's Avatar
It is do to the w5 auto is a beast compared to the stick(6speed is low end trans that has like 300ftlbs input max<W580 has over 427ftlbs). with the option of 4.10 and that auto it rolls 35s. My 2 door does rather well even on37s. You wont do that with the stick. remember a auto gear splits are at locked converter and when unlocked its multiplying torque.
If they ran it with 4.1 on 32s it would be over geared, loose mpg. 700$ is a rip though since its not like they have do much. when i ordered my jkr in 11 it was one of the first 12s 4.1 option i paid 50$. best 50$ i spent on the heep. well maybe the PSC steering is but stock anyaway.
If you get the auto rubi get the 4.1 before you check the box heated seats, leather or anything else.
222Doc is offline
post #4 of 6 Old 10-13-2017, 11:17 AM
BlueBabySound
2014 JK Wrangler
IMO if you're going with 35s or larger don't spend the money for factory gears, wait and get the correct gears once you add the larger tires.
His- 2014 JKUR Copperhead Pearl
Hers- 2018 JK Gobi
Retired: 2016 JKWW
Retired: 2013 JK
BlueBabySound is offline
post #5 of 6 Old 10-13-2017, 02:13 PM
Bill123
2016 JK Wrangler
Like Doc said, it has to do with the transmission. The auto is much sturdier than the stick. Having said that, if you're buying a Rubicon, my guess is that you are looking for many of the off road upgrades that come on a Rubi. If so, I would suggest that you opt for the 4.10 gears anyway, even with an auto trans. You may spend a little more for those gears now, but it will be alot cheaper than paying to do it later.
2016 Wrangler Unlimited
2.5" Teraflex Lift
305/70-17 Toyo Open Country AT2
Fuel Lethal Wheels
Bill123 is offline
post #6 of 6 Old 10-13-2017, 02:34 PM
cranbiz
4.10's and an Auto will turn 35's just fine.
Don't mess around with a lesser gear ratio if you plan on any off roading with larger than stock tires.
06 KJ
12 JK,2.5" Teraflex lift,Bilstein 5100's,BFG KO2's P305/65R17
17 WK2 Trailhawk
KN4BBA
cranbiz is offline
