Quantcast Diff Guard vrs. New Diff Cover??? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > Diff Guard vrs. New Diff Cover???
Truck-Lite's New LED Headlamp SeriesGR8TOPS Introduces the Exogate HD Tire CarrierRUBICON EXPRESS Lift Kits and Accessories Available at Bas
Old 04-16-2009, 10:25 AM   #1
kubwa_jim
There it is. I want to armour up my front D30 and rear D44 and I don't know whether to go with a diff guard (Superlift, Warrior, Rough Country, Rugged Ridge, etc) or with a differential cover replacement (Solid, Riddler, Blue Torch, etc). I'm don't want to spend stupid money on it, but I want to make sure I'm not going to peel off, split, crack, etc. my diffs. What do ya'll recommend. I know Warn, ARB, Dyntrac, and others make great products, but I think there are equally as effective products for less cash.
Also, should I be concerned with rear diff over-heating issues if I go with a replacement in the rear? I'm only running 33's with 4.10 gears, limited slip, D44, and I don't do any towing.
Thanks for the input,
Jim
Don't look at me, your rights were violated before I ever got here!!
kubwa_jim is offline   Reply With Quote
Old 04-16-2009, 10:33 AM   #2
SoCalJK
I went with the diff guards rather than replacement covers. Part of the reason was cost - guards are around 50% cost of replacements. Other part was I feel this actually gives extra protection. Even if the guard is badly damaged the original cover should remain intact. With a replacement cover (I know they are really thick/strong), if you crack it you are going to loose fluid. JMHO.
2007 Sahara Unlimited
4x4, Auto, Jeep Green, Tow Package, Soft top
With guns, we are citizens, without them we are subjects!
SoCalJK is offline   Reply With Quote
Old 04-16-2009, 10:38 AM   #3
RockyClymer
Red Rock 4-Wheeler
RockyClymer's Avatar
x2 -when I do this it will be with guards, not new covers.
08 JK 23S - Colorado Jeep Club No. 204
Too much to list - see my profile for details on build
NRA Life member
RockyClymer is offline   Reply With Quote
Old 04-16-2009, 10:48 AM   #4
mattman8706
mattman8706's Avatar
2009 JK Wrangler
I will probably get new covers... I like the feeling of a little more protection
-Matt
My Build Thread
JK Tech
www.matthewduval.com
mattman8706 is offline   Reply With Quote
Old 04-16-2009, 11:10 AM   #5
N2rock
N2rock's Avatar
I was originally going to do new guards because of the price difference. But back in December, Solid ran a sale on their covers- $60 shipped. Now that was a deal I couldn't pass up.
for details and info on our JK's, check out http://n2rock.com
His: '07 Unlimited X, Jeep Green, Hardtop, auto, 5.13, 2.5" RC lift and too many mods to list
Hers: '08 X Red Rock, soft top, auto. Bunch of mods
Originally Posted by tlgraham View Post
If you made a snuggy out of a Shamwow, ....would you have to get up off the couch to pee?
Originally Posted by Deepskyy View Post
At this point if Obama tried to move a little to the right, he would trip over Stalin's corpse.
N2rock is offline   Reply With Quote
Old 04-16-2009, 11:22 AM   #6
ctown67
i like covers better, the guards i looked at seemed like little football masks which i didn't care for.
List of stock parts that have been eviscerated.
power steering pump, tie rod, front left knuckle, horn, weld on rear track bar, rear track bar bracket, both rear fenders, front passenger fender, punctured spare tire, rear bar pins, steering stabilizer shock, front drivers side shock, spare tire carrier.
ctown67 is offline   Reply With Quote
Old 04-16-2009, 12:32 PM   #7
rballman
x2...
2007 Wrangler X - Jeep Green, 4" lift, JKS front/rear trackbars, Fab Industries custom front/rear bumpers, fenders, 6-point cage, Treks/T&T gas tank skid, 10lb co2 tank, rolling on 35s w/ 15s
Colorado Jeep Club member #2007
My JK Build Thread
Items For Sale:
- front/rear trackbars
rballman is offline   Reply With Quote
Old 04-16-2009, 12:43 PM   #8
MrShaft696
they are tough little football masks, ive given mine numerous smacks that stop the jeep dead in its tracks & they hold up just fine. The 4X doctor brand.
96 Cherokee SE 4.0 5sp 4.5" homebrew lift, Tomken + spacer & S10 leaves. P ORC SYE w/ Tom Woods Shaft 33" A/Ts, CB & Aussie locked 29sp 8.25 w/4.56's. Thrush Exhaust
MrShaft696 is offline   Reply With Quote
Old 04-16-2009, 02:05 PM   #9
kubwa_jim
Good info. Anybody got any guards they strongly recommend? Off the top of my head, I'd probably go with the Superlift, but that is a lot of money for a piece of stamped/welded grade 8 hardware. I'm wide open to suggestions.
Old 04-16-2009, 02:46 PM   #10
SoCalJK
I have the Rugged Ridge and they are plenty tough. My only complaint is that they send you torx screws to replace the original bolts. I had to grind a small piece around one of the bolt holes to allow me to use the original bolts. I could have used the screws but it is much easier to torque the bolts.
Old 04-16-2009, 02:59 PM   #11
DBA2GO
Happy Trails!
DBA2GO's Avatar
I've got Teraflex pumkin covers. They are "high-strength ductile-iron." What-the-heck that is? I had them put on when I got my gears.
DBA2GO is offline   Reply With Quote
Old 04-16-2009, 03:13 PM   #12
propped1
Aggressive Mediocrity
propped1's Avatar
ductile iron is the same stuff used in most water main pipe. It is iron but with an alloy in it to make it flex a little before breaking. Its not as rigid/brittle as Cast Iron (you can break a cast pipe with a hammer), but tougher than aluminum (the only way you are going to cut ductile pipe is with a motorized saw).
The clutch in the 6 speed Tremtec 6060 in the Viper, Challenger and Charger this year is ductile iron and can handle 750 ft/lbs of peak torque. Strong stuff.
._______
/_l__[___],
l--|--|--L
-OlllllllO]
(o)_) (o)_)o-)_)
propped1 is offline   Reply With Quote
Old 04-19-2009, 08:04 PM   #13
fernjack
Jeeper for life ;)
fernjack's Avatar
Guards allow your diffs to run cooler !
fernjack is offline   Reply With Quote
Old 02-13-2010, 09:22 AM   #14
PSYCH0
PSYCH0's Avatar
2009 JK Wrangler
How did those original bolts work for you? Were they long enough? How many lbs did you torque them to?
2009 Jeep Wrangler JK, 2-Door, Soft Top, Automatic, Black Procomp Aluminum Wheels with 315x75R16 Goodyear Wrangler Duratracs, 2" Black Diamond Lift, JKS Adjustable Track Bars, Smittybilt Rock Rails
PSYCH0 is offline   Reply With Quote
Old 02-13-2010, 10:26 AM   #15
McKBrew
I Live, I Ride, I Am
I saw the ARB covers at Northridge 4x4. They might be overkill, but they look badaxx.
Heavy as hell.
McKBrew is offline   Reply With Quote
Glock Forum
