Diagnosing Death Wobble and Fixing Non-DW Shimmies and Wobbles - Page 7 - JeepForum.com
 1Likes
post #91 of 360 Old 04-04-2011, 11:50 PM
JLC08JK
What was I thinking?
JLC08JK's Avatar
Poor kitty
Welcome to the Club raz631
I hope you find the solution to your D/W woes!
You came to the right place
Jim
JLC08JK is offline
post #92 of 360 Old 04-04-2011, 11:57 PM
raz631
Thanks for the reply!
I see what your saying but that's just it!
I have replaced just about everything and there are no parts the move at all!
No oval holes, no play in anything, no warn bushes.... nothing! and even the parts that were replaced have been re checked as per your list and they are still as new!
And sorry about the kittens.... woops... ha ha ha..
raz631 is offline
post #93 of 360 Old 04-05-2011, 12:02 AM
raz631
Originally Posted by JLC08JK View Post
Poor kitty
Thanks mate! Yeah me to...
I hope to get my Truck/Rig back to the way she was when i first got it!
Hang on... can I call it a she? I wont kill a fairy or something?
ha ha ha
raz631 is offline
post #94 of 360 Old 04-05-2011, 10:22 PM Thread Starter
planman
Thanks to all Mod erators
planman's Avatar
There should be no clunk in your steering. You need to find the source of it.
DW does happen without something being loose, damaged, broken, cracked, etc. Too much toe-in and too much caster can also cause problems. You might back off your caster to 4.5 degrees.
Do your tire tread surfaces have feathered or cupped wear patterns?
Have you driven without your front driveshaft yet?
planman is offline
post #95 of 360 Old 04-11-2011, 08:17 PM
goozaman
wow, overwhelming but dam good info here thru-out this thread/post!! i am trying to break into the jeep world, been lookin all over originally for the 05 or 06 TJ unlimited(LJ), now lookin at the JK unlimited's. test drove a real nice 2010 Rubicon unlimited with 6in Rough Country lift runnin 37's, and I noticed it felt a little sloppy to me.. looked at what i found out to be the trackbar after reading thru here, and noticed the bushing peeling away where it mounts. hhhmmm really concerned with it now after reading this.. the rig was just driven back from cali with 18000 miles total, and the lift was installed by a the owner, who im pretty sure is inexperieced at lift kits! not a fan of the rough country lift for starters after reading about them either and kinda prefer a long arm lift. thats a whole other question i am searching for on here, long arm vs short arm lifts!! what to do what to do!
goozaman is offline
post #96 of 360 Old 06-06-2011, 06:48 PM
OCBob
2009 JK Wrangler
Thanks for the checklist. I have really been struggeling with this issue for a very long time. It is not easy to figure out. I have tried so many things. Still no resolution. I am really frustrated and will use your checklist for another full inspection. I was told a JK with 53,000 miles should have had ball joints replace a while ago. Is that true?
09 JK Sahara, LS V8, 6L80Auto, 5.13 Yukon, Dana 44, 3" Teraflex Lift, Bilstein Shocks, JKS Trackbar, AEV Steer Kit w/Bilstein Stabilizer,MT 17x9 Lock II, Nitto Grappler 37X1250, EGS Grab Handles
OCBob is offline
post #97 of 360 Old 06-06-2011, 06:57 PM
speedbucket
only if youve had bad DW for a while,im about to do my my 3rd set at 250k on my zj and yours should be stronger
V8 zj at 6" . Double tri rear and true 3 link front. Stretched to 108"
speedbucket is offline
post #98 of 360 Old 06-06-2011, 07:11 PM
OCBob
2009 JK Wrangler
I have and the Teraflex Tech highly suggested it. At this point I really need this corrected. I can't keep driving like this. Not much fun and too dangerous!
OCBob is offline
post #99 of 360 Old 06-06-2011, 07:54 PM Thread Starter
planman
planman's Avatar
The stock ball joints are not very high quality. Some people get 60,000 miles out of them other people get much less.
If you have had multiple bouts of death wobble it is quite likely that your lower ball joints are damaged.
planman is offline
post #100 of 360 Old 06-06-2011, 08:01 PM
Hellbound13
While you are diagnosing it, you should also report this dangerous problem here..
https://www-odi.nhtsa.dot.gov/ivoq/
Hellbound13 is offline
post #101 of 360 Old 06-07-2011, 08:59 AM
OCBob
2009 JK Wrangler
Hello Planman. I have had multiple bouts with the DW. I was about to order a whole new set of all ball joints, but I really want to be sure I get what I need this time. I lowered air pressure in my tires yesterday to 30 psi (Nitto Tires recommend 65 and I have been running 45psi) as suggested by Teraflex Rep. I tried the AEV High Steer Kit. Still no luck fixing the problem. I used your original checklist and unfortunately I thought the high steer kit was the solution. I will be using the new checklist to go over everything once again. My mechanic swears the ball joints are in good shape however, it is one of the only things that have not been replaced. We did rebalance the tires two weeks ago hoping it would help. Still have the problem.
OCBob is offline
post #102 of 360 Old 06-07-2011, 09:14 AM
1222
RIP John
1222's Avatar
...My mechanic swears the ball joints are in good shape however, it is one of the only things that have not been replaced....
Man thatís gota suck. I sure hope you get it fixed soon. As far as your mechanic saying that the ball joints are still good and they might be, I would still go to another shop and get a second opinion. History here is that they are crap from the dealer and just donít last.
1222 is offline
post #103 of 360 Old 06-07-2011, 09:21 AM
OCBob
2009 JK Wrangler
Any recommendations for type of ball joints? The price seems to be all over the board.
OCBob is offline
post #104 of 360 Old 06-07-2011, 09:37 AM
1222
RIP John
1222's Avatar
Havenít checked prices but it seems that Poly Performance and Dynatrac (expensive) are the best.
1222 is offline
post #105 of 360 Old 06-07-2011, 11:02 AM Thread Starter
planman
planman's Avatar
The lower ball joints are usually the ones to go first. They are very easy to check.
Put your front axle on jack stands with the tires elevated a couple inches.
Have a helper use a long pry bar or lever underneath the tire to lift up the tire/wheel while you inspect the lower ball joints for up and down movement. The play should be very, very minimal.
If you have had a recent alignment done and your caster is off, it is often because the lower ball joints are bad.
I installed Dynatrac ball joints on my 2 door because I run 40s during the summer. I bought a pair of Poly Performance ball joints to install on my wife's 4 dr on 37s when hers get too bad.
The thing with DW is that you need to go through the entire checklist in one setting. If you don't, you end up chasing your tail. Maybe you replace your too small stock trackbar bolts with 9/16" bolts and weld washers on the front and back of both the frame and axle side brackets, but you don't address everthing else. Maybe your ball joints are bad, and by the time you check them, the wobble has damaged your drag link ends. Maybe by the time you get to the drag link ends you have damaged your trackbar bushings.
So, inspect it all at one sitting.
planman is offline
death wobble , JK Wrangler , shake , shaking , steering shimmy , wheel shimmy , wrangler
My Experience with the Death Wobbles haulincats TJ Wrangler Technical Forum 9 11-04-2009 01:53 PM
Need Help With Death Wobbles TrevorJordan TJ Wrangler Technical Forum 4 06-18-2009 05:30 PM
death wobbles at 60+mph dae03TJ TJ Wrangler Technical Forum 5 03-24-2008 01:19 PM
Death wobbles Chadillac1212 TJ Wrangler Technical Forum 7 01-27-2008 08:46 PM
Death Wobbles or something else? Coopa JK Wrangler Technical Forum 5 12-01-2007 10:36 PM
