Detroit TrueTrac or a winch?? - Page 2 - JeepForum.com
post #16 of 31 Old 09-30-2013, 02:48 PM
Vince1
2010 JK Wrangler
Sounds from your build and post that you don't wheel much on rough trails. The true trac is the answer in your situation. A high lift jack can get you out of a lot of sticky situations too.
Vince1 is offline
post #17 of 31 Old 09-30-2013, 03:05 PM
SLADE
I agree. It doesn't really sound like there will be a huge demand for a winch. Going wheeling with a buddy and carrying some self recovery tools can all but eliminate the need for a winch.
The TrueTrac will be beneficial on the street, trail, and not just if you get stuck.
Buy a winch before you start wheeling by yourself or hitting harder trails. Until then, enjoy having the added traction of the TrueTrac.
2014 Wrangler JKU
2013 Wrangler JK
2004 Wrangler TJ on LEAFS
2001 Dodge Ram 2500
SLADE is offline
post #18 of 31 Old 09-30-2013, 03:17 PM
Filthy-Beast
You already have a true-trak in the rear, I very occasionally also need my front locker and when I do 40% of those times end in winching. but only you know what kind of wheeling you do and if the extra traction would lead to the need for winching.
For Sale:
97 TJ: daughter 1 - 2.5L, Auto, 2" BB, 31" GY Duratrac
98 TJ: Daugher 2 - 4.0L, 5spd, D44 rear
06 LJ Rubicon: mine - Rokmen full up-armor, 8 adjustable CAs, front bumper, sliders, corners, Shrockworks rear bumper, 3" AEV/BDS lift, Currie HD stearing and Antirock, MT/r - k 35x12.5, SuperWinch, MC Overlines, York OBA
13 JKU Rubicon: Wife's for now, Ace Rock rails & rear bumper tire carrier, Truck Lites, MC Game changer 3.5 lift, RR skids, PSC Brawler front bumper, Warn 9.5cti-s, 35" GY MTRs
Filthy-Beast is offline
post #19 of 31 Old 10-01-2013, 07:53 PM
HappyTrails
HappyTrails's Avatar
I use my lockers on the trails more often than I use my winch. I've only been winched out once, when I didn't have a winch. My winch has been used numerous times to pull others up trails, but never had to use it on myself, yet.
Key thing to off-roading...Don't go alone!
I think the LSD would be a greater benefit to your type of driving. It could be handy on snow-covered roads, in addition to a slick trail.
The winch...save your $$$ for later, when you get into more difficult trails.
2008 2-dr Rubicon, auto,
RK 2.5" Max Travel, Rancho 9000XL shocks, 37" Nittos, 5.38's, RR skids, Warn VR8000-S.
RIPP Gen 2 Stg 2 Supercharger.
Political Correctness offends me.
HappyTrails is offline
post #20 of 31 Old 10-01-2013, 07:59 PM
329892 - Deactivated
Guest
I've got an '05 Rubi with full lockers. Many times I think about using the winch when stuck but the lockers have saved me everytime. Lockers first...... then when everything else is done add a wich.
329892 - Deactivated is offline
post #21 of 31 Old 10-02-2013, 04:38 AM
SubAtomicGenius
2011 JK Wrangler
You're going to get recommendations in either direction! Choose one, and drive accordingly! (I'd go with lockers before a winch - then choose a buddy with a winch to go with! )
SubAtomicGenius is offline
post #22 of 31 Old 10-02-2013, 08:32 AM
Yendor
I need a bit of help in the "word definition department", if some one would.
I know what limited slip/ true track/ posi-track in the rear is.
I know what a front locker does.
Additional traction coming from the front end: is a limited slip/true track in front the same as a "bread basket" type device? I guess what I'm wondering is, Is there a device that will act like a limited slip rear end, but doesn't do the ratchet/clicking nonsense when going around sharp turns?
Yendor is offline
post #23 of 31 Old 10-02-2013, 08:44 AM
SLADE
The clicking you are referring to comes from a lunch box locker (Aussie, lock Right,).
Limited slip carriers do not ratchet or click. The stock track lock is a Clutch operated limited slip. The Detroit True Track is a gear operated limited slip.
Limited slip's are NOT lockers, they are limited slips.
2014 Wrangler JKU
2013 Wrangler JK
2001 Dodge Ram 2500
SLADE is offline
post #24 of 31 Old 10-02-2013, 11:54 AM
Yendor
So you can put a Limited Slip in the front..... Surely it's not the same parts as in the stock Jeep rear limited slip, are they?
The Detroit True Track, doesn't do the ratchet thing, correct?
What's the disadvantage to a limited slip front end, other than cost?
Thanks for your patience.
Yendor is offline
post #25 of 31 Old 10-02-2013, 12:36 PM
SLADE
Yes
They can be. The carriers are axle model specific, not front or rear specific. You can run a Detroit TrueTrac Limited slip in the front and the rear if you want.
No, The TrueTrac is a limited slip and does not ratchet.
It's not a Locker. But on the other hand, that is also one of the biggest advantages.
2014 Wrangler JKU
2013 Wrangler JK
2001 Dodge Ram 2500
SLADE is offline
post #26 of 31 Old 10-03-2013, 06:59 AM
nwco4x4
One thing to think about and someone correct me if I'm wrong but I know lockers front and rear on snow pack and ice are bad. And I'm assuming LSDs are not much better. You get this really nice turn any direction you want, as long as it's straight experience. And if you don't wheel hard enough to need a winch do you really need a limited slip. Every reply on here has at some point been in a situation that required more than an open diff in the front could provide, requiring either a winch or LSD. Lockers/LSD are great and greatly improve the capabilities of a rig, but with them two things happen: 1 you get a false sense of security and you find your way into more extreme situations, and 2 when you do get stuck you get STUCK and if you don't have means to get yourself out your typically going to need a rig as capable as yours to get to you let alone pull you out.
nwco4x4 is offline
post #27 of 31 Old 10-03-2013, 02:02 PM
SLADE
You would assume wrong.
Limited Slips perform more like an open carrier than they do a locker. They just provide some resistance before they allow the "slip".
2014 Wrangler JKU
2013 Wrangler JK
2001 Dodge Ram 2500
SLADE is offline
post #28 of 31 Old 10-03-2013, 03:27 PM
xzy
Lockers/LSD are great and greatly improve the capabilities of a rig, but with them two things can happen: 1 you could get a false sense of security and you find your way into more extreme situations, and 2 when you do get stuck you can get STUCK and if you don't have means to get yourself out your typically going to need a rig as capable as yours to get to you let alone pull you out.
No false sense of security here with my double TT's. They work extremely well on snow/ice and off road.
A mans just got to know his Jeeps Limitations (!)
xzy is offline
post #29 of 31 Old 10-03-2013, 03:55 PM
Filthy-Beast
Just to clarify for those reading who do not reside in the snow belt or regularly drive in those conditions. Tires make the biggest difference, lockers and LSD cannot help much with tires that perform very poorly on snow and ice. With decent tires they can greatly help get you moving which leads to the leading cause of accidents, moving too fast, lockers /LSD don't help you stop!
For Sale:
post #30 of 31 Old 10-03-2013, 03:58 PM
nwco4x4
Exactly and a lot of people don't know their vehicles limitations. I've seen the "I have lockers/lsd I can go anywhere attitude". And that's all I was trying to say I'm not saying everyone does, but there are definitely some.
nwco4x4 is offline
