Detroit TrueTrac or a winch?? - JeepForum.com
post #1 of 31 Old 03-14-2013, 09:39 AM Thread Starter
chris79
JK Wrangler
So...I added a small budget boost and front and rear Smittybilt bumpers to my 12 JKU Sport, now I'm torn between a Truetrac in the front or a winch (the easy answer is both of course but $$$!). I have a Trac Lock in the rear but would love something in the front and I don't want air hoses, e-lockers, etc....the Truetrac is all mechanical and lasts forever, not to mention the reviews are great for daily drivers in snow and mild off road use, I don't rock crawl so I don't need lockers. My only issue is voiding the warranty with only 13k on it. What do you fellow Jeepers out there think??
chris79 is offline
post #2 of 31 Old 03-14-2013, 09:48 AM
brianjw
The only warranty that will void is inside of the axle assembly, and the installer/Detroit should warranty the parts installed.
This discussion comes up on a lot of boards and opinions vary wildly. My personal preference is lockers before a winch. Since you're considering a limited slip, I have to ask if you really think you need the winch? Depends on your usage I guess! Have you been stuck yet? Did you feel like more traction in the rear would have made a difference?
I've gotten away for years without a winch because I use to always wheel with a buddy who had one. On one of my rigs I installed a front hitch and wiring so I could use it as well (it was mounted on a portable tray).
But now I'm considering a winch as I'm venturing out by myself a little more often.
brianjw is offline
post #3 of 31 Old 03-14-2013, 09:52 AM
Kip03TJ
Since you live where it snows I would add another lsd up front. You can buy a cheap winch later on but you'll be using the lsd more than the winch since you don't go extreme when you offroad.
FOR SALE
14,960 miles perfect condition
2003 Jeep Wrangler Sahara edition fully loaded 5 speed manual. Brown dog 1" motor mounts, Currie 1" body lift, jks front disconnects, 31" Goodyear Wrangler duratracs, 8 adjustable control arms, Advance Adapters HD SYE, Tom woods premium driveshaft, driver & passenger heated seats
Kip03TJ is offline
post #4 of 31 Old 03-14-2013, 09:56 AM
Jeffro06
Jeffro06's Avatar
Winch may be more useful, unless you wheel with others who have one. Last time out we had three winches, and four jeeps with lockers....we needed the winches, despite the lockers. At times we had two winches working on one jeep...so I'll vote winch first.
Jeffro06 is offline
post #5 of 31 Old 03-14-2013, 10:26 AM Thread Starter
chris79
JK Wrangler
I've ran into a couple situations with obstacles that I could've used a winch, luckily other Jeepers were around. I had a Rubi for 4 years and used my lockers 4 times, I don't do extreme off roading but the TrueTrac looks really cool for snow and mud, which is what I'm normally in.
chris79 is offline
post #6 of 31 Old 03-14-2013, 02:24 PM
tslewisz
2010 JK Wrangler
I did a winch first, LSD's later.
tslewisz is offline
post #7 of 31 Old 03-15-2013, 06:35 AM
michiganmaveric
Got Beer?
michiganmaveric's Avatar
2011 JK Wrangler
True Trac first for sure.
Previous Jeeps: 84 CJ7 (A True Jeep), 2000 XJ (163,000 Miles/Totaled (Pictures of wrecked Jeep in gallery)), 2004 WJ (parting out die to major electrical issues)
If you don't have time to do it right the first time, how do you have time to do it over.
Lifetime member #13
lifetime member/airforce26yrs
2011 Tango/Mango JKU
michiganmaveric is offline
post #8 of 31 Old 03-15-2013, 09:07 AM
slider_68
2011 JK Wrangler
No ones asked but what gear ratio do you have? Do you plan to regear? If you have 3.21s and plan to regear at a later date, do the winch, if you have 3.73s or plan on regearing at the same time do the true trac. Why? 3.73 and up is a different unit than the one for 3.21, no reason to buy it twice.
slider_68 is offline
post #9 of 31 Old 03-15-2013, 10:31 AM Thread Starter
chris79
JK Wrangler
I've got 3.73s and I don't plan on regearing.
chris79 is offline
post #10 of 31 Old 03-16-2013, 08:52 PM
nwco4x4
Winch first. Lockers/LSD are great and they greatly enhance the abilities of a jeep, but they also greatly enhance the getting stuck abilities of the Jeep. They will get you places that only an equally built rig will get to, which can be a real problem if your the only one with an LSD front and rear. My advice is make sure you can always get yourself out. lockers/LSD wont do you any good if you got to walk home instead of pulling out 50' of winch line
nwco4x4 is offline
post #11 of 31 Old 03-16-2013, 08:59 PM
zaq123
zaq123's Avatar
1941 JK Wrangler
Lockers for sure. Go with OX. Good bang for the buck, comes with diff cover and also cable operated.
zaq123 is offline
post #12 of 31 Old 09-29-2013, 09:00 PM
tslewisz
2010 JK Wrangler
I went with a winch first, then TrueTracs, front and rear. I don't regret that choice at all.
tslewisz is offline
post #13 of 31 Old 09-29-2013, 09:33 PM
xzy
I've got TT's front and rear.
Without question get the TT before winter hits. A winch will be easier to add later.
xzy is offline
post #14 of 31 Old 09-30-2013, 10:36 AM
SLADE
You'll use the TrueTrac every time you put it in four wheel drive.
I had TrueTracs (front/ rear) and 4.88's installed with less than 4k miles. The warranty is nice, but I'd rather have the Jeep I want than to do without for that long waiting on the warranty to run out.
2014 Wrangler JKU
2013 Wrangler JK
2004 Wrangler TJ on LEAFS
2001 Dodge Ram 2500
SLADE is online now
post #15 of 31 Old 09-30-2013, 03:22 PM
jimk403
2009 JK Wrangler
I say winch. I (and others) have been in places where lockers would not help. For example, guy in a brand new Rubicon 2dr sat it down on a boulder on Bronco Peak trail (So Cal). If he had a winch, he would not have sat out there in the rain all day until he found us.
Just my opinion, yours will differ.
Proud owner of: '09 Rubicon Unlimited, '90 XJ, '88 XJ, '77 J-10
jimk403 is offline
