Definitive list of 15" wheels that will fit JK?! - Page 4 - JeepForum.com
 1Likes
post #46 of 69 Old 04-13-2014, 10:01 AM
jm708
2014 JK Wrangler
Just to add to the list of 15's that will fit. Helo HE791 fit without any grinding of the calipers. I was not able to use sticky wights though. Here's pre-BB pic just to make sure they would work.
jm708 is offline
post #47 of 69 Old 04-13-2014, 12:55 PM
iwaxmyjimmy
I run Jegs brand 15x8s, they aren't hub centric and they are 3.75" back spacing.
Sent from AutoGuide.com App
iwaxmyjimmy is offline
post #48 of 69 Old 04-13-2014, 03:03 PM
CJ7nvrstk
Military Jeeper
CJ7nvrstk's Avatar
Pro Comp 52 in both 15x8 and 15x10, 3.75" BS fit, no rubbing, no grinding needed.
RED Friday. Remember Everyone Deployed
45 MB, 67 Commando, 85 CJ, 08 JKU, 11 JKU
CJ7nvrstk is offline
post #49 of 69 Old 02-02-2015, 01:54 PM
snaugler
2014 JK Wrangler
I'm thinking about making the move to the AR 23s 15x8 with 3.75 backspacing. I'll be throwing 33x12.5x15 on them. Does anyone know how far those will stick out? Can't have them going more than an inch past the fenders.
snaugler is offline
post #50 of 69 Old 02-02-2015, 05:27 PM
roughneck942003
The list is great but Im having a tough time finding any of the rims listed anywhere online. Any place that carries a wide selection? They show alot of the wheel but most are 5x4.5 or 5x5.5 not 5x5
roughneck942003 is offline
post #51 of 69 Old 02-03-2015, 04:35 AM
snaugler
2014 JK Wrangler
tirerack.com. just throw in your vehicle type and it will give you a lot of options with 5x5. they also have the best prices
snaugler is offline
post #52 of 69 Old 02-03-2015, 10:38 AM
planman
Thanks to all Mod erators
planman's Avatar
There are filtering features on summitracing.com to find wheel with a given bolt pattern, diameter, backspacing, and width.
Discounttiredirect.com may also have similar tools, as well as ntwonline.com and jegs.com.
planman is offline
post #53 of 69 Old 05-03-2015, 01:38 PM
08steelblue
So im going with pro comp mt2 35x12.50x15r im gonna go with pro comp 52 steel wheels 15x10 5x5 with 3.75in back spacing and 1.75 in spacers .... does that sound like a good set up to not have to do any alterations to the calipers? I also have synergy 1 ton tire rod if that matters im also on a 3.5 in metal cloak lift its an 08 4 dr jkux. Need feed back asap
08steelblue is offline
post #54 of 69 Old 05-03-2015, 03:42 PM
Ljcrawler05
I don't know much about jks, but you're planning on running 2" of backspacing total. That's going to make you extremely wide and wear your outer components like it's nobody's business.
Ljcrawler05 is offline
post #55 of 69 Old 11-17-2015, 09:36 PM
Oakley990099
Originally Posted by ZX14Rider View Post
Pro Comp Rock Crawler 152's.....15x10 3.75 back spacing no rubbing..
Did you need new lugs or are the stock okay with these wheels?
Oakley990099 is offline
post #56 of 69 Old 11-20-2015, 06:04 PM
planman
planman's Avatar
Stock work fine.
planman is offline
post #57 of 69 Old 11-20-2015, 07:13 PM
Digger838
Summit racing brand 15X8's with 3.75 BS
Running 33-12.50/15 Dunlop mud rovers
No grinding needed 2014 jku sport
Sent from a jeepers iPhone
Digger838 is offline
post #58 of 69 Old 03-25-2016, 08:24 PM
catang5oh
2016 JK Wrangler
I like my MB72's, ran since 09 on my 07 Sahara, now on the 16 Rubi.
catang5oh is offline
post #59 of 69 Old 03-26-2016, 07:51 AM
JTPhoto
JTPhoto's Avatar
Down side to 15" wheels is most upgraded tierod Kits will rub the tires .. If you stay with stock components you shouldn't have a problem.
That being said, why are folks so interested in going with 15".? Most if not all 15s run on the small size and tire as well as wheel selection is very limited. Is it just because they are cheaper?
^^Jeff^^
2008 Black and Khaki Sahara Unlimited Trax-Lok rear diff. 3.5" Rock Krawler fr springs, rear TeraFlex 2.5 BB, D44HD/J8 w/ OX locker and RCVs, 37x12.50x17 Pitbull Rockers on ProComp 2635 Predator Alloys, AEV Prem Bumper, Smitty X2O 12K ETC..
JTPhoto is offline
post #60 of 69 Old 03-26-2016, 10:19 AM
PanthersFan
Originally Posted by JTPhoto
Down side to 15" wheels is most upgraded tierod Kits will rub the tires .. If you stay with stock components you shouldn't have a problem. That being said, why are folks so interested in going with 15".? Most if not all 15s run on the small size and tire as well as wheel selection is very limited. Is it just because they are cheaper?
Cheaper, more sidewall flex off-road, more options at 15".
THE Conventions of a number of the States, having at the time of their adopting the Constitution, expressed a desire, in order to prevent misconstruction or abuse of its powers, that further declaratory and restrictive clauses should be added: And as extending the ground of public confidence in the Government, will best ensure the beneficent ends of its institution.
PanthersFan is offline
Creating a "master list" of writeups, post yours here rustywrangler YJ Wrangler Technical Forum 35 10-15-2009 09:48 AM
Definitive language on Warranty sromain JK Wrangler Technical Forum 4 06-29-2008 03:06 PM
Seat Belts FUBAR "Add It To The List" badkarma61 TJ Wrangler Technical Forum 6 09-27-2006 06:28 AM
Need to make a "Jeep" List... shebas04TJ TJ Wrangler Technical Forum 11 09-19-2004 02:23 PM
need definitive answer on backspacing derby TJ Wrangler Technical Forum 3 11-20-2002 03:17 PM
