The definitive 2012 Wrangler 3.6 Pentastar Thread - JeepForum.com
post #1 of 190 Old 03-01-2011, 04:09 PM Thread Starter
BRICKTOP2
Unhingd PigFeedng Gangstr
BRICKTOP2's Avatar
Introduced in 2010 for the 2011 model year, the 3.6 Liter Pentastar motor (originally called the "Phoenix" but changed prior to release due to trademark issues I believe) is the next motor to be introduced to the Jeep Wrangler lineup. All indicators point to a fall 2011 release for the 2012 model year. It will increase horsepower by 40-50 percent, depending on how they tune it for this application. The current horsepower and torque ratings on the models with this powerplant are:
283hp in 200, Avenger, Grand Caravan, Journey, Town & Country
290 in Grand Cherokee and Durango
292 in Charger and 300
305 in Challenger
The torque variance is not as great, with the span being only from 260 lb ft to 268 in the different models
The current 3.8 has 202 horsepower and 237 lb feet of torque.
Weight is 383 pounds, which is 42 pounds lighter than the 3.5, 94 pounds lighter than the 3.7, and 30 pounds lighter than the current 3.8 in the Wrangler.
Specs:
All-new Chrysler 3.6-liter, DOHC, 24-valve Pentastar V-6 Technical Specifications
Displacement: 3.6 liters
Bore x stroke: 96 x 83 mm
Valve train system: Double-overhead cam with roller finger followers and hydraulic lash adjusters. Dual independent cam-torque actuated phasers
Fuel injection: Multi-point port fuel injection
Construction: High-pressure die-cast aluminum cylinder block and semi-permanent mold aluminum cylinder head
Maximum engine speed: 7200 rpm
Fuel requirement: E85 (Ethanol) or unleaded regular, 87 octane (R+M)/2
Emission capability: PZEV
There are talks of the Pentastar being turbocharged by 2014.
I'll update this initial post when I get hard facts as they arrive and I'll post updates as new posts to keep y'all aware of the changes. If anyone hears anything before I do, post away and I'll add it into the initial post as well.
"Tightening the nut behind the wheel is the most cost effective way to improve the performance of any vehicle."
JK Build Thread
TJ Tub Trailer
BRICKTOP2 is offline
post #2 of 190 Old 03-01-2011, 04:14 PM
Mol
Disclaimer: I'm Polish
Mol's Avatar
I was sure they were going direct injection...learn something new every day. Thanks for the detailed info, brick
Mol is offline
post #3 of 190 Old 03-01-2011, 04:17 PM Thread Starter
BRICKTOP2
BRICKTOP2's Avatar
No problem. There is talk of direct injection coming at some point btw.
JK Build Thread
TJ Tub Trailer
post #4 of 190 Old 03-01-2011, 04:21 PM
Mol
Mol's Avatar
Glad to hear that!
Mike
Mol is offline
post #5 of 190 Old 03-01-2011, 04:26 PM
farstucker621
I'm going to be a first time owner very soon... Now the question is do I hang on to my 07 Grand Cherokee lease for a couple extra months while I wait for the 2012 jeeps or do I stick with the older models and the tried and true engines!?
farstucker621 is offline
post #6 of 190 Old 03-01-2011, 04:33 PM
Mol
Mol's Avatar
They have warranty for a reason! I think the near-unanimous opinion will be to wait for the 3.6
Mol is offline
post #7 of 190 Old 03-01-2011, 10:13 PM
Glockem
2012
I'm waiting until after December 21st 2012 before I think about buying one with a 3.6L. Let em work the bugs out. Maby if I'm around in the Summer of 2012 sombody will make a swap kit for my 08 Rubicon.
(OllllO) RUBICON
Glockem is offline
post #8 of 190 Old 03-02-2011, 01:11 AM
242much
2009 JK Wrangler
fugget it, just get the 5.7 vvt hemi swap.
"The stoke was palpable..."
good grief, just buy the Rubicon.
242much is offline
post #9 of 190 Old 03-02-2011, 07:16 AM
BigMikeATL
2014 JK Wrangler
I wasn't impressed at all when I drove the '11 Grand Cherokee with the Pentastar. I opt'd for the HEMI.
2014 2D Rubicon, 2.5" Metal Cloak Game Changer ARB, ProComp 7069 17x9, Goodyear MTR Kevlar 35's, ACE Pro Series Bumpers, Warn M8000
2011 Grand Cherokee Overland HEMI MyGig Tow Pkg
2009 2D Rubicon SOLD
BigMikeATL is offline
post #10 of 190 Old 03-02-2011, 10:37 AM
saceone
SO the real question is: when should we expect to see pentastar'd Wranglers on the road?
saceone is offline
post #11 of 190 Old 03-02-2011, 10:46 AM
petertjr
My very reliable source says that they will be ready to order in July by dealerships here in Canada, so I assume we should see them sometime around September
petertjr is offline
post #12 of 190 Old 03-02-2011, 12:10 PM
chickenhawk7
Bricktop, check your PM. I have a non-related thread question for you.
Thanks.
chickenhawk7 is offline
post #13 of 190 Old 03-02-2011, 01:02 PM Thread Starter
BRICKTOP2
BRICKTOP2's Avatar
Thanks.
Sorry man. Missed that PM. Sent you a link.
JK Build Thread
TJ Tub Trailer
post #14 of 190 Old 03-02-2011, 01:07 PM
chickenhawk7
Thanks
post #15 of 190 Old 03-02-2011, 04:37 PM
bluegrassguitar
2011 WK
They will probably opt for the 283hp version since it's already in a van.
It'll still be big improvement, though, especially since the mpg is supposed to be better than what we have now.
bluegrassguitar is offline
Jeep Pentastar 3.6L in a 2011 Wrangler? kng JK Wrangler Technical Forum 32 06-11-2011 08:40 AM
Official!! Pentastar in 2012!! blue-coupe JK Wrangler Technical Forum 92 02-19-2011 12:59 PM
2012 Pentastar Jeep run11rb JK Wrangler Technical Forum 118 02-07-2011 09:41 PM
2011 Wrangler to get Pentastar Engine BRICKTOP2 JK Wrangler Technical Forum 96 06-14-2010 07:51 PM
No Wrangler Pentastar? ARTSBEST Wrangler General Discussion 12 04-10-2009 01:57 PM
