#1 | |
Death Wobbles or something else?
It only happens in the first 5 miles or so of driving. Fast wobble in the steering wheel, after 5 miles starts to fade and by the time I'm at work (15 miles) is almost undetectable. It's also gotten worse as it gets colder.
#2 |
Sounds like a tire issue.
#3 |
Gold Member
I assume you checked pressures in each tire , felt for any eggs in the sidewall, had balance checked etc.
2007 Black Unlimited Sahara, Black Hard Top, Khaki Soft Top, Khaki Interior, 3" Black Diamond Springs and sway bar links, Rancho Steering Stabilizer, Helo Black Maxx 6 17 X 9 wheels, BFG AT TA KO 315/70-17 Tires, Poly Peformance High Steer Kit, Poly Performance Upper and Lower Front and Rear Adjustable Control Arms, Poly Performance Rear Track Bar Bracket, Poly Performance Chromoly Tie Rod, Offset Upper Ball Joints, Mopar Front and Rear Bumpers and Skid Plate, Warn 9.5ti winch, ARB High Output Compressor with tire inflation kit, PIAA 510 SMR Fog Lights , Silverstar Headlights, Bilstein 5100 series shocks, 5.13 gears, Alpine IDA-X001, Infinity 6020CS, Infinity 6022si, Alpine MRP-F250, JBL P1024, Alpine MRP-M650 http://www.jeepforum.com/forum/f129/hothead-headliner-1237401/ http://web.me.com/stevenpeltierjr/Living_It_Up/Welcome.html |
#4 |
Pressure was checked... they are all at 26 psi. I didn't notice any bumps in the sidewalls. They were installed on the wheels by Discount Tire, who uses a Hunter balancer IIRC?
Could it be an alignment issue? I haven't had it aligned since the lift. |
#5 |
You should probably have an alignment done, but I don't see how the alignment would change after driving a few miles to warm up... temperature seems to be causing it since you said it's worse in cold weather... so ya I'd have your tires re-balanced.
2008 2dr JK Mod List (So far) OME HD Lift with NitroCharger shocks. JKS front and rear adjustable trackbars. 33" Toyo Open Country MT's on 18" XD Rockstars. JKS Quicker Disco's. RockHard 4x4 Oil Pan Skid. Shrockworks Rock Sliders. Woods SS relocation bracket & evap relocation bracket. sPod switch panel. Tuffy Security Cover -Drive it like you stole it- |
#6 |
mine do the same. But the wobble stops before i get to the highway so Ill leave it alone. It only happens when its cold in the morning
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
