Death wobble solved (in my case anyway) - Page 2 - JeepForum.com
post #16 of 17 Old 03-30-2010, 08:52 AM
Hellbound13
What does that bar do??
Hellbound13 is offline
post #17 of 17 Old 06-04-2010, 08:26 AM Thread Starter
mrcrwly
Originally Posted by DeepSky View Post
Glad you got it fixed
Questions for ya:
1. Are you running the bracket simply to reduce the angle of the TB with your 4" of lift or to save $$ on an adjustable TB??
negative
2. Are you running a drop pitman arm?
yes
3. Its hard to tell from that picture; how parallel are your trackbar and drag link to each other?
pretty close, it would have been a fairly steep rake without the pitman arm
4. Also, I assume the bar that runs from the upper TB mount to the sway bar was your addition? Any issue with disconnecting the sway bar linkage (if you have quick discos)?
WVUjeeper was right, its attached to the crossmember at the top
WhiskeyTangoFoxtrot...
Rescue Green Jeep Club Official Member Let the mods begin! 07 JK Sahara Loaded, 4.10s lim slip 4" RC lift 16 34x10.50 LTB Interco Swampers. Pro-Josh Evap relocation, Skid Row motor/trans skid, Build in the works...
mrcrwly is offline
Another case of death wobble 06gdneagle TJ Wrangler Technical Forum 8 01-27-2010 02:40 PM
Death Wobble Solved teflont Wrangler General Discussion 11 02-11-2009 04:10 PM
death wobble solved (finally) mrbates TJ Wrangler Technical Forum 7 08-01-2007 03:36 PM
Death Wobble.... Solved (for me :))! froggy76 TJ Wrangler Technical Forum 5 07-12-2005 08:55 AM
Another case of Death Wobble HELP! Blues61 TJ Wrangler Technical Forum 2 04-27-2004 11:18 PM
