Dealer "fixed" a leak. Now it's worse. Pics inside - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > Dealer "fixed" a leak. Now it's worse. Pics inside
Ruffstuff Axle Simple Swap Kit!The Ruffstuff NOT Universal 4 Link Kit!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 03-16-2010, 12:52 PM   #1
Dronac
My JK only has 20,000 miles and oil has started collecting near where the tranny and engine meet. I took it to the dealer and they said I had a leaking driver's side exhaust and valve gasket so I send it in (no loaner ) for 3 days and now, 2 weeks later, it's leaking worse. It looks like it's coming from right between the tranny and engine but the dealer said it wasn't the rear main seal. Any ideas?
In the pic, you can see it's coming down from above the top right bolt.
I was fixing to do an oil change today too, but I hate to put in $35 of oil when I'm not sure what will happen to it when it get;s "fixed" again.
Dronac is offline   Reply With Quote Quick reply to this message
Unread 03-16-2010, 01:02 PM   #2
mikebigh
mikebigh's Avatar
1987 YJ Wrangler
Valve cover gasket will give you the drip, the exhaust manifold gasket doesnt seal any fluid cept for any moisture as a result of any internal cumbustion(spell gurus chime in here, thanks) motor. If you change the oil now, it will be the same oil when you pick it up, nothing will happen to it. They will replace two gaskets, both dont need any oil draining.
Rock Krawler Suspensions
mikebigh is offline   Reply With Quote Quick reply to this message
Unread 03-16-2010, 01:05 PM   #3
DangFoo
If they took apart the housing to replace the gasket or seal, then a bolt may be partially stripped and allowing oil to slowly leak. Luckily, I don't think that's the case, but rather a less than perfect seal again. There's no drip pattern from higher up (if I'm looking at your photo rightside-up); otherwise I'd say to check higher on the assembly.
How much oil are you burning on a weekly or monthly basis? I've never owned a 4 x 4 that didn't leak a bit: Jeep, Chevy, Ford, and Dodge alike. My cousin's fugly Toyota Tundra (I give him crap for buying Japanese) leaks the worst and it's less than 2 years old.
DangFoo is offline   Reply With Quote Quick reply to this message
Unread 03-16-2010, 01:34 PM   #4
Dronac
Well it's leaking enough to have a few drops on the bottom of the tranny as seen in the picture. I don't see any in the driveway and the oil level seems unchanged. I'm just afraid of it getting worse down the road. On the other hand, I always hear Jeeps leak no matter what you do...
Is an oil leak ok as long as the fluid levels are within normal levels?
Unread 03-16-2010, 01:43 PM   #5
mikebigh
mikebigh's Avatar
1987 YJ Wrangler
Oil leaks are not normal, they happen, yes....but maintaining a vehicle is sorta important. Your small leak is fine, I HATE oil leaks. Nothing I have leaks oil, not even my 74 VW Bus....not a drop. My 57 T-bird has a rope seal front pump(transmission) leak, im lazy though....and drive train removal is needed for that.
A 20,000 mile JK oil leak, Not normal. Bring it back, and have them warranty it. What you said they fixed, again, wont effect your oil changing today. So change your oil, and bring it back to them. They fixed a leak, and its still leaking.....if they cant fix it, find a new dealer.
